Long Life Filtration System
long life filtration system
Download PDF - 544 KBbutton: technical data
Visteon's Long Life Filtration System is a fully sealed air induction system designed to remove contaminants from engine intake air while providing noise control with minimal power loss. In addition, the Visteon Long Life Filtration System conditions the induction air stream to ensure accurate metering of air flow into the engine and contains a reticulated foam filter that is 97% porous and can be designed to last more than 150,000 miles under normal use.
Linear Mode
