Ford Racing Performance Parts
Go Back   Focaljet - Ford Focus Forums > Ford Focus Style > ICE (In Car Entertainment)
ICE (In Car Entertainment) Audio, Security, DVD, and video game installs.
Sponsored by: Boston Acoustics
Old 06-23-2008, 11:34 AM   #1
parthc007
Default Focus 4600 head unit specifications...noob
its my first post here....just got 2000 white focus SE and had a couple of questions.
It has the factory sound system(4600) and factory speakers. I recently bough 4 Polk audio DB571 5 x7 speakers to replace the stock.
So my first question:
1. Would the 5 x 7 speakers fit in the 6 x8 slot without any adapters?
2. Does the factory unit have an amp? may i should rephrase the question....will the factory unit be able to pump out enough dope for the db571's or should i buy a new head unit/amp?
3. i am prolly going to install the speakers myself, any guides online as to how to install them?
thanks
parthc007 is offline   Reply With Quote
Old 06-24-2008, 09:39 AM   #2
parthc007
Default Re: Focus 4600 head unit specifications...noob
anyone????? help this noob?
Old 06-24-2008, 10:55 AM   #3
danager
Most 5x7's will fit without an adaptor, look on the speaker to see if they have the extra mounting tabs.
You could run them off of the factory deck, an aftermarket stereo will give you a little more power, and more controll (eq's).
Check out the "sticky" section, for some faq's, and tips. Be sure to read the wire colour, to make sure you have the polarity correct on all speakers, as you will have to cut off the plug that goes into the factory speakers.
danager is offline   Reply With Quote
Old 06-24-2008, 01:47 PM   #4
David Anderson
David Anderson
danagers post hit on the head
Old 06-24-2008, 02:53 PM   #5
captain_jack
Before you cut the speaker harness off run you booty down to ur local best buy and buy the speaker harness. they are like 24$ for both front and rear but they plug into the factory harness and you will always get the polarity correct. Cutting harnesses is silly these days.You will need metra part number 72-5600.
If it aint Pine it aint mine. 05 ST pitch black
turn sigs and blackened heads and tails skunk2 2" drop, fc sts, ice, r/s alarm
captain_jack is offline   Reply With Quote
Old 06-24-2008, 08:45 PM   #6
rollin_loud
not to mention a major PITA dealing with those short lil wires after u hack it off!!
rollin_loud is offline   Reply With Quote
Old 06-25-2008, 10:01 AM   #7
Ray
aka demonfire
yeah the wiring for the speakers in the doors is insanely short. i wish they had those adapters back when i did my doors several years ago.
Cable Ties. Is there anything they can't fix? Driver > Car - in memory of GaryK
Roadtrippin.org | CART
Ray is offline   Reply With Quote
Old 06-26-2008, 07:02 PM   #8
parthc007
hey thanks for the suggestion....where else can i buy it cuz i don't think canadian best buy stores sell that...any canadians on the forum care to help?
Old 06-27-2008, 01:36 AM   #9
danager
You are correct, Best Buy Canada dropped the speaker harnesses about 2 years ago. Try Crutchfield.
