Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Style > Exterior Modifications
Old 11-01-2009, 07:16 PM   #1 (permalink)
Default rear disk brake conversion
hello, anyone where can i find a rear disk brake conversion kit for my zx3 ( non svt). I have wanted to get rid of my rear drums for a while now. I am looking for a conversion kit that will not break the bank, and how long would install take if i found one for cheap.
zombie_ghosttrain308 is offline
Old 11-01-2009, 08:23 PM   #2 (permalink)
FORDSVTPARTS's Avatar
Default Re: rear disk brake conversion
I've got them in stock, I believe it's $429.00 for the complete kit.
If your fairly mechanically inclined you should be able to do it in a day quite easily barring any issues with stuck or broken hardware.
To order from me just call 1-800-328-9552 and ask for Steve or use one of the methods below.
2002 Silver SVT #2952 , custom CAI , Stage 2 throttle body, VF rear mount, FRPP 9mm wires, EAP/MACH HID's, Borla exhaust, K-W springs, FRPP UDP, Screamin Demon coil, Tuned by Mike at Unique Tuning in S.C.
FORDSVTPARTS is online now
Old 11-01-2009, 10:43 PM   #3 (permalink)
Yeah replacing your rear brakes is fairly simple. A bit time consuming but simple. I would give your self a half day just to be on the safe side. Should beable to complete it really in a couple hours.
POWERED BY F2
UnFocusedZX4 is offline
Old 11-02-2009, 04:22 PM   #4 (permalink)
Iceman2.0's Avatar
BAT inc. has the best prices
Iceman2.0 is online now
Old 11-02-2009, 04:43 PM   #5 (permalink)
don't put SVT rear kit w/o FRONT kit!
stock front + SVT rear setup is DANGER
jpboy is offline
Old 11-02-2009, 05:06 PM   #6 (permalink)
Not on this kit they don't
They list it on their site for $479.00 plus shipping.
I have it in stock and ready to ship for $429.00 plus shipping.
Old 11-02-2009, 05:15 PM   #7 (permalink)
how much for shipping?
Old 11-02-2009, 05:41 PM   #8 (permalink)
Just guessing without a ZIP code, $40.00-$50.00 or so.
Old 11-02-2009, 07:57 PM   #9 (permalink)
Napeolin Sherbert Gaundi
I have to say i feel in danger with my drums then when i do finally get my disc brake kit on wish i would have seen that price before i paid about 100 more then that, im fairly mechanically inclined but got a set of bolts and a thing called a control that ive got know idea where they go
2001 Ford focus se wagon Mods: FS Cool-Flo air intake, FS front stress bar, Momo pedals, underbody/interior lighting Soon adding: Drum to disc brake conversion kit and EVO 3 bumpers with fogs
Future mods: FS headers w/ flex pipe and FS exhaust with in-line cat, Corbeau FX-1 seats, svt suspension with koni or bilstein shocks and struts with H&R springs,lambo doors, custom opening rear hatch, new zetec engine with a auto to manual swap plus many more mods
zach92r is offline
Old 11-05-2009, 10:58 AM   #10 (permalink)
why is it a danger to put svt rear kit in the back and stock in the front?
norcaljess is offline
Old 11-05-2009, 11:17 AM   #11 (permalink)
Not quite following your post, if you have part numbers of the parts in question I can tell you what they are.
Old 11-05-2009, 11:19 AM   #12 (permalink)
The issue is that by adding the SVT rear discs to a 2000-2004 car you end up with rear brakes that are larger than your fronts which could cause the rear brakes to lock before the fronts which will unsettle the car.
Theres a lot of people running them that way though so just ask around foor first hand experiences.
Old 11-06-2009, 04:46 AM   #13 (permalink)
Fender's Avatar
You can always use a brake proportioning valve to solve the issue. Through trial and error adjust the brake pressure more and more to the front until you feel the fronts braking as hard or slightly harder than the rears.
2005 Ford Focus ZX3 SES. Custom CAI with a K&N Filter.
1974 Chevy K20 Stepside. 4" Lift, Front springs, rear blocks, 38" Dick Cepek Mud Country Tires, 1 ton running gear, Rebuilt Chevy 350ci, Edlebrock Carb/Intake, custom exhaust, Warn hubs, custom fender flairs. And more!
1973 VW Beetle Baja Bug in progress.
PM me if you need wire diagrams for the Focus, I can get all of them.
Fender is offline
Old 11-06-2009, 08:01 PM   #14 (permalink)
Lancer211's Avatar
Or you can just replace your brakes all at once?
Lancer211 is offline
Old 11-07-2009, 01:44 AM   #15 (permalink)
Ill get those numbers as soon as i get up lol idk why im even up at 2am, the bolts are marked 10.6 on their head.
zach92r is offline
Old 11-08-2009, 03:18 PM   #16 (permalink)
Heres the Controls numbers 5s4z-2b384-aa theres two of them and then the bolts numbers are w700672-s437 theres 2 bags of 2 of these. What are these for ????? Other then these parts i pretty much know exactly how to do the conversion, just wish i had a lift.
zach92r is offline
Old 11-13-2009, 05:56 PM   #17 (permalink)
Newbie
Do they have a conversion kit for the 2009 model i have an se coupe
blackjack09 is offline
Old 11-13-2009, 06:03 PM   #18 (permalink)
Kind of what I thought,
The 2B384's are rear ABS tone rings so if you don't have ABS you wouldn't need them.
The W700672-S437's are front caliper bracket mounting bolts.
That should clear things up I think.
Old 11-13-2009, 06:04 PM   #19 (permalink)
From what I understand the FRPP SVT rear kit will work with minor tweaking and I "think" the fronts will work as well.
I know FW Werks is running SVT rears on their '08-'09 projects.
Old 11-14-2009, 12:28 AM   #20 (permalink)
Ok thanks, No ABS on my foci so what your telling me is i can just toss these parts sweet or i could use them as spare parts if i do change to abs.
zach92r is offline
