Hello audiophiles and thumpers alike!
For those that want more features, better sound quality, better connectability, or just better looks, an aftermarket stereo is a must!
However, the Focus headunit, 1-disc, 6-disc, or Blaupunkt, are all 1 1/2 DIN in size. Almost every aftermarket stereo is a 1 DIN sized unit. For those that do not know, I am refferring to the vertical measurement of the face of the units. Width is standard amongst all DIN sized units, be it 1, 1 1/2, or 2 DIN.
Here we will be looking at three of the kits available, from Scosche, Metra, and American International. The Metra 995200 recently came out, and is not reviewed here. The choice is up to you based on your needs, and often based on where you get your new stereo from..
(Note: I bought all three units myself, so any bias towards one unit or another is based solely on the merits of the kit, not any manufacturer pressure)
Focus Stereo Installation Kits:
First up is the kit from Scosche. Unique amongst the three reviewed here, as it mounts the headunit at the bottom of the Focus stereo opening with a pocket above the headunit. This, in my opinion is the ideal location for a headunit, as you'll get less glare on the screen and it puts the controls closer to your hand, especially if you have a manual transmission. The pocket is not deep enough to securely hold a CD case, but this can be an advantage, as if you drop something small in the pocket, it's easier to get out. This kit utilizes the stereo surround that comes with your head unit, but with my Kenwood KDC-X979, this caused the front of the unit to protrude quite a bit from the dashboard. Appearance is good, with a textured finish, but construction is not perfect. Two clips, top and bottom, attach the unit to the dash bezel, but my unit does not attach securely in the upper left corner and flexes when you press on it, and slight warps in the plastic ruin the straight lines of the kit. It does not make for a very professional installation.
The Scosche Kit (I'm holding it upside-down so you can see the depth of the pocket):
Second is the Metra kit. Construction is top notch with this kit, and the plastic actually feels sturdier than the Scosche. Large clips on the side keep it secure in the dash bezel, but with no clips on top, it does flex ever so slightly when pressed. It's pocket is very deep, and securely holds two CD jewel boxes with clips in the back to keep them centered and separate. Very nice. A unique feature of this kit is the rear mounting bracket, that when attached to the rear of your head unit, allows the headunit to be supported and secured to the same metal bracket that the factory stereo is. Major points for this, and it makes up for the slight flex in the face, because your stereo is mounted rock solid. This kit does away with the stereo faceplate ring and makes for a very smooth attractive install.
The Metra Kit:
Last is the American Internatial kit. Construction of this piece is very good. Two clips on top and two on the bottom attach the unit very securely to the dash bezel. It has a slightly textured finish and it's unique feature is that it includes faceplates that allow you to use an older, two-knob design stereo without ruining the smooth lines of your dash. Slight bending of the plastic is visible between the kit and the face, but it's not major. Another small drawback is that the head unit surround presses in and is held in by four small posts. It does not snap-in unfortuneately, however mine has not fallen off or loosened yet. It's pocket is identical in size to the Scosche kit.
The American International Kit:
All three kits have a textured finish, which does not match the smooth Focus dashboard Bezel. All three kits do not fit flush with the dash, with the American International kit protruding the least. Some time with a bit of sandpaper will cure the first issue, however, unless you plan on fiberglassing the kit into the dash permanently, you'll just have to live with it sticking out a bit. The minoe flexing of these kits can be cured with a modest amount of fabrication if you feel so inclined. The Scosche kits and Metra kits are widely available on the internet, but I only found the American International kit at Crutchfield.
Overall, it's a toss-up between the Metra and American International kits, with the Scosche being considered only if the stereos position in the dash is all-important to you.
Options are always good, and I help this helps you make an informed choice.
Good Luck!
-Seth
LinkBack URL
About LinkBacks
For now, do you have pix and some opinions? Post 'em up! Any info helps those who are hitting the stores now and need some help!
