Tire Rack
Old 07-02-2008, 08:55 PM   #1
phil2cool
Default K&N FIPK maf lean code solution?
For the past year I have been procrastinating on getting my check engine light fixed. I couldn't clear a P0171 lean code. It occurred right after installing a K&N cai. I was stubborn and really wanted my cai to work. So I never put the stock intake back on. Only negative thing that was different was that my fuel millage had been reduced
I started to work at trying to clear this code this last weekend. I installed a new fuel filter, o2 sensor, and spark plugs (shortened life from running rich). None of those worked. A mechanic said all sensors were reading ok. I didn't get specific numbers though. Originally I did test my MAF sensor to see if it was working. I did see a difference in engine performance without it. That led me to assume it was working.
On a roll with this recent motivation I decided to go at what caused this problem in the first place. I didn't have the stock air intake nearby. So I came up with the idea to restrict air flow. My theory was based off of the engine thinking it had to much air. I went to the recycle bin and pulled out one of the cardboard flyers that I get from junk mail. I wrapped it around half of the air filter cone. I started up engine and code was gone. One year of this crap and it was solved by some cardboard! I did notice my performance has gone done a lot, almost to stock levels. For the interim I might keep reducing the paper until I get the check engine light again.
I see people on these forums get cai to work all the time. Is my MAF sensor bad because it can't handle the higher volume of air? Would repalcing it with a OEM sensor solve my problem? Or would an aftermarket MAF sensor fix this issue? I don't necessarily want to get a tune either.
phil2cool is offline   Reply With Quote
Old 07-02-2008, 09:00 PM   #2
FocusSportVP
Premiere Sponsor
Default Re: K&N FIPK maf lean code solution?
The problem is the K&N kit. I have seen this before. I literally did a data log at one of our dyno days on a car to see what the deal was. The fuel trims are thrown off, probably because they have changed the I.D of the MAF sample area. Not a good design. It can be corrected with ECU programming. Not all cars are effected, but yours is one of them obviously.
FocusSportVP is offline   Reply With Quote
Old 07-02-2008, 09:03 PM   #3
phil2cool
ECU programming meaning a tune?
Old 07-02-2008, 09:21 PM   #4
orionlion82
WARNING: This post may be hazardous to your health.
^^^yes
ive seen so many threads out here about K&N you would think they were EBAY hacks...
from what i have seen they get most things right but cant handle the focus. bad deal.
after what ive seen here i would go with a sponsor who took the time to engineer and sort out a system all proper.
orionlion82 is offline   Reply With Quote
Old 07-03-2008, 12:42 AM   #5
TungfumastR
My aircharger threw lean codes also. It's too bad k&n made a defective product. I will never buy anything from them again regardless of what I drive or the horsepower they claim.
TungfumastR is offline   Reply With Quote
