Focaljet Store
Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > Forced Induction & Nitrous
Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide
Old 06-16-2004, 03:08 PM   #1
Welding Rod
Default Precision Turbo Kit Part 1 - Components
This is the first part of a series on the Precision kit.
I got my Precision kit last night and went through it. Here are the first impressions:
The air filter is a pre-oiled conical K&N unit - that thing is HUGE! The filter is connected by 3" tube to the GT28R.
All cold tubing and the (cast) plenum are aluminum. All tube ends are bead rolled. I only found one welded connection in the cold tubing - in the center of the 3" air intake tube. The charge tubing consist of 3 pieces total of 2" tube, plus the cast intake plenum that goes from 2" up to ~3" or whatever the throttle body actually is.
I didn't see anything in the way of support tabs or brackets for the aluminum tubing so we'll see how that turns out during the install.
All hose connections under 3" diameter are by T-bolt clamps, 3" and over use worm type clamps but of the style that does not cause the hose to exude out through slits in the band.
The intercooler is 18" x 6 3/8" x 3.5" and has cast end tanks. I am a little skeptical about the wellnut mounting method for the intercooler - I may add a supplementary mount, or just substitute nuts and bolts where the wellnuts are supposed to be used.
The header and down pipe are stainless coated with titanium of some kind. The finish looks very nice. The down pipe is 2" in diameter. A header-to-head gasket is included, gaskets are not used on the header-to-turbine or tubine-to-downpipe connections.
There is a stout bracket that supports the lower (turbine end) header flange by bolting it to the block. It appears to be ceramic coated - looks very nice.
The internal wastegate actuator has a threaded arm to allow some boost adjustment. The instructions explain how to preset this arm for 8-10 PSI.
Oil is carried from the back of the block (by the starter) to the turbo via 2 prebent hard lines. Oil is returned by a Hitachi oil pump (Edit for those that have enquired: "Hitachi T-Type Oil Pump, 742-4839" - mine also says MFG No. 000151 which may just be a serial number) via braided stainless hoses that are terminated with real pressure connectors - not faux aluminum shielded hose clamps. The pump uses a simple 2 wire connector for power. There is a US made "Digi-Set" timer/relay of some sort that will cause the pump to run for a few minutes after engine shut down.
A new Ford oil seperator is included. It has a threaded nipple TIG welded on for the oil return line. Here is something for you Eric - According to the instructions it also must have some kind of modified or alternate PCV valve as it is warned that the supplied one must be used instead of the factory valve (?)... the part number of the supplied valve is AC Delco Type CV-893C.
There are some beautifully done prebent stainless hard lines to plumb water into and out of the turbo.
All in all it appears that someone went to alot of effort to try and ensure the component quality was about as good as could be sourced. I am left with a very good first impression of the parts and materials selected.
One hang up I found so far - my car does not have air conditioning and the oil pump bracket is designed to bolt to the AC pump. I guess Foci without AC are rare? This means that I will have to fab up my own bracket. Not a big deal, this will actually work in my favor as I will be able to gain a little ground clearance (I have a Cup Kit suspension) by moving the pump back closer to the block, but something potential buyers should be prepared for. Precision is express shipping me a longer oil return line (no-charge) to allow this relocation reward.
Next installment... Installation
Welding Rod is offline   Reply With Quote
Old 06-16-2004, 03:52 PM   #2
Violent_Ed
Default Re: Precision Turbo Kit Part 1 - Components
Congratulations on the arival of the kit! Im glad everything looks good, and hope the insall goes smooth.
Cant wait to see it run.
Violent_Ed is offline   Reply With Quote
Old 06-16-2004, 03:58 PM   #3
belacyrf
[FJ] Addict
Great Write-Up
That downpipe seems really small however, but hopefully it will work out ok. I cant till the next issue !
belacyrf is offline   Reply With Quote
Old 06-16-2004, 04:06 PM   #4
blueovalbaboon
Location: Lubbock, TX (my once and future--but not right now--home
Great Write-Up
that's what I was thinking 2" and 10psi? Can we say restriction?
blueovalbaboon is offline   Reply With Quote
Old 06-16-2004, 05:44 PM   #5
Welding Rod
I will have to see how that down pipe works out. ATP Turbo was running 295WHP on their 1.8 Quatro project car with its original 2.25" exhuast... so who knows?
I will be running it into a 2.25" flex and 2.5" Borla system initially. After testing, if I can't reach my desired output of 230whp I may redo the entire exhaust from turbo to tailpipe with 3" - to the tune of close to $1K, so I'll try what I got first. Should be interesting.
Old 06-16-2004, 05:51 PM   #6
BowDown
1k for just an exhaust and downpipe?
BowDown is online now   Reply With Quote
Old 06-16-2004, 07:21 PM   #7
jeffro03
I really like my Precision kit. The install was easy. Just buy some really good drill bits for the intercooler install. The bumper is made of some really hard metal. The mounts work fine on my car.
jeffro03 is offline   Reply With Quote
Old 06-16-2004, 07:33 PM   #8
Welding Rod
Bow - That $1K would be for $200 worth of stainless parts (flange, transition w/v-band connection, 3 90 degree 3" CLR bends) to build a 3" down pipe, ~$700 for stainless Trubendz flex and exhaust with shipping, and $100 more just because it always cost at least that much more than what you had planned.
Old 06-16-2004, 08:00 PM   #9
BowDown
Theres a guy selling a new SS 3" Trubendz setup in the Classifieds for CHEAP! and I think he's selling the flex too .
Old 06-16-2004, 08:46 PM   #10
Violent_Ed
I can not remember if you talked about this in your first post, but are you going to switch it to an external wastegate?
Old 06-16-2004, 09:32 PM   #11
Welding Rod
I have no plans to go to an external unless it proves to be needed. I will be operating this turbo well within its intended limits and I have no reason to question Garrett's engineering yet. Harry at Precision told me it holds boost rock solid.
Old 06-17-2004, 01:54 AM   #12
troy1nonly
one thing that I have noticed about the kit that seems a bit off is the flange that they use between the turbo and the downpipe...seems that they could have done a better job with the flow by adding at least a bump of some kind into the internally regualted waste gate. As I see it now, the exhaust has to flow out of the turbo, turn 90*, and turn 90* again to make it into the exhaust flow...
troy1nonly is offline   Reply With Quote
Old 06-17-2004, 08:57 AM   #13
Lentech Automatics
We also had some concern about this 2" downpipe on our car....we have trubendz 3" and flex. If necessary we may fab a 3" downpipe . Should have final dyno results with the 2" in the next day or two. We replaced the supplied injectors and the factory rail when we ran out of fuel at 190whp on the auto trans, so we'll see what that nets.
Lentech Automatics is offline   Reply With Quote
Old 06-17-2004, 11:03 AM   #14
TragiC
Nope thats Sold
TragiC
TragiC is offline   Reply With Quote
Old 06-17-2004, 01:48 PM   #15
Drabert
how does the piping run? i mean from the turbo to intercooler to throttle body? does it go over the top of the engine to the throttle body, over the tranny, or under the engine (like the AC)
congrats on the new toy... i dont know who i am going to bug now with my AC problems but i cant wait to see the numbers you put out
Drabert
Drabert is offline   Reply With Quote
Old 01-28-2006, 04:13 PM   #16
Welding Rod
Bumping this thread for someone who asked for some info from it.
05 ST Bone Stock
Old 01-28-2006, 04:58 PM   #17
Ray
Driver > Car
added to the references, just in case
Cable Ties. Is there anything they can't fix? Driver > Car - in memory of GaryK
Roadtrippin.org | CART
Ray is offline   Reply With Quote
