| Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide |
#51 |
Xios kit, stock internals, ORP, stock flex/exhaust
2002 Pitch Black SVT: Math according to Xios and FocusSport: (1 snailpower*6.8psi)/1 wheel = 235whp/209wtq |
#52 |
aka demonfire
From a few months ago, sorry, i thought i posted this.
we figured we could get over 300 if we wanted, but... car is fast enough as is. ![]()
Cable Ties. Is there anything they can't fix? Driver > Car - in memory of GaryK Roadtrippin.org | CART |
#53 |
![]() 285hp 245tq Powerworks SC 2.4 pully FR head Eagle rods JE 9.1 Pistons Arp everything 93 Octaine
2000 Powerworkd Black ZTS..Forged internals, FRPP head with the Massive 2.4 BBK.. 285hp 245tq!! 2005 Focus ST W/ FS StgII Turbo JCM #608 |
#54 |
Here's my Procharged Zetec numbers...this was on a second gear pull because 3rd gear was slipping on high RPMs and my tuner said I was losing out on 5-15 HP because of this but but I don't know.
![]() Mods: Focussport stealth exhaust, 65 mm Focus Central throttle body, stage 1 Spec clutch, reworked SCT chip, 10 lbs Procharger kit
"Sauske is my friend. Someone who I was finally able to form a bond with. I don't care who I have to fight. If he rips my arms off I'll kick him to death. If he rips my legs off I'll bite him to death. If he rips my head off I'll stare him to death and if he gouges out my eyes I'll curse him from beyond the grave!" - Uzumaki Naruto '01 Rainforest Green ZX3 - Procharged w/ Focussport Stealth Exhaust, FC 65mm TB, 42 lbs injectors, and retuned SCT chip - 200 HP/170 TQ to the ground Last edited by Hitokiri : 08-25-2007 at 10:38 AM. |
#55 |
![]() Performance: Focus-Power 2.3 Zetec Stroker Kit on CGI WRC Short Block Focus-Power 3" Header Back Exhaust Focus-Power Billet Main Caps, Crank, Rods, & Pistons @ 9.2-1 Ford Racing Torsen T2 Differential Ford Racing Jet-Hot Coated SVT Header SVT Ported & Polished Head SVT Cam Shafts ProCharger C-2 Supercharger using 2.55" Blower Pulley Central Florida Motorsports 5.7" Over Drive Crank Pulley Central Florida Motorsports 65mm Throttle Body Clutchmaster Stage IV Clutch Fidanza 12Lbs Flywheel 1 x Kent Cams Adjustable Cam Gear 1 x Esslinger Adjustable Cam Gear ARP Cam Gear Bolts ARP Studs Siemen's Deka 60Lbs Fuel Injectors MSD Coil Pack & 8.5mm Spark Plug Wires 180 Degree Thermostat Godspeed Front Mount Intercooler & Custom Piping Forged's By-pass Valve Engine Management J&S Vampire Ultra Safegaurd SCT X-Caliber 2 Kenne Bell Boost-A-Pump Diablo MAFia Mods: Central Florida Motorsports Intake Manifold Couplers All 3 VF Engineering Engine Mounts And a crap more on the exterior and interior that does not help with this chart.
Born: June 12, 2003 #2907 of 3985 SVT Silver Bullet Procharged @ 335Hp/251Tq by Focus-Power! |
#56 |
My ZTS dyno sheet... mods in my signature.
![]() It looks kinda goofy because the hp and torque were no plotted on the same grid-the left side is the torque x-axis and the right side is the hp x-axis.
OBX 4-2-1 header, FC short shifter, MBRP exhaust, Crane St. 2 cams, Powerworks supercharger. |
#57 |
Same day, same dyno as 02ztsian.
Stock SVT with : Procharger 8PSI 60lb injectors MAFia Tuned remotelly via email by Focus-power ![]()
Procharged SVT 8PSI : 236whp/190wtq (on Mustang Dyno) by Focus-Power N/A ZTW : 117whp/116wtq (on Mustang Dyno) by Tecmotion |
#58 |
Precision turbo kit.
![]() Mods in my signature
Precision turbo kit 216whp - 230wtq |
#59 |
DIY Turbo kit
Stock SVT engine 10 psi ![]()
Stupidity is forever, Ignorance can be fixed. There is no I in TEAM, However there is a M & E |
#60 |
Premiere Sponsor
The FocusSport "Street Tuner Challenge" Focus that we built to compete on the TV show on SPEED:
Best Regards, Randy Robles Vice President www.focussport.com / www.fswerks.com 714.630.6353 ![]() A work in progress - The 384 WHP / 341 WTQ FocusSport Turbo ZX3 - Click me! The FocusSport Street Tuner Challenge Focus 396 WHP / 347 WTQ - Click me! |
#61 |
352 WHP 307 WTQ Escort ZX2 Turbo Boost |
#62 |
Premiere Sponsor
ARNIE's dyno:
#63 |
Premiere Sponsor
Here is MARKSZX3's dyno chart:
![]() I think Mark only has one post on Focaljet so don't expect him to say much. ![]() Mark if you read this, pop in and say hello!
#64 |
Premiere Sponsor
Here is nitetimebolher's dyno chart:
#65 |
heres my latest dyno!
-Jeff 2005 Infra-Red Focus ST- FocusSport Turbos... For when you can never have too much power... :) http://www.cardomain.com/ride/2992424 |
#66 |
put down: 133whp and 134wtq, N/A
put down: 203whp and 226wtq, nitrous CAI, Magnafow cat back, 75 shot nitrous!!! http://i292.photobucket.com/albums/m...ICSVOL2003.jpg http://i292.photobucket.com/albums/m...ICSVOL2002.jpg Per FJ rules, your images were too large so they have been turned into links. Last edited by FocusSportVP : 05-18-2008 at 08:21 PM. |
#67 |
[IMG]
[/IMG]Just did these today at 19psi car made 353.4hp and 322.6 tq on the second run the car wouldn't build boost and the A/F was not right so I didn't go again. Looking the car over and hour later found that it blew a vaccum line off the intake manifold and was loosing boost. So, I'll have to get another run to 24psi to know the limits. Car is crazy fast Thanks Orange and Supersnail again for a job well done. ![]() Oh, yeah this is with VCT
Mods: Custom turbo kit thanks to Supersnail Fab and OrangeSvt03. and other things! Clutch is here,Thank you Southbend for a great product and service and the clutch will hold 350ftlb of Torque. SVTF 353.4hp and 322.6Tq at 19psi with VCT Last edited by 99dot : 06-22-2008 at 01:01 AM. |
#68 |
![]() 4th gear pull -high temps - 1st attempt with stock rev limiter and conservative spark /fuel settings specs as per signature
PowerWorks 2044cc Zetec -CR 9.7:1, Diamond pistons with Eagle rods ,lightened - weightbalanced crankshaft, 2.4'' pulley, 5.36''crank pulley, FR head with 1mm Supertech inconel valves,ported and polished supercharger manifold, Mcnews custom SC cams, SVT manifold decat with 2.75'' custom pipes with custom middle box,MTX trans 4.06 final with HyperSingle Exedy and Torsen T2 -- from JJ POWER -- |
| Thread Tools | |
| Display Modes | |
