OK, There has been some minor discussions here and there, but I would like to get is straight!
For the Oil return of the Turbo, where does everyones go?
The GUDE goes in the Oil pan, econorocketZX3's goes in the part of the engine between the oil pan and the block.
I have mine setup like the GUDE.
Some people are saying that this is not good, because the level of oil is usually ABOVE the oil pan, so it does not allow the Turbo to drain properly thus causing the seals to blow on the Turbo. BUT, when the engine is running, is there that much oil in the pan? Wouldn't it be all over inside the engine thus allowing the oil to drain properly?
If you have to drill into that part between the block and the pan, what do you have to do? From looking at it from underneath(With the pan off), if you drill into it, not all metal shavings will fall out since there is like a plate there. Do you take off that piece, drill and tap it and the replace it? If you are drilling and taping, do you screw in a special adapter piece so that you can hook up your oil line? All the fittings that I have seen, come in weird "pipe" type threads which is hard to find a tap for. So that do you do?
I hope this all makes sense! [img]images/icons/smile.gif[/img]
If anyone can shed some light, it would be great!
[img]images/icons/confused.gif[/img]
Linear Mode
