FSWerks
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 47
Like Tree9Likes
Thread: Top Speed's 300hp NA Duratec Build
    Jul 2008
    Greenville, NC
    400
    Default Top Speed's 300hp NA Duratec Build
    We have decided to ditch the turbo zetec engine in our sedan race car and go with a naturally aspirated duratec. We should have the car running by the end of the summer.
    We are currently flow testing 2.0, 2.3 and 2.5 heads to decide on the best combinations. Physically the 2.5 intake ports are much larger than the 2.0
    The final setup hasn't been decided as we are waiting on flow numbers from the different heads.
    To see pictures of the rest of the car check out this thread
    http://forums.focaljet.com/forced-in...ld-thread.html
  2. #2
    Mar 2008
    Farmington Hills, MI
    2,007
    Default Re: Top Speed's 300hp NA Duratec Build
    This is a good thing.
    Still using the AEM computer? Custom intake manifold or ITBS? I can't imagine the Cosworth will be enough to reach your power goals, even at 12.5:1 and gnarly cams.
  3. #3
    Jul 2008
    Greenville, NC
    400
    Quote Originally Posted by ehancock View Post
    Still using the AEM computer? Custom intake manifold or ITBS? I can't imagine the Cosworth will be enough to reach your power goals, even at 12.5:1 and knarly cams.
    We are going to be using the aem ems 4 on both this car and Bryan's true street turbo focus.
    We plan on using 52mm itb's
    As for the compression ratio we are going to try a couple different things.
  4. #4
    Mar 2008
    2,007
    Are you guys considering offering a tuning package with the itbs and standalone to customers after this is done? I wouldn't mind making grumpy car more grumpy.
  5. #5
    Jun 2008
    668
    i'm following your other thread with the turbo build, are you going to be using the 2.5 block and the 2.3 head for this build as well?
  6. #6
    Jul 2008
    Greenville, NC
    400
    yes
  7. #7
    Jul 2008
    Greenville, NC
    400
    Quote Originally Posted by lapse138 View Post
    correct.
    I will post more info as we go along. We are going to test two different engines in this car.
    1st one with a stock 2.5 bottom end, ported 2.3 head, crane cams and itb's
    2nd Engine with be much more radical : 2.5 with 15:1 compression and ported 2.5 head
  8. #8
    Jun 2008
    668
    Quote Originally Posted by topspeed View Post
    correct.
    sounds awesome! take as many notes as possible haha. it seems like for your average joe on this site, the 2.5 short block swap would be the way to go, that is if you prove it to be easy and not a complete custom build.
  9. #9
    A Flock of Seagulls pseudonym's Avatar
    Mar 2004
    Tempe, AZ
    1,750
    correct.
    Is it a Ford Duratec 2.5, or Mazda MZR 2.5? If it's a Ford, is the crankshaft forged like the Mazda? I've also read somewhere that the Mazda MZR 2.5 is fully counterweighted. If possibe, could you post pictures.
  10. #10
    Premier Sponsor topspeedfab's Avatar
    Jul 2008
    Simpson, NC
    1,437
    Quote Originally Posted by pseudonym View Post
    It is a ford 2.5 from a fusion here is a picture of the crank
    Bryan @ Top Speed
    In order to speed up response time and to make sure I get all messages I do not accept Private Messages anymore.
    To contact me please click here. Fill out the contact form in detail. You can also call the shop during business hours. (252) 321-6356
    [/URL]
    Ford Focus Performance Parts | SCT Programmers | Duratec Turbo Kits | Zetec Turbo Kits | Garrett Turbos | TurboSmart Products
  11. #11
    Jan 2007
    Fife, WA
    2,114
    Would the 2.5 head work on the 2.3?
  12. #12
    Mar 2004
    Tempe, AZ
    1,750
    So it's fully counterweighted; but I can't tell for sure from the picture if it's forged. It appears to be cast, judging by what little I can see of the parting line. If so, then it's different from the Mazda crank.
    Edit: http://www.youtube.com/watch?v=cis_OSQEVWk
    From youtube. It's just a video of a dyno session of a 2.5 duratec, showing the results at the end. Looks like a little over 300hp. I tried to contact the builder, Damico, to get a little more info, but so far no response.
  13. #13
    Jul 2008
    Greenville, NC
    400
    The crankshaft is cast. Do you know of anyone that has confirmed that the mazda crankshaft is forged. Pictures? I had planned on buying a mazda 3 engine in the next few weeks to take apart and see for myself.
  14. #14
    Mar 2004
    Tempe, AZ
    1,750
    I've been going by Mazda literature, which says it's forged. I wouldn't be surprised if they switched to a cast crankshaft; as it must be much cheaper to manufacture. At least this Fusion crank is fully counterweighted.
    “The Secretary shall develop oral healthcare components that shall include tooth-level surveillance.” Before Obama’s Act of Supremacy did the English language ever have need for such a phrase? “Tooth-level surveillance”: from the Declaration of Independence to dentured servitude in a mere quarter-millennium.
    "It's a beautiful thing, the destruction of words."
  15. #15
    Jul 2008
    Greenville, NC
    400
    Yeah I have read the same thing. But I have also read that the mazda and ford bottom ends are identical.. Who know
  16. #16
    May 2006
    Boonville, IN
    3,043
    Hey guys... pretty sweet project...
    I found this after watching the above vid and looking into damico race engine...
    http://www.twinkam.co.uk/shop/catalo...WTY&shop_param=
    looks like a place that builds custom cranks for the duratec... and any motor for that matter but you have to order atleast 3 of the custom pieces... but their prices arnt bad... ~850 euro which would be a little over $1200... not bad for a billet crank
    Anyways... keep it up
    -Chris
    2002 - Twilight Blue ZTS
    Built Engine, Getrag 6spd w/ Quaife,Garrett GT3071R turbo, Tial BOV/WG
    2003 - Onyx Black Z71 Tahoe
    Loaded out the wazzu... 3" Lift & 315/70/R17 Goodyear Wrangler Duratracs(On DD Duty)
  17. #17
    Jul 2009
    Canada
    69
    Thumbs up Re: Top Speed's 300hp NA Duratec Build
    I would bet that the ford and Mazda engines are the same. Based on my experience taking apart 2.3 duratec/mzr engines they will be the same. Great info though and another interesting project to follow.
  18. #18
    Nov 2001
    Quebec
    98
    Any update ?
    ZX3 2000 - RIP
    SVT 2002 - SOLD
    sT 2005 black - Race car - RIP
    sT 2005 silver - Daily driver/weekend racer
  19. #19
    Jul 2008
    Greenville, NC
    400
    Quote Originally Posted by KevinZX3 View Post
    Any update ?
    Got in a set of crane stage 5's in. Hopefully I will have better updates later this week,
  20. #20
    Nov 2009
    Raleigh, NC
    74
    Have you considered installing the direction injection from the Mazadspeed3? It seems like this would allow for higher compression but may be difficult to tune.
