Old 06-29-2008, 10:06 PM   #1
n2o Focus
Default Cosworth Intake Manifold Owners Help
For any of you who have installed the Cosworth intake manifold do you think that you might be able to help me with a sensor of off your old intake manifold. I think that my intake manifold runner control module is going bad. I was wondering if any of you might have that module that you could give me or sell me? Here is a link to a picture of it. It sits below the throttle body. Any help would much be appreciated!
http://i160.photobucket.com/albums/t...27/sensor1.jpg
Who Rides The Short Bus?
n2o Focus is offline   Reply With Quote
Old 06-30-2008, 09:30 AM   #2
arty
Default Re: Cosworth Intake Manifold Owners Help
What tells you that it is going bad? Codes?
Comp Orange Coswagon /Torsen and 4.06 gear, alum. flywheel /Centerforce. 2.3L/ 11.6 pistons, 39lb. inj. Eagle rods, Stage 2 Cosworth cams on ported street head with the Cosworth Intake and exhaust.
arty is offline   Reply With Quote
Old 06-30-2008, 02:36 PM   #3
n2o Focus
Not pulling a code. Every once in a while that module is closing and stalling out the car. It make a purge sound in the intake. I have seen it when it is idleing and that sensor is opening for a second and it almost stalls out the car. Sometimes when I am driving it will happen and kill the engine, the rest of the time it just drops the rpm's down to like 300 then comes back up.
Old 06-30-2008, 03:21 PM   #4
arty
Have you set up a tune for this engine with Cos manifold? These are tuning issues.
Old 06-30-2008, 07:00 PM   #5
n2o Focus
No I need that sensor off of the old intake.
Old 07-01-2008, 11:23 PM   #6
247_racing_zx3
What aftermarket intake are you using? And is there a tune to go with your FC throttle body?
2003 Zx3-T 2.3L
247_racing_zx3 is offline   Reply With Quote
Old 07-02-2008, 03:07 PM   #7
n2o Focus
I am using a k&n CAI and a Cosworth TB. I have a tune for my mods and when I go back to stock the problem is worse.
Old 07-22-2008, 03:51 AM   #8
Europeanfocus
Just a question for anyone how might know.
What is the size of the cosworth manifold runners. Diameter and lenght?
RECARO Sportster CS
Europeanfocus is offline   Reply With Quote
Old 07-23-2008, 11:27 AM   #9
whyme
what engine, 2.0 or 2.3? is this a dyno tune or mail order tune? who did the tune?
it might be that the tune needs to be tweeked alittle. its been a while but i remember hearing that these ecu's where a learning type ecu so you may want to inplug the battery overnight and see if the problem goes away, if that is, this problem hapened since the tune.
2006 zx3, 2.0 PZEV. Toreador red
Body Mods: Roush front fascia, HIDs (6k), 5% Tint, Blue turns, Silverstar fogs, painted headlights, BOSCH wipers.
Performance Mods: MBRP exhust, F2 CAI, F2 Header, Cosworth Cams, CFM 65mm TB, FC short throw, Steeda MIL eliminator, energy dogbone inserts, SVT 5 spoke wheels w/ Hankook K106 rubber, SVT dampers and FRPP 1 1/2 drop springs, Bix RSB retrofit, Eibach anti-roll kit(22mm front/25mm rear), slotted rotors and Hawk HPS pads, XCAL2 by FocusSport.
whyme is offline   Reply With Quote
