Originally Posted by danager
Actuators are available, for universal applications. The shop installing the security system will have them, at about $10-$15 plus labour (each).
As mentioned above, look at additional prevention, as the alarm will only alert you to a break in (prevent in some cases).
I will also say, the alarm is only as good as the install. You are looking at a comprehensive list of components, so research the install bay as well.
For a couple components you have listed:
Glass sensor - these are great if you are concerned a items could be removed from the vehicle through the window opening. Otherwise, a door will need to be opened, so this sensor wouldn't be needed. You mentioned the van has little glass. They use a microphone, and when mounted up front, could be less effective against rear glass intrusion. They also have a tendency to false alarm in a work vehicle. This is due to the lack of insulation, and the amount of product being carried. As heat/cold cause items to expand and contract, the microphone can pick up on that.
You also have the digital tilt/motion sensor listed - these are most often used to prevent tow away, or wheel theft. I have not found this to be a concern with a work vehicle.
A battery back-up is a good idea, but let me introduce a twist... Look into the DEI 515R. It is a siren, with a built in battery. This siren is connected to the power/ground, and alarm outputs. Once triggered by the alarm, or power/ground (either) loss, the siren triggers. It has a 30 minute power supply, and can only be dissarmed by the alarm, or the use of a barrell key. I had to remove one of these, where the owner didn't have the key, and what a pain! We wrapped it in dynamat, and threw it into a garbage can and put the lid on, but it still drove us crazy.
Last, I would recommend an additional shock sensor for the rear of the vehicle. This "may" not be needed. I like the additional sensor, so the one that comes with the alarm doesn't have to be set too sensative, just to pick up rear impact.
What I would look at installing:
Viper 1002 - Security system
4 TL1006 - door lock actuators
DEI 515R - battery back-up siren
DEI 504D - shock sensor
Ask:
Where will the various components me mounted? The controll module should not be easily accessible, in your van, I would mount this by the headlight switch. The LED should be visable from both side windows, and perhaps from the rear. Above the radio is always good.
How will the connections be made? All connections should be soldered.
How will the wiring be routed? All wiring should be routed along with factory wiring. This makes the wiring less conspicuous. The wiring running to the rear for the locks, and possible shock sensor, can be difficult to run this way. I would insist on it, and in a work vehicle, sometime you need to remove equipment...
Hope this helps, and good luck!
Can I use the universal actuators on the sliding door and rear barn door? Maybe a DEI 524K kit?
Yes I agree with additional prevention. I have installed steel mesh over the rear barn doors and installed a steel mesh wall located behind the 2 front seats.
Thanks for the heads up on the glass sensor. What you say makes perfect sense. Scratched from the list lol.
515R? Sounds perfect! Thanks.
Thanks for all the advice. I am trying to do all the homework I can so I can take it to a good friend who is an installer. He was my bay manager at Tweeter before they closed our store down and another 30 last year.
