| Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide |
#26 (permalink) |
$3|\|10r 734|\/| |\/|3|\/|b3r
- 04 SVT, 10lbs Procharger, 42lbs/hr Injectors, Diablo Tune and Mafia, CFM Highflow cat, Borla Center Exit, 600 ft altitude.
- Dynos ![]()
#27 (permalink) |
![]() ATI SVT ProCharger 10lb kit FC ORP CFM 67mm TB 60lb/hr injectors, Diablo MAFia, Kenne Bell Boost-a-pump Borla 2.5in exhaust stock compression ratio stock internals J&S Safeguard Custom tuning done by Hector of Central Florida Motorsports w/SCT XCal2, tuning done on both the dyno and the road for peak hp and overall driveability. Jason
2006 Dodge Ram SLT 4x4 Quad cab. Custom exhaust, Alpine and JL Audio sound system Old: 2002 ProCharged SVTF 2000 Dodge Dakota Last edited by ArmyFocus; 05-03-2007 at 05:55 PM. |
#28 (permalink) |
Jon's latest dyno from our most recent dyno day:
Best Regards, Randy Robles Vice President FocusSport / FSWerks www.focussport.com / www.fswerks.com 714.630.6353 ![]() Check out our NEW video on www.TheFordStory.com. Please leave a comment! Click me! The FocusSport Street Tuner Challenge Focus 396 WHP / 347 WTQ - Click me! |
#29 (permalink) |
![]() Tuned by ray at McNews low boost was at 13.5 lbs mid boost was 17 lbs and high boost was 20 lbs but it wasn’t a finished tune. ray and i decided that anything over 300 hp was going to be pointless because the turbo hits so hard that even in 4th gear we would get wheel spin. so we thought that the 280 HP mark would be good. so we just went with the 13.5 lbs and the 17lbs tunes. ray was saying that it has a **** load of mid range power, but what im most happy about is the torque #s.
Pitch Black Euro Focus Rieger Kit, 18x8 DPE Wheels, Full Alpine System, Built CGI Block/Head, T3/T04e CBB Turbo, 300.17 HP, FF ROTM January 2007/FJ ROTM June 2007 www.mnfocus.com Minnesota Focus Owners Club |
#30 (permalink) |
![]() 2003 2.3l PZEV Auto Transmission(for those wondering) FocusSport Stage 2 Turbo @9.5PSI BS Delete/2.5" TrubedZ Stainless Steel,Exhaust, W/ Hi-Flo HP eating Cat
-2003 SE PZEV ATX - FS 2.3l Stage 2 1/4: 13.78@100mph -2008 Mazda 3S Touring 2.3l w/VVT |
#32 (permalink) |
![]() low boost was at 13.5 lbs mid boost was 17 lbs and high boost was 20 lbs but it wasn’t a finished tune. ray and i decided that anything over 300 hp was going to be pointless because the turbo hits so hard that even in 4th gear we would get wheel spin. so we thought that the 280 HP mark would be good. so we just went with the 13.5 lbs and the 17lbs tunes. Turbonetics T3/T4 CBB Turbo Focus-Power Mani/Down Pipe Custom Blow Through IC Piping Greddy Type S BOV CGI WRC Block w/ Oil Squirters Diamond 9:1 Compression Pistons Crower Connecting Rods Focus-Power Main Caps ARP Bolts On Everything Custom P&P Head McNews Turbo Grind Cams Ford Racing Valve Springs Focus Central Cam Gears Focus Central 3-Peace UDP Focus Central TB 3” Exhaust Diablo MAFia Diablo Sport Chip 72lbs Injectors VF Engineering Rear Mount Clutch Master Stage 4 Clutch Focus Sport Flywheel Quaife LSD
#33 (permalink) |
Here's my Powerworks setup...
![]() 2001 ZX3 9.0:1 shortblock stock head and cams SVT header, cat, flex, and Magnaflow exhaust 3.82:1 Final Drive |
#34 (permalink) |
Xios kit, stock internals, ORP, stock flex/exhaust
2002 Pitch Black SVT: Math according to Xios and FocusSport: (1 snailpower*6.8psi)/1 wheel = 235whp/209wtq |
#35 (permalink) |
Driver > Car
From a few months ago, sorry, i thought i posted this.
we figured we could get over 300 if we wanted, but... car is fast enough as is.
Vacuum Vulture Racing - I can fix your car with a hammer. Intelligence is largely at the mercy of self-control Roadtrippin.org | CART |
#36 (permalink) |
Here's my Procharged Zetec numbers...this was on a second gear pull because 3rd gear was slipping on high RPMs and my tuner said I was losing out on 5-15 HP because of this but but I don't know.
![]() Mods: Focussport stealth exhaust, 65 mm Focus Central throttle body, stage 1 Spec clutch, reworked SCT chip, 10 lbs Procharger kit
I pretend to text in awkward moments... '01 Rainforest Green ZX3 - Procharged w/ Focussport Stealth Exhaust, FC 65mm TB, 42 lbs injectors, retuned SCT chip and Clutchmasters Stage 3 clutch - 200 HP/170 TQ to the ground Last edited by Hitokiri; 08-25-2007 at 11:38 AM. |
#37 (permalink) |
![]() Performance: Focus-Power 2.3 Zetec Stroker Kit on CGI WRC Short Block Focus-Power 3" Header Back Exhaust Focus-Power Billet Main Caps, Crank, Rods, & Pistons @ 9.2-1 Ford Racing Torsen T2 Differential Ford Racing Jet-Hot Coated SVT Header SVT Ported & Polished Head SVT Cam Shafts ProCharger C-2 Supercharger using 2.55" Blower Pulley Central Florida Motorsports 5.7" Over Drive Crank Pulley Central Florida Motorsports 65mm Throttle Body Clutchmaster Stage IV Clutch Fidanza 12Lbs Flywheel 1 x Kent Cams Adjustable Cam Gear 1 x Esslinger Adjustable Cam Gear ARP Cam Gear Bolts ARP Studs Siemen's Deka 60Lbs Fuel Injectors MSD Coil Pack & 8.5mm Spark Plug Wires 180 Degree Thermostat Godspeed Front Mount Intercooler & Custom Piping Forged's By-pass Valve Engine Management J&S Vampire Ultra Safegaurd SCT X-Caliber 2 Kenne Bell Boost-A-Pump Diablo MAFia Mods: Central Florida Motorsports Intake Manifold Couplers All 3 VF Engineering Engine Mounts And a crap more on the exterior and interior that does not help with this chart.
Born: June 12, 2003 #2907 of 3985 SVT Silver Bullet Turbocharged @ ___Hp/___Tq by Focus-Power! Numbers coming soon! |
#38 (permalink) |
My ZTS dyno sheet... mods in my signature.
![]() It looks kinda goofy because the hp and torque were no plotted on the same grid-the left side is the torque x-axis and the right side is the hp x-axis.
OBX 4-2-1 header, FC short shifter, MBRP exhaust, Crane St. 2 cams, Powerworks supercharger. |
#39 (permalink) |
Same day, same dyno as 02ztsian.
Stock SVT with : Procharger 8PSI 60lb injectors MAFia Tuned remotelly via email by Focus-power
Procharged SVT 8PSI : 236whp/190wtq (on Mustang Dyno) by Focus-Power N/A ZTW : 117whp/116wtq (on Mustang Dyno) by Tecmotion |
#42 (permalink) |
The FocusSport "Street Tuner Challenge" Focus that we built to compete on the TV show on SPEED:
#44 (permalink) |
ARNIE's dyno:
#45 (permalink) |
Here is MARKSZX3's dyno chart:
![]() I think Mark only has one post on Focaljet so don't expect him to say much. ![]() Mark if you read this, pop in and say hello!
#46 (permalink) |
Here is nitetimebolher's dyno chart:
#47 (permalink) |
heres my latest dyno!
- Jeff 250whp/245wtq at 11psi... *ENGINE BUILD PARTS/COSSIE IM/FSW STAGE 1 TURBO KIT/EXEDY HYPERSINGLE/FORD RACING HEAD COMPLETE WITH EVERYTHING FOR SALE!!! PM me for info.. FIRST COME FIRST SERVE* |
#48 (permalink) |
put down: 133whp and 134wtq, N/A
put down: 203whp and 226wtq, nitrous CAI, Magnafow cat back, 75 shot nitrous!!! http://i292.photobucket.com/albums/m...ICSVOL2003.jpg http://i292.photobucket.com/albums/m...ICSVOL2002.jpg Per FJ rules, your images were too large so they have been turned into links. Last edited by FocusSportVP; 05-18-2008 at 09:21 PM. |
#49 (permalink) |
[IMG]
[/IMG]Just did these today at 19psi car made 353.4hp and 322.6 tq on the second run the car wouldn't build boost and the A/F was not right so I didn't go again. Looking the car over and hour later found that it blew a vaccum line off the intake manifold and was loosing boost. So, I'll have to get another run to 24psi to know the limits. Car is crazy fast Thanks Orange and Supersnail again for a job well done. ![]() Oh, yeah this is with VCT
Mods: Custom turbo kit thanks to Supersnail Fab and OrangeSvt03. and other things! Clutch is here,Thank you Southbend for a great product and service and the clutch will hold 350ftlb of Torque. SVTF 353.4hp and 322.6Tq at 19psi with VCT Last edited by 99dot; 06-22-2008 at 02:01 AM. |
#50 (permalink) |
![]() 4th gear pull -high temps - 1st attempt with stock rev limiter and conservative spark /fuel settings specs as per signature
PowerWorks 2044cc Zetec -CR 9.7:1, Diamond pistons with Eagle rods ,lightened - weightbalanced crankshaft, 2.4'' pulley, 5.36''crank pulley, FR head with 1mm Supertech inconel valves,ported and polished supercharger manifold, Mcnews custom SC cams, SVT manifold decat with 2.75'' custom pipes with custom middle box,MTX trans 4.06 final with HyperSingle Exedy and Torsen T2 -- from JJ POWER -- |
| Thread Tools | |
| Display Modes | |
