FSWerks
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Feb 2005
    Colorado Springs, Colorado
    91
    Default Clutch master cylinder leaking
    The other day I noticed a wet spot on my floor mat drivers side, but the weather has been very dry here for a while. So I looked closer and discovered that fluid from the clutch master cylinder was leaking and running down the clutch pedal, and dropping onto the floor mat.
    I have about 83k miles on the car.
    So, my question is: What is the repair for this? Is there a rebuild kit for the master cylinder? Or, do we just replace the master cylinder with a new/rebuilt one?
    Thanks.
    2003 Orange Euro SVTF, JRSC + BBK, MBRP Cat-Back, H & R Coil-Over Kit , SS Brake Lines, VF Eng. Mounts, FocusSport Cool-Flo AIS, ...
    #2442/3985
  2. #2
    Revrent Houdini's Avatar
    Aug 2008
    At the Foot of the Cross in Rocklin CA
    6,097
    Default Re: Clutch master cylinder leaking
    Call steve . Just replace it its about 40 shipped to me in cali. He can give you the best deal...good luck.
    2012 Triumph Thruxton 900, Triumph Black, "Bianca" - For Fun/strees relief/Summer Ride
    1997 Ford Ranger 2WD Blue, Bare Bones, Brass Tacks - Work/Hunting/Winter ride
    2002 Ford Focus SVT Infra RED #4308 - NIkki - Sold 10/28, I'll miss ya old girl. *e-tear
    My blog...Working Man's hands. http://www.workingmanshands.blogspot.com/
  3. #3
    TEAM Member warmonger1583's Avatar
    Nov 2004
    S. Elgin, IL
    168
    i'm on my third one now... it sucks but its not too expensive to fix.
    2004 Black SVT EAP - Soon to be dedicated track and auto-x car
    2009 Dark Silver MINI Cooper S R56 - Daily Driver
  4. #4
    Feb 2006
    5
    Mine is leaking too. If I park the car at an incline, it leaks even more. That is cool to know that it can be replaced for roughly $40. My question is regarding the procedure...is it that hard to do that is better to take it to the dealer? Is there any procedure on how to do it yourself written up somewhere? Thanks!!!
  5. #5
    Nov 2004
    S. Elgin, IL
    168
    i dont have a write up for it but basically what you do it take off the lower dash panel off
    -Remove the two lines connecting to the master cylinder from the engine side of the fire wall
    -remove the pedal assembly from under the car
    -switch the master cylinders from the pedal assembly and reinstall
    -and then reinstall the lines and bleed the system
    very general write up but its been a while since i have done it but i hope it helps you a little bit.
  6. #6
    Feb 2002
    Wherever peculiar people congregate
    5,175
    The only real difficulties I found were the physical location, it pretty far up under the dash, and the stupid clutch in to start switch whose bracket is totally in the way.
    Oh and of course that switch is not shown in the ford manual.
    Quote Originally Posted by Chalz
    Obama doesn't have a birth certificate because he's a genetic experiment. They made him smart and good looking in a tube in a government research facility, and made him half-black to make him easier to relate to for all people. He's really just a bio-engineered Manchurian candidate.
  7. #7
    Feb 2005
    91
    Quote Originally Posted by warmonger1583
    Wow, that sucks! Maybe I should buy two.
    How many miles are on your car?
    #2442/3985
  8. #8
    Junior Member OrangeSVTguy's Avatar
    Nov 2006
    Elyria, OH
    69
    I did a temporary fix how-to here to not make your pedal slippery any more. I will be calling Steve up too here soon.
    [2004 SVT Focus 3dr Competition Orange]
    [#1329 of 1978]
  9. #9
    Feb 2002
    5,175
    Quote Originally Posted by OrangeSVTguy
    Hey thanks.
    Why didn't I think of that....
  10. #10
    Jul 2010
    Arlington,TX
    202
    Quote Originally Posted by warmonger1583 View Post
    Any tricks for removing the two lines on the Firewall side? I see the two block lines with green tips on them. It appears maybe there is a release clip of some type and then they pull off?
    I don't understand why they can't make the same as the brake one- push in white clip and it pulls right off
  11. #11
    Dec 2006
    houston (katy), tx
    1,112
    ya I wish I knew the name of the tool but get a pointed tool that does a 90 degree bend at the end so you can undo the c-clips.
    also if you can pre-load the CMC or it will be a LOT of bleeding after.
    I just got pissed off and bent the stupid clutch sensor out of the way lol
    2004 EAP SVTF zx3- magnaflow exhaust, cfm rear mount, custom short ram intake and heat shield, steeda springs
  12. #12
    Jul 2010
    Arlington,TX
    202
    Quote Originally Posted by snake eyes View Post
    Thanks for the reply!
    Ahh a 90 degree 'pick' that would be the ticket. I assume by pre-load you mean getting fluid in it beforehand? Any tricks to that?
  13. #13
    Dec 2006
    houston (katy), tx
    1,112
    sorry can't as I didn't do it. took me about 2.5 hours to do it the one time that I have. Prob could do it in about 1.5 hours next time I need to.
    other tricks: (that I can remember)
    -u-joints are your friends
    -there is no good way to reach the CMC, do some stretching before hand.
    - if you find a way to get the sensor out of the way without bending let me know lol
  14. #14
    Jan 2010
    MN
    346
    I don't believe you could do it in 1.5 hours. It was a ridiculously ****ty procedure. especially bleeding.
  15. #15
    Dec 2006
    houston (katy), tx
    1,112
    let it gravity bleed first, takes a lot of time out of the process.
