Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > Duratec Tuning
Old 10-31-2009, 09:58 PM   #1 (permalink)
Egz
Moderwhiner
Egz's Avatar
Default How do you align the crankshaft position sensor?
The manual mentions an alignment jig, but I don't see how that aligns the sensor. Is it dead middle? Does it point at a tooth?
Egz is online now
Old 10-31-2009, 11:52 PM   #2 (permalink)
Default Re: How do you align the crankshaft position sensor?
TY for asking, i couldn't find the answer to this either. When i order my new CPS im going to do a write up on how to set the engine to stock timing. Because the haynes manual i have doesn't really tell you the answer to this either.
2003 Zx3-T 2.3L
247_racing_zx3 is offline
Old 11-01-2009, 09:45 AM   #3 (permalink)
I was just wondering this the other day! The mazda 3 guys move theirs to "advance" the timing.
Last time i looked at mine i think it was close or at the center.
ehancock is offline
Old 11-01-2009, 02:35 PM   #4 (permalink)
Egz
Moderwhiner
Egz's Avatar
My guess is it looks like aligns with a tooth on the gear. Thread the bolt into the crank to lock it at TDC, and then point the sensor at the tooth. Its almost dead middle of the adjustment range.
Egz is online now
Old 11-01-2009, 03:46 PM   #5 (permalink)
So what does the alignment tool do? Because if you look closely on the sensor, there is a black line right in the middle.. I set my black line to the edge of the tooth similar to this -_ . Thinking once they both meet the signal is sent, instead of once they meet in the middle of eachother..
Not sure if that made much sense, but can someone clarify? Or possibly a picture of a CPS setup correctly?
2003 Zx3-T 2.3L
Old 11-02-2009, 12:26 AM   #6 (permalink)
Is this how others are setup?
2003 Zx3-T 2.3L
Old 11-06-2009, 07:55 PM   #7 (permalink)
Which book to you have? I have the 6" thick Ford Service manual and am wondering if its worth digging out.
04 ZX3 D23E - 173.4whp/155wtq - powered by COSWORTH
03 Screamin' Yellow SVT EAP #3444 - Stock AutoX Beast
warneej is offline
