Top Speed Performance
Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > Forced Induction & Nitrous
Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide
Old 06-21-2008, 11:02 PM   #51
99dot
Default Re: Forced Induction Dyno charts & specs
[IMG][/IMG]
Just did these today at 19psi car made 353.4hp and 322.6 tq on the second run the car wouldn't build boost and the A/F was not right so I didn't go again. Looking the car over and hour later found that it blew a vaccum line off the intake manifold and was loosing boost.
So, I'll have to get another run to 24psi to know the limits. Car is crazy fast
Thanks Orange and Supersnail again for a job well done.
Oh, yeah this is with VCT
Mods: Custom turbo kit thanks to Supersnail Fab and OrangeSvt03. and other things!
Clutch is here,Thank you Southbend for a great product and service and the clutch will hold 350ftlb of Torque.
SVTF 353.4hp and 322.6Tq at 19psi with VCT
99dot is offline   Reply With Quote
Old 07-23-2008, 03:02 PM   #52
geostef
4th gear pull -high temps - 1st attempt with stock rev limiter and conservative spark /fuel settings
specs as per signature
PowerWorks 2044cc Zetec -CR 9.7:1, Diamond pistons with Eagle rods ,lightened - weightbalanced crankshaft, 2.4'' pulley, 5.36''crank pulley, FR head with 1mm Supertech inconel valves,ported and polished supercharger manifold, Mcnews custom SC cams, SVT manifold decat with 2.75'' custom pipes with custom middle box,MTX trans 4.06 final with HyperSingle Exedy and Torsen T2
-- from JJ POWER --
geostef is offline   Reply With Quote
Old 09-25-2008, 08:52 AM   #53
topspeedfab
TEAM Sponsor
Stock ZETEC
Top Speed Turbo Kit
Garrett GT3076 w/ TiAL Stainless Steel .63 A/R Exhaust Housing
TiAL 44mm Wastegate
10psi: 240.67whp
12psi: 265.09whp
This is another members car, we just did all the fab work and tuned it.
Bryan Emanuel
Top Speed Performance & Fabrication
bryan@topspeedperformance.net
(252) 321-6356
www.topspeedperformance.net
topspeedfab is offline   Reply With Quote
Old 10-07-2008, 06:24 PM   #54
Power Surge
Built short block at 9.2:1 CR, with a ported head, stock cams, shimmed springs for more seat pressure, 42s, ported JRSC supercharger, port matched intake, 180 thermostat, and ORP. I am guessing the car has the BBK as well, since it's got a blue pulley. Has a P-MAS MAF with cone filter.
Dyno graph is below. As you can see, SAE numbers are 214/164. You can see how well the porting is, because it's still going up in hp even at 7500 rpms. I set the A/F at about 11.7 all the way across, and timing is 19 total at WOT. Now normally I tune non-I/C blower cars at about 16 total, but in searching the forums it seems that these cars can take a little more with a lower CR piston setup. The previous tune (which was on the stock motor) was actually seeing 26 total, and I felt that was way too much. So I was shooting for about 19-20 total and it seemed to like it.
Boost hits just about 8 psi, which I figure is right for the BBK with a ported head, since the porting will drop your boost about 2 psi.
I was hoping for more power, but after thinking about it and looking at other SVTF JRSC dyno sheets (stock and built), I think my numbers seems pretty good. A stock SVT has more compression ratio and the BBK usually makes 10 psi with a stock head, so my setup is giving up some hp from less boost and less CR, but yet makes the same power as a car with more boost and CR. I could add more boost to it and easily get to the 250whp range, but since it's a DD and I really don't go WOT often, I don't see the need (right now).
Sal
2002 Sonic Blue SVT Focus 4098 of 4788 - supercharged
2008 Vista Blue 2 dr Focus SE - stock for now
Shelby American 427 Cobra S/C - CSX 4241
Power Surge is offline   Reply With Quote
