Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > Duratec Tuning
Old 10-11-2009, 12:21 PM   #1 (permalink)
Newbie
Default Stock deck height for 2.0 liter Duratec
Hello to the forum this is my first post. Could any members of the forum please advise as to the stock deck height for the 2.0 liter Duratec block or the stock deck height for the 2.3 block? I have searched Google, Yahoo, etc. and can only find that the 2.3 stock deck height is 11MM taller than the 2.0 liter. There has been no mention of the actual deck height for either block. Appreciate any insight and information. Thanks Jerry
Jerry Poole is offline
Old 10-11-2009, 05:03 PM   #2 (permalink)
Egz
Inheritly Sinister
Egz's Avatar
Default Re: Stock deck height for 2.0 liter Duratec
Well, I have a block out in the garage. What is the industry way of measuring it? Bottom of block to top? Or is it from crank center line?
Egz is offline
Old 10-13-2009, 05:41 AM   #3 (permalink)
Newbie
The distance from the crankshaft centerline to the block deck will be okay, thanks Jerry
Old 10-15-2009, 10:53 AM   #4 (permalink)
Looks in the Ford Racing parts catalog. I believe this and other measurements are published in the back.
2001 ZX3 Spec Rally Car - Build Thread
2004 ZX3 23D - Rally Car Engine Donor
1985 Mazda RX-7 GSL-SE
BigSandwich is offline
Old 10-15-2009, 11:01 AM   #5 (permalink)
Egz
Inheritly Sinister
Egz's Avatar
Well, unfortunately, I the only measuring device I have is a regular tape measure, so I'll tried to get the best accuracy I could.
Bottom of block (where oil pan bolts to) to deck was exactly 12.5", or 317.5mm.
From crank center line to deck was 9.12", or 231.65mm
And this was on my 2.3l, so you will need to take out 11mm from those.
Egz is offline
Old 10-15-2009, 02:25 PM   #6 (permalink)
Here you go from the Ford catalog.
Engine DISPLACEMENT:2.0L I-4 Duratec
YEARS:2005-TBD
BORE: 3.445
STROKE: 3.272
BORE SPACING: 3.780
Main Journal DIA: 2.047
Rod Journal DIA: 1.850
Rod Length (MEAN): 5.758
DECK HEIGHT: 8.540
PISTON COMP HT 1.122
Old 10-15-2009, 07:33 PM   #7 (permalink)
Egz
Inheritly Sinister
Egz's Avatar
Good info. Thanks for looking that up. I trust that more than my tape measure. lol
Egz is offline
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
