Racing Parts Solution
Results 1 to 9 of 9
    Nov 2007
    San Carlos, CA
    102
    Question Power is not being cut to the power outlet
    I'm not sure if this is in the right section...
    Basically my battery was completely discharging if the car was sitting for 1 week.
    Today I hunted down the problem and turns out that the relay or whatever cuts the power to the power outlet/cig lighter in like 15-25 min is not working. I had my PIE AUX adapter connected to the power outlet wires and it was draining the battery.
    Does anybody know what cuts the power to the power outlet, where it is, and how to replace it?
    Thanks!
  2. #2
    TEAM Member Now534's Avatar
    May 2010
    Norwalk IA
    614
    Default Re: Power is not being cut to the power outlet
    As far as i know it is wired for constant power. The only way to shut it off is to rewire it to an ignition signal.
  3. #3
    Ray
    Ray is offline
    Driver > Car Ray's Avatar
    Jul 2002
    CT
    31,109
    That outlet is wired to be on constant on - so it's no failure. Just unplug what is plugged in if you're going to leave the car for a while.
    I used to have a focus like you. Then I took an arrow to the knee.
    Intelligence is largely at the mercy of self-control
    Roadtrippin | CART | MCA
  4. #4
    Oct 2004
    Somewhere between UT and MN
    4,400
    rewire your pie thing... mmmm pie...
    Seriously though, if you've tapped the wires to the cigarette lighter without checking to see if it turns on and off with the car, lesson learned. Try using the wire that is ignition switched going to the HU
    '00 Focus Kona edt.
    SVT suspension, poly bushings, 15" split 5 spokes with Cooper CS4, ebay CAI with K&N filter, an 'aaaoooogah' horn
  5. #5
    Nov 2007
    San Carlos, CA
    102
    Quote Originally Posted by Ray View Post
    It's not constant on. I clearly remember over the past years I would forget to turn off my XM receiver and I would come back an hour later and it is off, that is until I open the door.
  6. #6
    Oct 2004
    4,400
    Quote Originally Posted by BeeFzX3 View Post
    while it's entirely possible that your focus is different than any other focus ever made, I rather doubt it
    '00 Focus Kona edt.
  7. #7
    Moderator Dracconix's Avatar
    Nov 2002
    Central Indiana
    3,136
    More than likely it was something built into the XM receiver that automatically shut it off.
    Yellow Blaze 2012 with a Coyote 5.0 swap.... it's stock otherwise...
  8. #8
    May 2010
    Norwalk IA
    614
    12v plug is constant. XM more than likely had a auto off like what someone previously said.
  9. #9
    Feb 2010
    20
    Which head unit do you have? You can splice into the power wire that is only on when the radio is on.
