Tire Rack
Old 10-04-2008, 11:25 PM   #1
SHOoffST
Default Cam swap?
Ford manuals claim that the 2.0L duratec has a higher lift intake cam than the 2.3L duratec...
If thats true, then a simple swap could net a few more hp right? Anybody done this?
I was honestly comparing the duratec to another engine and wa surprised to stumble on this...
Sean
2006 Focus ST 2.3L
Spectre Cone Filter
Custom Ram Air
Smoothed Intake Ports on Head
SHOoffST is offline   Reply With Quote
Old 10-05-2008, 02:01 AM   #2
sayin0487
Default Re: Cam swap?
what ford manual are you lookin at. i am a ford mechanic and have access to fords online manuals.
directly out of fords workshop manual
Lobe lift — intake 8.24999 mm (0.324 in) Lobe lift — exhaust 7.80007 mm (0.307 in)
thats on a 2.0 duratec
thats on a 2.3
so according to fords online manuals, the cams are the same lift. so you would be wasting your time, according to fords online manual.
07 ST with SAP, Modified 2.5" Trubendz exhaust, FS Cool-flo intake, COSWORTH BSD, OBX header, CFM Dogbone mount, CFM STS, Eibach Pro-Kit, FS lower front stress bar, 93 octane tune thanks to focussport and the XCAL2, 159whp/151wtq
-George- Ford Certified Tech
Originally Posted by KonaZXIII
There are two seasons in Florida Summer and Hot. Both bring rain.
sayin0487 is offline   Reply With Quote
Old 10-05-2008, 09:35 AM   #3
SHOoffST
thats on a 2.3
Ok, most be some bad information I was looking at. I figured it was not that simple, but you never know...
Added displacement would surley increase power, I just didn't know if ford pulled the valve lift back to limit hp.
Sean
2006 Focus ST 2.3L
Spectre Cone Filter
Custom Ram Air
Old 10-05-2008, 12:14 PM   #4
Focusfre4k
I pay 5 dollar!
replacing cam's does not change displacement if I am correct. it was the deck height?
Originally Posted by 1badassfoci
Well I hope it wont be too big for ya...haha hopefully you wont tear your butthole!
Focusfre4k is offline   Reply With Quote
Old 10-05-2008, 06:47 PM   #5
sayin0487
technically its the longer stroke of a 2.3 that increases displacement. but the taller deck height is there because of the longer stroke.
