Originally Posted by Zona Kona
Here's an example of the fading from the red lenses. I have the black lenses in my garage.
When you refer to fogging are you speaking of moisture or the lenses actually getting milky similar to older headlight lenses? I would guess the fading is due to UV. Have you tried using either a transparent or translucent paint over the lens to deepen the red? Following up the color with a good clear that has UV protection might restore the lens.
Brian
Linear Mode
