| ICE (In Car Entertainment) Audio, Security, DVD, and video game installs.
Sponsored by: Boston Acoustics |
#1 |
i have installed my dvd player but it wont play dvds i have used a bypass but i think i may have done something wrong can anyone help
#2 |
ground ebrake wire...or depends on which model you got, requires relay, or use toggle switch..
MECP certified mobile installer 2000 Kona Dirt.www.cardomain.com/id/focusonfocus Future Mod >>> GET RID OF AUTO TRANS!! |
#3 |
What dvd player?
#4 |
ya knowing what system you're trying to by-pass will help a lot...if you have an AVIC-D3 all you have to do is move the yellow/black tracer wire into another spot.
#5 |
Jensen VM9312, see i hooked up the wire for the ebrake to toggle switch, grounded it and gave it a power but there is another wire that is called reverse wire, now in the diagram it shows these two wires, one as a negative and one as a positive so i started to think that they both need to be connected to something and if that is the case where do i connect the reverse wire
#6 |
reverse wire is for when you put "reverse gear", that is for when you have reverse camera attached..
if you do not have camera, then leave that wire..
#7 |
without using any toggle switch, ground wire staright to the ground wire..
if this is not work, try this.. simple googling gave me this.. heres the trick to the parking brake bypass procedure: 1. Go into Am/Fm mode 2. Hit "setup" on the remote control 3. Enter 543210 on the remote, listening for the beep for each number entered 4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen 5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen. 6. Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
#8 |
do i actually need to connect the ebrake wire from the dvd player to the actual ebrake wire in the car then do the bypass
#9 |
nevermind dude focusonfocus i love man that totally worked thank you so much
#10 | |
Resident Wheel-Whore
Does this work on all Jenson's? I'll have to try that on mine. I have the switch, and is a major PITA to always flip that on and off.
~~Boost Crew supports single mothers~~ _/ ResidentWheel-Whore\_ 'Bone Stock'2002 TwilightBlue ZX3-Neglect has led to a nasty whine from under tha rusty hood. (CHROMED) STS Prep'd 2001 Pitch Black 5spd Wagon-(666-STFU) "Your mom has an SVT bumper..."-Pappy, 2008 --No longer allowed access to FJ 'For Sale' Forums. Has a uncontrollable urge to buy stuff I don't need-- |
#11 | |
ive only ever grounded it all together when i wired and soldered all the wires. |
| Thread Tools | |
| Display Modes | |
