Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > Forced Induction & Nitrous
Forced Induction & Nitrous Talk about any form of Forced Induction (Turbos & Superchargers) and Nitrous Oxide
Old 10-23-2009, 02:07 PM   #1 (permalink)
pzev04boy's Avatar
Default Powerworks bypass valve vac line mod!!!
Just an fyi. I have found on a pw car that re-routing the line for the powerworks bypass valve is very helpful in a few ways.
I have had a feeling that at times the bypass valve can stick open a bit causing lower boost & this also allows already compressed /heated up air to be recirculated through the blower one more time causing higher IAT's. This may explain why a lot of powerworks owners notice their car will have it's moments where it makes less boost and feels slower.
There is also another Issue I just encountered with a local who has a built motor and a custom 2.5 pulley. He was making only about 14 psi and noticed the boost would not stay consistant. We did the mod I am about to describe and the car picked up 2 psi boost and dropped about 15 degrees of IAT's. He needs to get back on the dyno now.
The solution & my recomendation to all PW owners is to pull the vacuum line off the Bypass valve & plug it, get a tee and tap into where the fuel pressure sensor hose is on the upper plenum and run a new hose from there to the bypass valve. Use zip ties or clamps to hold the hose on.
Now with both a source of boost and vacuum to the valve it will still function as a bypass at idle or cruise, but will also have the boost pressure to hold the valve shut under boost.
I have not tried this on a stock boost car yet, but I see no issues only potential performance gains. This also should help prevent the bypass valve from sticking open like has happend to some.
I feel this is especially important for big boost cars as there is a spring in the bypass valve and it wasn't calibrated to hold much pressure. It's a very light spring in fact.
Try at your own risk, but this should be a worthwhile mod
If you end up with more boost you need to make sure it's safe.
03 Zetec ATX E&S TURBO SYSTEMS powered sedan
00 Mustang Gt - Built motor - Soon to be Single turbo
07 Ninja 500R Building 640cc race motor.
pzev04boy is online now
Old 10-23-2009, 03:38 PM   #2 (permalink)
dhardison's Avatar
Default Re: Powerworks bypass valve vac line mod!!!
Very interesting! So the thought is the 'default' PWSC vacuum line connection between the bypass valve and lower 'intake tube' doesn't reduce the vacuum enough to fully close the bypass valve, even under boost conditions?
If so, it makes sense.
'00 ZX3 ITE/STU SCCA race car (PWSC'd)
dhardison is offline
Old 10-23-2009, 04:25 PM   #3 (permalink)
pzev04boy's Avatar
No. It doesn't use vacuum to close it. It uses vaccum to open it. But now that you mention it I'll bet there is a little bit of vavcuum in the neck itself when the car is under boost, which would futher support the need for this mod. The inlet to the rotors of the blower are bigger than the throttle body opening so when it is drawing air in it's almost for sure a slight vacuum in there.
Here is the scenario. The vaccum line that goes to the bypass valve goes to the inlet/neck of the PW housing. It never sees boost in the neck, only vacuum. The bypass valve has a spring and a diaphram in it and it gets opened by vacuum at idle & cruise. Then it relys on just a spring inside of it to keep it closed under part throttle & boost.
The re-routing of the hoses to put boost to it will give it a little extra to keep it shut under boost.
Old 10-25-2009, 05:16 AM   #4 (permalink)
Sounds intresting, where it currently is it only sees about 10psi vac. Moving the pipe to the plennum means it will see vac and boost like you say.
My only question is can the diaphram handle ~15psi of boost pressure?
Trev
2.0 Powerworks
gti_uk is offline
Old 10-25-2009, 03:33 PM   #5 (permalink)
pzev04boy's Avatar
Trev
I don't see a problem with it. The diaphram is made of a pretty tough material. Seems to be working just fine.
If you did have a diaprham failure it won't blow the engine up as it doesn't control boost. You just would have no bypass valve at idle so the car would have a poor idle.
Old 10-25-2009, 09:29 PM   #6 (permalink)
DigitalGT's Avatar
Trev
It should handle 15 psi of boost no problem. It handles 30 in/hg of vacuum no problem which is equal to 15 psi of boost.......just moving the the opposite direction.
'03 Pitch Black SVT 5 Door -- Stroked, blown, ported and massaged. Still not fast enough.
'07 Liquid Platinum Metallic Mazda CX-7 Sport -- Turbocharged SUVs FTW!
'96 Burgandy Toyota Avalon XLS -- Daily commuter/beater
'05 Carbon Fiber Buell Lightning XB12S -- Loud fans save lives.
'09 Villain Black Buell 1125CR -- American innovation....Austrian muscle.
'07 Red Ducati Sport Classic 1000S -- Sexy body....sadistic ergos.
DigitalGT is offline
Old 10-26-2009, 10:32 PM   #7 (permalink)
This is very interesting. I am new to the PW, and the slight fluctuation in boost is something I noticed right away. At times I can have only 7.5 pounds of boost while others hit consistent 9 pounds. I may have to try this out over the weekend.
Black Aria...#1211: 2002 SVTF
Jasmine...#1062: 2004 SVTF Euro
Rain...1990 Ford Escort Wagon
"Dear Diary...Jackpot!" Giggity Giggity Goo!
SVTADAM is offline
Old 10-26-2009, 11:13 PM   #8 (permalink)
I've done something similar to this. Reason I did it though is because I pulled out all of the vacuum line that came with the kit when I removed the DPFE sensor and other related sensors off of the firewall. I just ran a line from the vacuum "tree" on the lower portion of the blower intake to the bypass valve. Seems to function just fine except I haven't really noticed any performance increase.... just less clutter
Although I've never once had any issue with my kit. Mine was one of the first and from the sounds of it I've been pretty lucky having ZERO issues.
Time Attack Unlimited FWD Class #26
SCCA E-Modified Class #26
Too many mods to list... Here is a link to my build thread http://forums.focaljet.com/team-rigz...6k-no-way.html
Terrible1 is offline
Old 10-27-2009, 12:47 AM   #9 (permalink)
pzev04boy's Avatar
If you are running it from the lower part of the blower you are not getting boost to the bypass valve. Anything from neck of the blower does not see boost.
And just to confirm, we hooked a vacuum gauge to the inlet neck of the blower and it does have some vacuum in the neck at wide open throttle. Almost 5 hg. Probably not an issue with stock boost levels, but you can imagine that it is going to further allow the bypass valve to leak during boost. I'll bet the spring in the bypass valve begins to open around 8-10 hg. Especially with boost helping push the butterfly open from the other side.
Old 10-27-2009, 01:16 AM   #10 (permalink)
So are you saying I've done this incorrectly???
Old 10-27-2009, 03:27 AM   #11 (permalink)
BOWERSdaAZIAN's Avatar
subscribed. Im kinda intrigued to see if this will be worthwhile for me to do.
USAF Electronic Warfare Motto(s):
"Jam Harder, Penetrate Deeper, Dispense Longer"
"In God we Trust... All Others we Monitor, Jam or Deceive"
Proud owner of former FocusSport/JCM racing Powerworks SVT.
BOWERSdaAZIAN is online now
Old 10-27-2009, 10:42 AM   #12 (permalink)
x2 here. Very interesting! Looks like a little Thanksgiving weekend project on the floor of the garage. Anyone post a schematic for this? Just a thought as I'm sitting in my office trying to visualize this, scratching my head.
--Scott
MOVE: PWSC w/ esslinger gears from McNews w/Tune, J&S Safeguard, FS wires, CFM throttle body, VF lower mount from FS, SVT header, TruBendz 2.5" flex/exhaust Groove: SVT shocks/struts/Vogtland springs, Eibach antirolls, Ecsta asx Stop: Hawks Look: Yellow fogs w/ Nokyas & I.F. Mod, Euro upper/lower grille, blk headlight paint, sedan tail mod, Speedhuts, Mach lip from Tousley (installed by Brian Lokay).
greentengu is offline
Old 10-27-2009, 11:49 AM   #13 (permalink)
The reason for the pre-blower location is because it is a clean source of vacuum for the BBV ... not much chance of re-circulated oily air to find its way into the BBV while it always experiences vacuum.
The post blower location will be a dirtier air source. Not saying it won't work, but keep any eye on it so that that you aren't blowing oil (mist will pool) into the BBV and causing other problems.
'04 PW (#1) Competition Orange SVT 5-door Euro
Wanna buy a Focus harness bar? (<- click)
COSDEVSVT is offline
Old 10-27-2009, 12:47 PM   #14 (permalink)
Black EAPs = Love.
ZX3TUNING's Avatar
dammit!
that means another oil catch can for this car?
Power in Style.... ZX3Tuning
Part of Conglomerate Motorwerks!
Mitch A.
ZX3TUNING is offline
Old 10-27-2009, 02:19 PM   #15 (permalink)
pzev04boy's Avatar
You have it pretty much how powerworks has you hook it up.
Old 10-27-2009, 02:22 PM   #16 (permalink)
pzev04boy's Avatar
Good point. I know some blow of valves come with filters and it may be something to add on to this. Although I doubt oil is going to make it into the bypass valve seeing as the teflon line to the boost gauge is see thru and I have never seen any oil in it. I'm guessing that under boost if there is any oil in the system it will go with the air flow and since air doesn't flow through the bypass valve it shouldn't get any oil in it.
Old 10-27-2009, 09:05 PM   #17 (permalink)
Not Special Enough
TXFO's Avatar
bypass valves Vs. supercharged cars. the oldest boost battle ever.
German and Italian car tech.
Fixin to adjust the knob to HIGH POWERED.
black belt at the drunk as balls dojo.
Bloodshot eyes, metal skin, serpent's tongue, dagger claws, dragon wings, crooked horns. KING!
TXFO is offline
Old 10-27-2009, 09:48 PM   #18 (permalink)
DigitalGT's Avatar
I think that if I were going to try this hose reroute that I would simply tee off the boost gauge port next to the IAC valve and run the bypass valve hose to that. Positive boost pressure at WOT along with manifold vacuum at low load/closed throttle. Just seems simpler to me than teeing the fuel pulse damper hose......which if I'm not mistaken, comes from the three way vacuum distribution hose connected to the intake neck of the blower assembly doesn't it?......which means it does not see boost pressure...... Hmmm.
I also just don't see the point of doing it in the first place. It's very hard to blow open a butterfly style valve that seals properly.....even one held shut with light spring pressure. Glad it worked for the OP. I can only assume that it wasn't sealing perfectly if the hose reroute caused a boost increase.
Old 10-27-2009, 11:39 PM   #19 (permalink)
pzev04boy's Avatar
[QUOTE=DigitalGT;7134460 which if I'm not mistaken, comes from the three way vacuum distribution hose connected to the intake neck of the blower assembly doesn't it?. [/QUOTE]
No. There are 2 nipples on the upper part of the blower. 1 comes capped from powerworks and is for use with a boost gauge. The other goes to the fuel pressure sensor. You could tee into either of those actually.
It's a known issue on 03/04 cobras so they have been doing this for a long time and getting gains from it.
Old 10-28-2009, 12:51 AM   #20 (permalink)
DigitalGT's Avatar
Ahhh yes yes yes. I was wrong. I thought you were talking about the pulse damper in the middle of the fuel rail not the pressure sender on the end of it. Went back and re read your post and see that's actually what you said. My brain saw otherwise. You were correct at the onset.....though my previous post, from a "seen" vacuum/pressure point of view is just as accurate as yours.
Carry on maestro.
Old 10-28-2009, 05:26 PM   #21 (permalink)
I am seeing that this thought could also be adapted to JRSC's as well. Curious to see how this works because I swear some times I see a little less boost and this could certainly be a reason. I am a bit leary of blowing boost in behind the diaphram on the by-pass though. I blew a hole in one already and changing that part out turn out to be a small project, lol. Not to mention the vac leak caused by this had me pinging
..:: sleestak ::..
Keepin' the Rubber Side Down
"Our mother of blessed accelleration, don't fail us now" -- Elwood Blues
sleestak is offline
Old 10-28-2009, 08:17 PM   #22 (permalink)
I <3 UC^3
When you look at BPV's and BOV's on turbo cars they are setup to see both vacuum and boost to operate correctly. I don't see why this valve should be any different.
Tuned By: Bristol Dyno
hEaT is offline
Old 10-28-2009, 08:20 PM   #23 (permalink)
OmniFocus's Avatar
Well, it kind of depends how they assembled the diaphragm. If it wasn't engineered to see positive and negative pressures, I wouldn't do it. For all we know, there could be a sharp protrusion that the rubber contacts with positive pressure that'll wear through with time.
The only way to know for sure is to ask the entity who designed it.
Vacuum Vulture Racing: The masters of ape latexing.
OmniFocus is offline
Old 10-28-2009, 10:02 PM   #24 (permalink)
dhardison's Avatar
Or take one apart. I have my old bypass valve that I can open up if anyone's interested.
Old 10-28-2009, 10:20 PM   #25 (permalink)
I <3 UC^3
Good point.
Please do!
hEaT is offline
