Tasca Auto Group
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    Senior TEAM Member iceguyb14's Avatar
    Jul 2007
    Fredericksburg, Virginia
    2,863
    Default Weird Whistling sound??
    I was driving the car today and I started hearing a weird whistling sound coming from the engine bay. i turned off the radio to listen and whenever i put any kind of load on the engine (even barely touching the gas) and im in 3rd, 4th, or 5th at about 2000rpms it starts to whistle and it gets higher pitched with the engine. its not the turbo.
    could it possibly have something to do with the clutch/flywheel? i was goin about 40mph in neutral and blipped the throttle to shift to 4th without using the clutch and as i was slightly pushing it into 4th the whistle was there and it got lower pitched with the engine speed slowing down and then it went it gear like normal. then putting load on the engine caused the sound again.
    any ideas?
    also, when in neutral with the foot off of the clutch the clutch/flywheel has been makin a lot of noise lately. more than before. it used to a little bit.. then after it was broken in it only made a little noise when the a/c was on. now its considerably louder..
    - Jeff
    2013 GT Premium Deep Impact Blue 12.39 @ 114.71mph on stock tires | 6MT | Track Pack | Recaros | Bama Tuned | JLT | Pypes | Eibach | J&M
    Sold - 2010 GT Premium - 308whp 320wtq - 12.92 @ 105.62mph
    Sold - 2005 Focus ST - FSWerks Stage 2 Turbo 250whp 245wtq 13.6 @ 103mph
    YouTube Channel - Mustang and Focus Videos!
  2. #2
    Dec 2003
    775
    Default Re: Weird Whistling sound??
    The only thing that should(not that it should) make noise on the clutch is the throw out bearing. Does it change when you depress the clutch pedal?
    Is it possible you have a small air leak?
  3. #3
    Jul 2007
    2,863
    the whistling only happens under load, so when its in neutral or the clutch is pushed in it doesnt make the sound..
    and the noise with the clutch does go away when you push in the clutch. some people have told me its just the lightweight flywheel so i dunno..
    - Jeff
  4. #4
    Jul 2007
    2,863
    all of the vacuum lines are fine too..
    ok so i just went for a drive and it is still doing it. i wanted to mention i cant hear it when the window is down, only up and its pretty quiet.. i also noticed that if i shift front 3rd to 5th its makes a kind of whistle for a second too (sounds kind of like a person whistling quietly while humming if that makes any sense). does that mean it has something to do with the tranny? could it be a t/o bearing? im 99% sure i replaced that about 4000 miles ago..
    - Jeff
  5. #5
    RECORD PROFITS ZX3autoxtasy's Avatar
    Jul 2004
    atlanta
    5,297
    I don't think the throwout bearing would make that type of noise...
    2011 Relfex Silver VW Golf 2.5L 5-Cylinder: I need some fancy Mercedes wheels for this thing...
    2004 Pitch Black 5spd 2.0L(Z) ZX3: Totalled 4/26/2011 :(
    Stuff left to sell off it: FocusSport Cool-Flo intake, H&R Rear Swaybar, Thule OEM Roof Rack w/ Fairing, Camber Bolts, etc.
    2008 Specialized Tarmac. 2010 Giant Anthem X2. Trek 1500. Fuji hipster bike. Boom.
  6. #6
    Jul 2007
    2,863
    could it be synchros?
    - Jeff
  7. #7
    Feb 2002
    Wherever peculiar people congregate
    5,176
    I had an Ranger years ago that made a sound similar to what to you describe.
    It turned out to be a problem with the heater core. The coolent flow is relative to RPM's so as the RPM's climbed the flow through the core increased making the sound.
    It sounded like the trans was going to blow up but wasn't the trans at all.
    It's not likely to be your problem but it is one more possiblilty that is fairly easy to eliminate. Just by pass the heater core and see if anything changes.
    Sounds can echo through a car and be misleading. For example one rear shock bolt just slightly loose enough for the captive washer to rattle sounded like the entire subframe was about to fall off.
    Quote Originally Posted by Chalz
    Obama doesn't have a birth certificate because he's a genetic experiment. They made him smart and good looking in a tube in a government research facility, and made him half-black to make him easier to relate to for all people. He's really just a bio-engineered Manchurian candidate.
  8. #8
    Currently listening to:
    The Thong Song
    Focusfre4k's Avatar
    Jul 2006
    3,793
    could be stupid question..do you have a decent stereo in your car? could it be alternator whine?
    2006-2009 Copper 2005 ZX5
    2009-2010 Red 2008 SE Coupe
    2010-now Velocity Red 2010 Mazdaspeed3
    Quote Originally Posted by BlkThunder View Post
    Oooooooh pm me the full pic of your wifes snatch!!! I just got me a fresh bottle of Jergins!!!
  9. #9
    Jul 2007
    2,863
    stock stereo..
    - Jeff
  10. #10
    Oct 2008
    37
    its not the radio,,,, i have a 07 zx3,, same sound only under load and at around 3200-4100 rpms,, sounds just like a turbo spoolling up.. high pitch.. clutch makes no diff.. a/c on or off no diff. i have tracked it down to the intake.. but can not find where it is... maybe to swirl valve ??
  11. #11
    May 2008
    Frederick, MD
    26
    same issue here. I noticed it once I put my cool-flo intake on. When getting in higher rpm's it starts to whistle. Maybe because of the itg filter
    05 ZX4 (sedan): FS CAI, FS Stealth Exhaust, Glow
  12. #12
    Jul 2007
    2,863
    yeah j8346 cept mine is at a little lower rpms.. its not quite like the turbo, but it is a high pitch whistle. a/c on or off doesnt make a diff.
    who knows..
    - Jeff
  13. #13
    Aug 2006
    185
    It is the intake, mine does it when I get to about 3000 rpm. it didnt do it until I put the intake on my car.
    azrally.com
  14. #14
    Jul 2007
    2,863
    just so you know i have a turbo.. i never noticed the sound til a couple days ago..
    - Jeff
  15. #15
    I AM THE MOFREAKINGMAN!
    Apr 2006
    Westchester, CA
    6,762
    i dont know if i have the same noise, my car is way to loud to hear anything
