Tire Rack
Old 05-23-2008, 01:45 PM   #1
Stolle
YOU MODIFY, I CRITICIZE!
Default Euro headlight harnesses.
Would anyone that has made them b4 be willing to help me make mine? there arnt any VW dealers anywhere near me.
Parts by MASSIVE, tuning by FocusSport
"You must be able to keep track of the course in your head. If you can't, then you can't drive it to its fullest potential"
:|MK1 MotorSports|:
[> MY BAD!
Stolle is offline   Reply With Quote
Old 05-23-2008, 02:56 PM   #2
o2_designs
Resident Wheel-Whore
Default Re: Euro headlight harnesses.
I'd recommend ordering the harness from BatInc or from a Euro parts place that has them. It would be alot easier.
~~Boost Crew supports single mothers~~ _/ ResidentWheel-Whore\_
'Bone Stock'2002 TwilightBlue ZX3-Neglect has led to a nasty whine from under tha rusty hood. (CHROMED)
STS Prep'd 2001 Pitch Black 5spd Wagon-(666-STFU)
"Your mom has an SVT bumper..."-Pappy, 2008
--No longer allowed access to FJ 'For Sale' Forums. Has a uncontrollable urge to buy stuff I don't need--
Old 05-23-2008, 03:46 PM   #3
Stolle
yea. im just horrible at wiring. lol
:|MK1 MotorSports|:
[> MY BAD!
Old 05-23-2008, 06:33 PM   #4
GapBoyPCS
Wiring is easy. The VW wires used have a metal clip on them that insert into the slots of the connector base.
If accessibility is an issue, definitely try our sponsors, Bat Inc.
GapBoyPCS is online now   Reply With Quote
Old 05-23-2008, 06:42 PM   #5
Stolle
anyone have the VW part number?
:|MK1 MotorSports|:
[> MY BAD!
Old 05-23-2008, 08:33 PM   #6
EggYolk_Zetec_ZX3
This is what I used for my Machs... I am horrible with wiring but this is step by step the entire way, and I didn't even **** it up! http://homepage.mac.com/alf/HIDlights/
Part numbers are listed there... be prepared to shell out a little over $100 for what you need... also get with FORDSVTPARTS to get you the Ford connector that you will need.
Current Car - MkV GTI 2.0T Reflex Silver w/DSG
Previous Car - 2002 Sonic Blue SVT #2769 of 4788 Built June 13, 2002
Wife's Car - 2007 Silver Birch Metallic Ford Fusion SE
EggYolk_Zetec_ZX3 is offline   Reply With Quote
Old 05-23-2008, 08:48 PM   #7
Stolle
hey o2. did u skip the lil plugs that plug into the existing headlight bulb pigtails and just cut those off and directly wire in the VW harness?
:|MK1 MotorSports|:
[> MY BAD!
Old 05-23-2008, 10:49 PM   #8
o2_designs
The harness in that how-to is different then the VW harness I have.
I just cut the old factory harness out, and wired up the new harness directly in. So my signals, and all my other leads go thro the same harness.
Old 05-24-2008, 12:42 PM   #9
secondechomatt
I made an adaptor harness with a couple of "weather proof" connector plugs and the wiring harness out of the old headlamps. Its easily removable and I can go back to stock headlamps in about 15 mins, if i had to.
a jetter with a case of the "usta's"
"The existence of flamethrowers is proof that someone, somewhere, said to himself, "I want to set those people over there on fire, but I don't feel like walking over there to do it."
There's no right way to eat a Rhesus.
secondechomatt is offline   Reply With Quote
Old 05-24-2008, 01:22 PM   #10
Foci_Fosho
I did the same as secondechomatt.
Old 05-27-2008, 03:25 PM   #11
RallyRacer
I bought the connectors from BAT inc. for $50. I cut off the old connectors in the car and soldered the new connectors to my existing harness. Easy and cheap.
2001 ZX3 Infra-Red, Auto
Power: Volant Ram Air, 65mm FC TB, 2000 ported intake, SVT header, Random ORP, Bosal flex, Borla exhaust, Esslinger UDP, FocusSport Xcal2(FR stage1 cams and gears to be installed)
Handling: Energy bushings everywhere, Koni Adjustable dampers, H&R sport springs, SVT rear swaybar, FC rear toe links
Braking: SVT brake kit, Hawk HPS pads F&R, Aeroquip braided lines
RallyRacer is offline   Reply With Quote
