Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > Forced Induction & Nitrous
Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide
Old 08-22-2005, 10:49 AM   #1
DJ Sures
Exclamation Forced Induction Dyno charts & specs
I have a good idea . I'd like to maybe suggest this as a sticky . And have it to be place for ppl to post:
- FI type, modifications, specifications
- Dyno charts
- Pictures or other useful media
If you don't have a dyno chart, please don't post in this thread.
And perhaps we can please avoid discussions in this thread and keep it as an information resource instead.
*** Because dyno numbers are always targetted, please respect the post. And if need be, challenge the information in a New thread, not this one.
DJ Sures is offline   Reply With Quote
Old 08-22-2005, 10:51 AM   #2
DJ Sures
Default Re: Forced Induction Dyno\'s, times and Specs
sInce it was my idea to do this, i'll put my head on the chopping block first...
AFR at WOT holds pretty steady at 11.5.
Rest of tune is done in Open Loop.
<font class="small">Code:</font><hr /><pre>
Engine
42 lbs Injectors
Eaton M62 Super Charger with 3.6" pulley (5 psi)
Motor rebuilt with new internals from Lightspeed Innovations
- Ported and Polished head work
- Custom hone
- Custom ring gaps
Fidenza Adjustable Exhuast Cam Gear
Fidenza Aluminum Fly Wheel
3" Magnaflow exhaust
Off road cat delete from Lightspeed Innovations
3" Intake Piping (anodized blue)
K&amp;N Air Filter
Jackson Racing Fuel Rail
Jackson Racing Intake Manifold
Larger Fuel Line
Relocated MAF &amp; IAT
GReddy oil catch can
Tuned by Lightspeed Innovations
</pre><hr />
Old 08-22-2005, 02:08 PM   #3
Welding Rod
About 12 PSI, 2" down pipe and 2.5" exhaust:
About 14 PSI and 3" complete exhaust:
Engine mods: Precision GT28R w/ Intercooler, SCT Pro-Racer, Lightning 90mm MAF sensor inside 3" tube, 60 LB Injectors, Relocated Lightning ACTs, 3" Down pipe and Exhaust, Safeguard, Aquamist
Dip in 14 PSI dyno is from inadequate timing... that was the first dyno at that high of a load, and the timing was too conservative at the time... I never expected that kind of load to be achieved so early.
Welding Rod is offline   Reply With Quote
Old 08-22-2005, 02:12 PM   #4
scott77
9 psi, focus-power full kit, 91 octane...not actually running that tune right now (long story, ha) but will be once I am able to run back up to FS.
stock longblock
scott77 is offline   Reply With Quote
Old 08-22-2005, 02:29 PM   #5
FocusSportVP
Premiere Sponsor
FocusSportVP is offline   Reply With Quote
Old 08-22-2005, 02:30 PM   #6
FocusSportVP
Premiere Sponsor
This is the prototype and is subject to change.
Old 08-22-2005, 02:40 PM   #7
SVTDavan
Well, here is mine, mere hours before it blew up.
Focus-Power Stage 1 turbo and manifold hitting 11psi
custom fabbed piping
custom downpipe and cat eliminator
42 pound injectors
stock exhaust
SVTDavan is offline   Reply With Quote
Old 08-22-2005, 02:57 PM   #8
w00w00
toms stg 1/mic at 10psi on 93 oct
bone stock zetec longblock
3" exh, ported tb, blocked egr
w00w00 is offline   Reply With Quote
Old 08-22-2005, 03:01 PM   #9
Penguini66
171.6hp/176ft-lbs
Aerocharger Stage 2 at around 7psi
2.5" Borla
Off Road Pipe
Volant air box
70mm Pro-M MAF
42# injectors
SCT PRP base tune with MAF transfer function created from the Pro-M flow sheet.
Still need to get around to getting it on the dyno now that I've added:
Aerocharger stage III intercooler
TiAl 38mm external Wastegate with .7bar(10.15psi) spring
Penguini66 is offline   Reply With Quote
Old 08-22-2005, 03:37 PM   #10
FocusSportVP
Premiere Sponsor
Here is the dyno of the car that Aerodyne brought for us to check out back in the day. We didn't tune it, they had their 5th injector set up on there.
Old 08-22-2005, 03:41 PM   #11
belacyrf
[FJ] Addict
Best I have for now... with slipping clutch and half tuned.
9-10 PSI
14-15 PSI
GT28RS Turbo
2.5" MBRP Exhaust
Boost Controller
RT Catalytic
42# injectors (on this run currently on 71# injectors)
2002 Mustang GT Maf.
Other Bits and pieces
I actually stickied this topic as I think it's very nice to have a thread like this, with a topic like this nice and visible.
belacyrf is offline   Reply With Quote
Old 08-22-2005, 03:57 PM   #12
FocusSportVP
Premiere Sponsor
Here is one of Todd Parker's dyno runs:
Old 08-22-2005, 04:13 PM   #13
FocusSportVP
Premiere Sponsor
Here is FocusSportTECH's Focus at our last dyno day:
Old 08-22-2005, 08:43 PM   #14
OrangeSVT03
ONLY MODS:
Prototype Intake Manifold, VCT Eliminator, cam gears, 65mm FC TB, GT28RS, One Off tubular Turbo manifold, Tom's intercooler &amp; piping, 2.5" downpipe, 3" cat-back, ORP, Quaife, Fidanza, CM-4, one AWESOME tune by Tom..... thats all the main stuff
15psi on 93 octane
20-21psi on 93 octane
19psi on 93 octane
FYI my car has NEVER been tuned on anything other than 93 octane
OrangeSVT03 is offline   Reply With Quote
Old 08-23-2005, 02:03 PM   #15
steve7786
Here's my latest
steve7786 is offline   Reply With Quote
Old 08-23-2005, 11:50 PM   #16
orangeZXT
42 pound injectors
stock exhaust
what happen to car man
orangeZXT is offline   Reply With Quote
Old 09-01-2005, 01:39 PM   #17
DrTorque
Here's demonfire's:
edit: since this is my car, i'll list the horsepower mods done.
Vortech supercharger (2.62" pulley)
PWR WTA Barrel Intercooler (4"x6")
Teel pump (3.8 gpm)
double heat exchangers (cool-it, in series)
trubendz 3" flex back with magnaflow muffler, and a 31" long magnaflow resonator (3" inlet outlet, but core is 2.5")
FC 65mm tb
pro-m 70mm mafs
FR 55lb / hour injectors
SCT Xcalibrator2 by Bristol dyno
DrTorque is offline   Reply With Quote
Old 10-07-2005, 04:02 PM   #18
mab351
Please be aware that the TQ and HP numbers are NOT on the same scale
2003 SVT Focus 245.8 HP / 193.4 lb/ft TQ
STOCK REV Limiter
Powerworks SVT kit
NO base engine or vehicle mods
NO custom tuning (stock powerworks tune on 91oct)
NO additional parts or hardware or tuning required
20k mi already on the vehicle after the kit was installed
Used for numerous demo drives shows and track events during the milage accumulation
2003 ZX3 Automagic 202.1 HP / 167.3 lb/ft TQ
STOCK REV Limiter
Base Powerworks Auto kit
NO custom tuning (Stock Powerworks calibration on 91 oct)
NO base engine/transmission or vehicle mods
10K mile durability, used for demo drives and shows.
mab351 is offline   Reply With Quote
Old 10-11-2005, 11:20 AM   #19
EvoZX3
JRSC BBK, K&N air filter, FR spark plug wires, one step colder copper spark plugs, Kamikaze Race header, FC Flex pipe, 2 1/4 Magnaflow catback
Added VF motor mounts...
183whp 161wtq
EvoZX3 is offline   Reply With Quote
Old 10-28-2005, 11:20 PM   #20
CFM Focus
2001 ZX3
  • STOCK SHORTBLOCK (boosted for 35k)
  • Vortech V-5 F-Trim Supercharger (20psi @ 7k)
  • PWR Air/Water Cooler
  • Ported Stock Head / Stock Valvetrain
  • Thicker Head Gasket (9.0:1 appx)
  • FC Adjustable Cam Gears
  • Crower Stage 2 Camshafts
  • Ported 2000 Intake
  • 65mm Throttle Body
  • Snow Performance Water/Methanol Injection
  • Stock Returnless Fuel System
  • Stock Fuel Pump / KB Boost-A-Pump
  • RC 750cc Injectors
  • Pectel Engine Management / CFM Tune
  • SVT Header w/ 2.5" Magnaflow Exhaust
  • Spec Stage 3 PLUS
  • Spec Billet Flywheel
  • Quaife Differential
CFM Focus is offline   Reply With Quote
Old 11-23-2005, 08:50 PM   #21
lourenco
Dyno # 03 in red is done at 11.5 psi, which has an okay tune. The car made 247fwhp.
Dyno # 14 in blue is done at about 26 psi of boost. The car made 361fwhp. All hp results were on 93 octane.
Anything above 26 psi did not net any good increase in hp since of possible misfire issue. I am hoping to resolve this strange issue, so I can run more boost and make more hp.
Car has port&polished head, stock camshafts, stock valve train, FR intake manifold, and other mods listed in my signature.
Here is a link to the 32 psi dyno run. video 1
Disconnecting the exhaust only added a few hp. Dyno not show for that run, but here is a video clip of how it sounded like. video2
One of the lower psi dynos. video 3
Turbo SVTF, GT3076R 60 trim, custom turbo Kit.
361 fwhp on 93 octane.
http://www.TurboFocusSvt.com
97 mustang cobra supercharged. 504rwhp.
07 BMW 335i 280RWHP.
lourenco is offline   Reply With Quote
Old 02-26-2006, 05:33 PM   #22
BUR_ZX3
[FJ] Addict
Default Re: Forced Induction Dyno's, times and Specs
FocusSport/VF Engineering Supercharger
FocusSport One-Off Non Production Extrude Honed Head
FocusSport 4-1 Header, Flex and Stealth Exhaust
91 Octane
FocusSport Presents Focus On The Beach 2008.
FocusSport / Exedy / Xios / H&R / 3dCarbon / NASA
Saturday, August 9, Santa Barbara
Sunday, August 10, Willow Springs
http://www.focusonthebeach.com
BUR_ZX3 is offline   Reply With Quote
Old 03-06-2006, 02:59 AM   #23
thefrush
I <3 dyno queens
Here's my JRSC info.
Mods listed on dynos.
If youre gonna die, die with your boots on
If youre gonna try, just stick around
Gonna cry, just move along
If youre gonna die, youre gonna die
thefrush is offline   Reply With Quote
Old 03-09-2006, 08:06 PM   #24
Discord
Procharger, 10lb pulley, FR head, Crane 3's, 2000 intake manifold, 42lb injectors, pro-m, kamikaze header, 2.5in flex, 3in from flex back, stock bottom end.
01 Focus - Turbine equipped
02 Lightning
86 Mustang SVO
86 Blazer 4x4
80 V8 Pinto
Things I have up on ebay
Discord is offline   Reply With Quote
Old 03-19-2006, 05:46 PM   #25
ZX3TUNING
Justin(EnigmaZ-V)
http://www.zx3tuning.com/images/pics/pw-j-dyno.jpg
04 ZX3 Zetec
PW base kit
FC TB
FC 4-2-1 race header
FC 2.5" Flex
MBRP SVT 2.5" exhaust
ZX3tuning Prototype "RACE" Cams
Kent cam gears
before and after mild retune.... 250fwhp and 208lb/ft..... stock head&block and no boost upgrades!
Power in Style.... ZX3Tuning
Part of Conglomerate Motorwerks!
Mitch A.
ZX3TUNING is offline   Reply With Quote
