Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Style > ICE (In Car Entertainment)
ICE (In Car Entertainment) Audio, Security, DVD, and video game installs.
Sponsored by: Boston Acoustics
Old 10-27-2009, 10:13 PM   #1 (permalink)
Default stock subwoofer problem.
i got it home, first car, its a 2004 sonic blue, euro package svtf.
its got two connectors, one going in to the enclosure and one going to the front of the car.
its not hooked together in any way between those two connectors,
il post pics in a minute.
any ideas?
all help appreciated.
This is the one going towards the front. it could be to the amp, im not sure.
thats the one going to the enclosure, no connections between either. im kind of a noob when it comes to connections and things.
as said eirlier all help appeciated:]
2004.blue.euro.svt. is offline
Old 10-27-2009, 10:51 PM   #2 (permalink)
GapBoyPCS's Avatar
Default Re: stock subwoofer problem.
Welcome to FocalJet.
Let's see if anyone in our ICE section can answer this one...
Richard - 2002 ZTS | Sangria Red | 433,000+ km...Be Bold, Stay Focused 24-7
Redline Rendezvous | OFOC - Ontario Focus Owners Club | SVTOA-Toronto
GapBoyPCS is offline
Old 10-27-2009, 10:55 PM   #3 (permalink)
thank you.
sorry about posting in the wrong area, i wasn't sure which section it belonged in.
Old 10-28-2009, 10:54 AM   #4 (permalink)
20focus03's Avatar
pictures are real clear but on connects to the amp
03 Sangria Red zx5 stock :)
09 Harley Sporster 1200 :)
99 Yamaha R6 (stunter) :)
93 S10 -SBC in the works :)
._________________________
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___.
|_..._...____________======||_|_|...,]
20focus03 is offline
Old 10-28-2009, 04:16 PM   #5 (permalink)
hmm. is it the one runing towards the front of the car? or the one going into the enclosure?
Old 10-28-2009, 05:31 PM   #6 (permalink)
20focus03's Avatar
the one towars the enclosure since the amp sits right on top of it
Old 10-28-2009, 06:00 PM   #7 (permalink)
oh. so am i missing the amp then?
what does the amp look like?
Old 10-28-2009, 07:10 PM   #8 (permalink)
20focus03's Avatar
its a big sliver square should be right on top of the sub enclosure unless some took it out
Old 10-28-2009, 09:13 PM   #9 (permalink)
ahh.i see. any idea how much one would run me, new or used?
or if it would even work?
Old 10-28-2009, 10:58 PM   #10 (permalink)
20focus03's Avatar
so your missing the amp? i know there are some on ff if those arent available its gonna be tough trying to track one down
Old 10-29-2009, 12:32 AM   #11 (permalink)
yeah, theres the black plastic enclosure, and nothing on top but 4 holes.
i heard somewhere the amps on the passenger side?
Old 10-29-2009, 02:16 AM   #12 (permalink)
20focus03's Avatar
no the amp is on the drivers side right ontop of the enclosure,those 4 holes is where it bolts down,u need to check out focusfanatics audio for sale section i think i saw a few of them on there
Old 10-29-2009, 09:25 AM   #13 (permalink)
While were on the subject of the stock amp..anyone know how many watts it pushes to the stock sub???
Dads03SVT is offline
Old 10-30-2009, 08:58 AM   #14 (permalink)
20focus03's Avatar
i cant remeber i wanna say something like 300ish,but dont quote me on that
Old 10-30-2009, 09:17 AM   #15 (permalink)
I heard 200....if so that's not enough to push a 8 inch JL-W3.
Old 10-30-2009, 09:31 AM   #16 (permalink)
20focus03's Avatar
while i was waiting to track down another stock sub i had a fosgate 10 in my stock enclosure with stock amp it sounded fine
Old 10-30-2009, 01:10 PM   #17 (permalink)
i heard a lot less, but another question, what subs would fit in the stock in closure with little or no fab work?
Old 10-30-2009, 09:49 PM   #18 (permalink)
20focus03's Avatar
ive seen all the way to a 12in with a little trimming,i had a ten in mine with no trimming
Old 10-31-2009, 01:18 AM   #19 (permalink)
ahh. thank you very much.
is there any kind of rep system so i can credit you for your help or something?
Old 10-31-2009, 01:37 PM   #20 (permalink)
20focus03's Avatar
no theres not,dont even worry about us jetters look out for each other
Old 11-01-2009, 12:58 AM   #21 (permalink)
ah thank you very much.
Old 11-01-2009, 01:55 AM   #22 (permalink)
Could you do me a favor? I have the opposite problem from you: I have the amp, but not the wiring! I bought the stock subwoofer from someone but for some reason my car doesn't have the wiring in place and I'm going to have to make up my own. Can you take a picture of that connector, the one that has 7 (?) wires going in to it so that I can see what wire goes into what place on the connector? I believe there should be two red (12v constant), two black/blue (grounds), one white/red (amp turn on), and then the positive and negative amp inputs (wht/blk and gry/blk), but I'm not sure which position each are in on the connector. And then on the other one, is it just two wires? One white and one gray and going to the speaker?
Also, can you (or anyone out there) let me know how the sub enclosure bolts to the floor and wall? I have the brackets and bolts but there are just large holes on the car that match up to them and they don't have nuts welded to the back and there is no access to get behind there and hold a nut while bolting the brackets on. Is there some sort of insert that pushes into the holes and then the bolts screw into them?
I'd really appreciate it!
stephens is offline
Old 11-01-2009, 02:34 AM   #23 (permalink)
20focus03's Avatar
the whole should be threaded,if not get yourself and a tap and dye set and make your own threads
Old 11-01-2009, 10:38 AM   #24 (permalink)
I can't tap it because though the holes are already there, they are much too large. The holes in the bracket piece are sized for size 6 metric bolts and those came with the subwoofer. But the holes drilled in the floor and wall are so large even a size 14 bolt can fall right in. If the holes are supposed to be smaller and threaded, then I'm SOL. I'm going to have to attach the enclosure some other way - make a different bracket and tap new holes, or maybe just velcro the thing.
But the wiring is more important so if anyone can post about that, I'd appreciate it. Thanks!
stephens is offline
Old 11-01-2009, 12:20 PM   #25 (permalink)
are you talking about the wiring like coming from the connectors in my pictures.
