Capaldi Racing
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    Dec 2002
    120
    Default transmission Oil drain and fill plugs?
    Does any one know the location of the oil fill and drain plugs for the SVT tranny. I see a black plug with a hex wrench hole in it on the lower bumper side of the tranny, can any one confirm if this is the drain plug? I do not however see any filler plug on that side except for on the top of the tranny by the battery tray there are two bolts/plugs right next to each other. One is raised and the other is flush with the tranny casing. Are one of these the filler plugs. They seem kind of high. How do you check level of the oil on this tranny. I am used to the oil filler hole also being the oil level check hole like on the MTX-75 tranny where you unbolt it and stick you finger in the hole to see if there is oil just below the plug. If any one has drained and filled their tranny before your help would be appreciated.
    Thanks
  2. #2
    Nov 2003
    Cleveland
    2,379
    Default Re: transmission Oil drain and fill plugs?
    The drain is on the right side of transmission by the dog bone transmission mount. The fill is on the front, very low on the transmission.
  3. #3
    Dec 2002
    120
    Quote Originally Posted by BadIdea
    Thanks for the help. Any idea of the torque specs for these plugs?
  4. #4
    Feb 2003
    Port Moody
    225
  5. #5
    Aug 2004
    604 baby
    603
    how much fluid is needed to fill it back up?
  6. #6
    Nov 2006
    Peoria Heights, IL
    46
    Can someone tell me the type of oil recomended for the 04svtf trans. and amount. I don't have an owner's man. Thanks.
  7. #7
    Ninjas>Pirates error54's Avatar
    Jul 2006
    Waaay South Georgia/N. Fl
    603
    ^^^haha that's sure to start a debate^^^
    I'm about to use royal purple for mine. I hear good things about it but pretty much everyone has their own opinion.
    Quote Originally Posted by The RZA
    Her sign is Virgo, she's from Chicago, she likes my slow flow but loves my turbo
    '04 SVT:Turbosmart, Tial, Borla, Treadstone, Clutchmasters, Ford Racing, Sparco, Steeda, Eibach and Garrett.
  8. #8
    Senior TEAM Member oskarSVTee's Avatar
    Feb 2005
    Somewhere in the Desert
    2,558
    Quote Originally Posted by Eagle60
    2.1 quarts. I'm sure you'll get lots of recommendations as to brand and type. Personally I'm using the Redline Synthetic D4 ATF which is also used by a lot of locals in both the regular and SVT manual transmissions.
    Ron
    2004 SVT Focus - 5 Door in Sonic Blue with European Appearance Package - 1 of only 48 made
    Build number: 592 of 1079 - Build date: 1/28/04 - Arrived at Dealer: 2/13/04 - Drove it home: 2/14/04
    Mods: Steeda STS, Screamin' Demon Coil and Live Wires, FS Front Strut Bar, VF Rear Motor Mount, Euro Grille, Clear Bumper Lights, LED Tails with the MIKE Mod, FC Shorty Antenna, Hoen H10 All Weather Foglight Bulbs, FS Cool-Flo Intake, FS SCT XCalibrator2, FC 65mm TB, CFM Hi-Flo Cat and FRPP Multimatic Suspension
  9. #9
    I change diapers now focusownerskid's Avatar
    Aug 2000
    Lincoln Park, MI
    13,949
    I'd reco Redline D4( www.focussport.com ) or GM/Pennzoil Syncomesh w/ Ford friction modifier
    ///type dRew
    '99 Camaro / '02 Sunfire / '02 Jetta
  10. #10
    Jan 2007
    Denver, CO
    25
    Where is the dipstick to check current fluid level?
  11. #11
    Aug 2000
    Lincoln Park, MI
    13,949
    Quote Originally Posted by SVTF_170
    This isn't an ATX
    ///type dRew
  12. #12
    Jan 2007
    Denver, CO
    25
    So you can't check current fluid level? How do you know if its right? My STi had a tranny dipstick on its 6 speed.
  13. #13
    Jul 2003
    2,247
    Quote Originally Posted by focusownerskid
    This isn't an ATX
    ATX's arn't the only transmissions with dipsticks, my other getrag 5 speed has a dipstick. Ford went the cheap route and didn't give us one. You check it by removing the FILL plug and sticking your finger in. If you can feel fluid you are ok.
    Quote Originally Posted by Pappy
    ...This should be the new focus slogan "Focus - Gone horribly wrong after 2004"
    2003 Focus SVT Euro Package
    Get autocrossing with the SCCA - -- - My Autocross Page
  14. #14
    Aug 2004
    604 baby
    603
    anyone doing this make sure to open up the fill cap first before you drain out the fluid.
    Its not ford at fault its the german company who made it
  15. #15
    Jan 2007
    Denver, CO
    25
    Quote Originally Posted by Primaris
    Thank you
