Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > Forced Induction & Nitrous
Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide
Old 06-30-2006, 09:25 PM   #1
CFM Focus
Default Are you using factory SVT intake manifold with forced induction???
If you're boosting with the stock SVT intake manifold (ProCharger, Vortech, Turbo) then you might be in for a big and costly surprise if you don't make one of the following changes soon:
1. Disconnect DSI toggle cable
2. Program ECU to run either the short runners OR long runners ALL THE TIME!
Failure to do either will cost you at the least a valve if not a valve and a piston. Unfortunately, one of our customers became a victim after only a couple of weeks of FI. You have been warned!
CFM Focus is offline   Reply With Quote
Old 06-30-2006, 09:26 PM   #2
CFM Focus
Default Re: Are you using factory SVT intake manifold with forced induction???
Maybe this should get added to the FI sticky?
Old 06-30-2006, 09:50 PM   #3
COSDEVSVT
Yep.
There is a internal seal that can brittle and break off and get sucked into an intake runner ... eventually it will find it's way into the chamber.
We had a customer that this happened to as well. A piece broke off and was residing in his intake runner while he was NA. When he installed the PW blower, the boost forced it into the chamber.
'04 PW (#1) Competition Orange SVT 5-door Euro
COSDEVSVT is offline   Reply With Quote
Old 06-30-2006, 09:55 PM   #4
CFM Focus
Originally Posted by COSDEVSVT
We had an customer that this happen to as well. A piece broke off and was residing in his intake runner while he was NA. When he installed the PW blower, the boost forced it into the chamber.
Wow, I didn't know they would break while NA. That is really bad!
Old 06-30-2006, 10:03 PM   #5
COSDEVSVT
I'm guessing a poor choice of material to begin with ... must not age well.
Plastic and engines/underhood environment really don't mix well for the long term ...
Old 07-01-2006, 01:06 AM   #6
ArmyFocus
So in other words I will need to disable to the DSI clip by removing the cable coming from the IMRC? What effects will this have on performance, if at all? Also, is anybody looking into a way to fix this issue?
Jason
2006 Dodge Ram SLT 4x4 Quad cab. Custom exhaust, Alpine and JL Audio sound system
Old: 2002 ProCharged SVTF
2000 Dodge Dakota
ArmyFocus is offline   Reply With Quote
Old 07-01-2006, 09:22 AM   #7
CFM Focus
Jason
The correct way would be through programming the ECU to run EITHER the short OR long runners ALL the time. That means no switching AT ALL. Using the short runners will give you higher rpm power and long runners will give you better torque down low.
We were thinking of splitting the manifolds in half and welding the plastic ring to the main body so it will not come loose but know that COSDEVSVT mentioned that they are breaking even in NA applications then we might have to think of something different. If the plastic is becoming brittle then it probably won't weld very well. We might have to make some billet replacements that will press on much tighter and will not break or distort under boost.
Old 07-01-2006, 10:43 AM   #8
orangeZXT
sweet idea can u make the whole manifold, maybe make the runners i bit bigger or some improvements to it?
[FJ]
check out my new project hit ALT + F4 to view the pics
-There is a fine line between "HOBBY" and MENTAL ILLNESS"-
[FJ] "more psi than your tires"[FJ]
orangeZXT is offline   Reply With Quote
Old 07-01-2006, 10:57 AM   #9
ArmyFocus
can I program the runners via the ECU using my Predator?
Jason
2000 Dodge Dakota
Old 07-01-2006, 02:01 PM   #10
CFM Focus
We have looked and are still looking into possibly making a manifold but so far the quotes have been too high. The SVT manifold isn't too bad if we can get this issue solved.
Old 07-01-2006, 02:03 PM   #11
CFM Focus
Jason
I doubt the pre-programmed Predator has that feature. If not, it would have to be done via a custom tune. If we end up doing the ProCharger install for you it will be tuned with SCT and we'll be able to take care of that.
Old 07-01-2006, 02:12 PM   #12
dimm
Thanks guys....you just made me scared as hell to drive my freakin car....I appreciate that.....
I'm only N/A too.....
So the piece was residing in the heads intake runner....great.....
Sure you can go real fast in a straight line but can you turn without hitting your brakes?
dimm is offline   Reply With Quote
Old 07-01-2006, 02:35 PM   #13
CFM Focus
We will try to have a fix for this ASAP.
Old 07-01-2006, 04:12 PM   #14
Ray
Driver > Car
You've gotta be freakin' kidding me. Maybe make a mid length intake runner (aftermarket)
oi.
adding to the references thread.
Cable Ties. Is there anything they can't fix? Driver > Car - in memory of GaryK
Roadtrippin.org | CART
Ray is offline   Reply With Quote
Old 07-01-2006, 06:12 PM   #15
MEANSVT
dang this sucks now i have to worry about this when i drive.
MEANSVT is offline   Reply With Quote
Old 07-01-2006, 10:37 PM   #16
tracksidelogistics
Yep.
After the fact how did you determine it happened while NA?
tracksidelogistics is offline   Reply With Quote
Old 07-02-2006, 12:09 AM   #17
CFM Focus
Because the PW kit replaces the factory intake manifold which is a big plus.
Old 07-02-2006, 09:58 AM   #18
tracksidelogistics
So while NA the the seal came off the stock intake and went into the head. Then when FI the seal was forced further in and caused damage?
Old 07-02-2006, 10:06 AM   #19
lourenco
Originally posted by 1turbofocus
As for the SVT Intake i did a write up on it back in late 2002 about the inner white/green seals coming off the end of each of the runners all you have to do is remove the TB and fish in there and pop them loose and take them out , after doing so i saw to power loss on the dyno from removing them and it is a quick fix to cure the problem
It is very common for them to come loose but VERY rare they hurt the engine
Tom
Here is what Tom said.
Turbo SVTF, GT3076R 60 trim, custom turbo Kit.
361 fwhp on 93 octane.
http://www.TurboFocusSvt.com
97 mustang cobra supercharged. 504rwhp.
07 BMW 335i 280RWHP.
lourenco is offline   Reply With Quote
Old 07-02-2006, 10:11 AM   #20
COSDEVSVT
It wasn't the entire seal (just a piece of it), but yes.
It was discovered when the customer took a really close look into his factory SVT manifold and found the piece of the seal missing.
You need to be a contortionist to be able to easily look down the head intake runners with the engine in the car.
Old 07-02-2006, 10:25 AM   #21
ArmyFocus
Awesome, I'll let you take care of it for me then.
Jason
2000 Dodge Dakota
Old 07-02-2006, 11:28 AM   #22
CatMostFeared
mamma says SVT focus is the devil
2000 Turbo WRC ZX3
2002 PowerWorks SVT
MassiveSpeedSystem
www.focusxtreme.com
CatMostFeared is offline   Reply With Quote
Old 07-02-2006, 03:33 PM   #23
ArmyFocus
yeah, but that's okay, 'cause me and Lucifer are buddies. (j/k of course)
Jason
2000 Dodge Dakota
