Tire Rack
Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > Forced Induction & Nitrous
Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide
Old 06-27-2008, 11:57 AM   #1
OmniFocus
Default PWSC Air-to-water order... critical?
The default setup for the PWSC air-to-water is:
Intercooler -> Tank -> LTR -> Pump -> Intercooler
Is there any ill effects to changing it to:
Intercooler -> LTR -> Tank -> Pump -> Intercooler
In my mind, it shouldn't make a difference, but I could be overlooking something.
I have a temperature probe installed immediately after the intercooler, so any ill effects SHOULD be obvious, I suppose.
Old 06-27-2008, 11:59 AM   #2
Ray
Driver > Car
Default Re: PWSC Air-to-water order... critical?
Ltr = ?
Cable Ties. Is there anything they can't fix? Driver > Car - in memory of GaryK
Roadtrippin.org | CART
Ray is offline   Reply With Quote
Old 06-27-2008, 12:00 PM   #3
OmniFocus
Sorry... Low Temperature Radiator.... the one in the front.
Old 06-27-2008, 12:04 PM   #4
Ray
Driver > Car
Okay. That should be fine. Just make sure the pump is below the tank, so it doesn't run dry.
On my SVT it went Tank (which was also the intercooler) - pump - LTR 1, LTR2 - Intercooler.
When i had the PWR barrel cooler it was
Intercooler --> Tank --> pump --> LTR --> intercooler.
I think that having the LTR to the intercooler direct is a good thing as there is the coolest possible water going to the intercooler before it's heated.
Old 06-27-2008, 12:07 PM   #5
OmniFocus
I'm planning for the future when my original tank eventually cracks and I need a nice aftermarket solution.... and I'll have tons of room on the driver side.
Old 06-27-2008, 12:07 PM   #6
brads03zx3
I almost wrote this backwards...if what you wrote is correct, your routing will improve the efficiency of the system. You want to cool the water when it is the hottest, which means you want the water to go directly from the intercooler to the LTR. There is ill-effect storing hot water in the tank.
I have had this same discussion with a fellow racer. Their Z06 oil cooler was cooling the oil from the oil pan rather than straight from the block. They were planning on changing the order.
Mountain Tested----'03 zetec
DuraMonster---'03 duratec
Old 06-28-2008, 11:52 PM   #7
DigitalGT
IMHO, you want the water to leave the LTR and proceed directly to the intercooler core. The more time the "chilled water" spends under the hood in the degas tank, the more heat it is soaking up and the warmer the IATs will be.
If I was going to put the degas tank on the drivers side, I would swap the hoses on the pump so the original flow order remains the same; intercooler, tank, pump, ltr, intercooler.
'03 Pitch Black SVT 5 Door -- Audiophile, HID, Moonroof, Cold Weather Package, EAP Recaro interior, HID Foglights, and lots of motorwork.
'96 Burgandy Toyota Avalon XLS -- The Beater
'05 Carbon Fiber Buell Lightning XB12S -- The Boy
'07 Sex Red Ducati Sport Classic 1000S -- The Girl
DigitalGT is offline   Reply With Quote
Old 06-29-2008, 06:58 PM   #8
CaysE
[FJ] This is worse than when the raccoon got caught in the copier!
My question is... would you be decreasing the efficiency of the radiator by placing it before the degas tank? Any bubbles passing through the radiator is going to decrease its cooling capability, I imagine.
The radiator immediately before the intercooler sounds like the best option for getting the coolest water.
2008 Cannondale F4 ··· Hi-brite · no mods (yet)
2003 Vermilion Red SVTf ··· hehehehehehe
strictly/focused
"It would take a miracle to make the entire Focus community get along. FF vs FJ, F-P vs FS, tuner vs tuner, racer vs ricer. What can you do?"
CaysE is offline   Reply With Quote
Old 06-30-2008, 08:16 AM   #9
DigitalGT
You're correct. The more air in the radiator and intercooler core, the less heat transfer will occur. It is advantaeous to have the degas tank up as high as possible but the packaging constraints of the Focus engine bay make that difficult. If anything I would place the degas tank before the radiator just like it is now and continue to top it off.
