Tire Rack
Results 1 to 9 of 9
    Jan 2009
    Brazil
    169
    Default SCT X3 update problem
    Hello,
    Today I decided to update my SCT X3. Before start the process, I returned the car to stock. Then I used the "automatically check for updates" button on the SCT Device Updater. On the last part of the update process, I got an error message, I think it was the tune revision update part. Then the SCT X3 screen become missing some graphics.
    After this, I downloaded the .LWU firmware update file from SCT website and started the update by the "update firmware" button on the SCT Device Updater.
    My question is: it's taking too long to complete the update. Now it's "writing firmware". It took about 2 hours to reach 50% of the process. Is that correct?
    Thank you
  2. #2
    Nov 2007
    Florida/Shekou PRC
    490
    Default Re: SCT X3 update problem
    First question, did you actually need to update the device?
    Second, where did you buy your device from again? Depending on this will determine if you can even use the updater program (overseas devices are different. Only US is supported with the automatic updating at the moment.)
  3. #3
    Jan 2009
    Brazil
    169
    No need to update, I just decided to do it, since it was available and, according to SCT instructions on the website, there was no restrictions about upgrading.
    I bought it from EFI Components.
    The X3 is working fine now, it took about 5 hours to complete the writing firmware process. My question was about this long time.
    Thank you
  4. #4
    Nov 2007
    Florida/Shekou PRC
    490
    Quote Originally Posted by Fernando_221 View Post
    Thank you
    No, it does not take that long to update. Most likely it did not update the unit.
    What is listed in device info currently?
  5. #5
    Jan 2009
    Brazil
    169
    Quote Originally Posted by Blivit View Post
    Its not working fine anymore lol.
    In device info is showing only the serial number. All other fields are incompletes or blank.
    Could you send me an older firmware file?? I'll be much grateful.
  6. #6
    Nov 2007
    Florida/Shekou PRC
    490
    What is the serial number?
  7. #7
    Jan 2009
    Brazil
    169
    Here is:
    XP0322100ED53
    I tryed the firmware 1.2.123 .
    I think the original firmware was something with 14 in, don't remember at all.
    Thank you
    EDIT:
    The previous firmware was 1.2.122
  8. #8
    Nov 2007
    Florida/Shekou PRC
    490
    Here is:
    XP0322100ED53
    Thank you
    EDIT:
    Your device was sold as a US device (based on the serial number.)
    You can use the firmware that is on our website, but you need the 3015 version. You will have to do it manually. To do so, hold down the cancel button as you plug the device in through usb. In the updater program then choose update firmware and select the 3015 lwu file.
  9. #9
    Jan 2009
    Brazil
    169
    At the first attempt I downloaded the 3015 version firmware.
    Now it's ok. In this "manually mode" it did a lot faster, less than 1 minute.
    Thank you
