FSWerks
Page 1 of 6 1234 ... LastLast
Results 1 to 15 of 79
Like Tree3Likes
Thread: DIY Guide: Changing Spark Plugs
    TEAM Member HEDBNGR's Avatar
    Jul 2009
    Middleburg, FL
    576
    Post DIY Guide: Changing Spark Plugs
    I've decided to take pics and make easy guides as I upgrade and make changes to my car. The pics were taken with my camera phone so they aren't as sharp as can be. This is the first time changing my spark plugs so if anyone has additional advise please comment and I'll adjust the original post as needed.
    Engine: Duratec 2.0L
    Difficulty: Easy
    Time: < 20 min
    Plugs Used: Copper Autolite 104's with .055 gap
    Tools: Socket Wrench, 5/8 deep socket (16mm), 5/16 socket (8mm), 3 to 4 inch socket extension, needle nose pliers (used to pull out spark plugs)
    Step 1: Clean off engine area to free it from any loose dirt that could fall into the plug holes (I realized I should have done this after I saw some leaves in the way >.>).
    Step 2: Using the 5/16 socket remove the screws holding the spark plug boot in place. Also remove the wires that are connected to the boot.
    Step 3: Remove the boot by making a twisting motion. Do not rock the boot side to side.
    Step 4: Using the 5/8 deep socket and extension loosen the spark plug. Be sure to turn counter-clockwise and do your best to keep the socket steady. At first, use gentle pressure when unscrewing to ensure you don't crack or break the plug (I hear this is bad ).
    Step 5: Use the needle nose pliers to grab hold of the spark plug and remove from the hole.
    Step 6: Use Anti-Seize on the threads and dielectric grease on the boot so you secure the spark plug nicely. Make a scraping motion across the threads as you gently squeeze the Anti-Seize on the threads.
    With Anti-Seize applied:
    Finally: Place the spark plug back in the hole and tighten using the 5/8 deep socket. Be sure the plug is nice and snug but don't over tighten. Remember, it's not a bolt or a nut, so you don't want to use too much force and risk cracking or breaking the spark plug. Replace the boot and twist it on for a secure fit. Reconnect the wires and screw it back down.
    You're Done!
    Last edited by HEDBNGR; Oct 6, 2009 at 12:30 AM. Reason: Added MM conversion for Socket Sizes
    redorchestra likes this.
    '06 Black ZX3 ~ The Ford of Evils Bane Build Thread
    Tokico HP shocks/struts, Eibach Sportlines
    Pioneer Premier: DEH-P690UB headunit, Pioneer TS-D1720C Component Speakers
    TS-D801P 60w RMS speakers, TS-W1008D2 350w RMS 10" Subs x2
    GM-D8500M 600w Mono AMP, Pioneer GM-6400F 4CH AMP
  2. #2
    Apr 2005
    San Jose, CA
    1,663
    Default Re: DIY Guide: Changing Spark Plugs
    Thanks for taking the time to do a write up. But i use a 8mm socket to remove the mounting bolts for the coil.
    Garage as of 5/19/14
    2003 Focus ZX3 Turbo 2.3L
    2003 Focus ZTW
    2003 Honda Civic Hybrid
  3. #3
    Jul 2009
    Middleburg, FL
    576
    Quote Originally Posted by 247_racing_zx3 View Post
    Thanks. I've added the millimeter equivalent (or closest one).
  4. #4
    Mar 2006
    Louisville, KY
    3,590
    you dont need to take the plug off the COP.
    8mm is correct
    The only standing control arms is your goal for the first time.
    If weapons killing people, scoops, make Mihajl′ Moor and fat Rosie O'donnčl′!
  5. #5
    Junior Member bigsheep's Avatar
    May 2009
    Cary
    75
    Does anyone want to chime in about putting some dielectric grease up in the boot / coil?
  6. #6
    Mar 2006
    Louisville, KY
    3,590
    eh not needed but doesnt hurt...
  7. #7
    Egz
    Egz is offline
    Inheritly Sinister
    Nov 2000
    Tappahannock, VA
    12,886
    I always put grease in the boots.
  8. #8
    Dec 2000
    San Dimas, CA
    1,780
    Quote Originally Posted by Egz View Post
    So do I. A little preventive maintenance will pay off the first time you wish you had.
    2009 Focus SES Coupe - Vista Blue
    I don't often mod my car, but when I do, I prefer FSWerks!
  9. #9
    Mar 2009
    Toronto
    119
    So the only grease you should use for this is dielectric grease?
    What is a good brand of this stuff?
  10. #10
    Egz
    Egz is offline
    Inheritly Sinister
    Nov 2000
    Tappahannock, VA
    12,886
    Yes, dielectric grease is the only stuff you should use. Brand doesn't matter.
  11. #11
    Mar 2009
    Toronto
    119
    Right on thanks..
    I changed my plugs for the first time on my 2009.. Put in Autolite 104's. There was actually a lot of grease in the boot still so I didn't grease it that time. But I plan to do it on the next change.
  12. #12
    Senior TEAM Member PR1ME's Avatar
    Aug 2006
    Jacksonville, FL
    2,924
    My little trick when changing plugs is to have a little chunk of rubber hose that fits snuggly over the spark plug, instead of the needle nose pliers.
    [RIP] Garret McIntire [7/84-4/07]
    Quote Originally Posted by OmniFocus View Post
    Pfffft... I have a side pipe on my Minivan. Ain't no thang. :p
  13. #13
    TEAM Member SVTDuck's Avatar
    Nov 2002
    Eugene, OR
    511
    Quote Originally Posted by bigsheep View Post
    I always do.
    03 FSP ZX3 Duratec 2.3
    The Just Ducky Racing Car
  14. #14
    Nov 2002
    Eugene, OR
    511
    I good spark plug socket has a rubber insert to grab the spark plug. It also is the right depth and will help keep you from breaking the ceramic.
  15. #15
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,827
    Quote Originally Posted by SVTDuck View Post
    X2.
    I always use dielectric grease as well.
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
