Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Style > Interior Modifications
Interior Modifications Seats, shifters and knobs, gauges, etc.
Old 10-27-2009, 07:44 PM   #1 (permalink)
"Shut Up man, get on my horse"
Armanduhx3's Avatar
Default Guage Cluster LED Swap.
Im thinking about changing the LED's behind the guage.. Any Idea on how to do so? I tried searching, but none really were that helpful. Like what size bulbs? I know Oznium has some, but im not sure what size.. Ideas?
aRmanda||Tweet||Building teh zx3||Girls of FJ
Armanduhx3 is offline
Old 10-27-2009, 09:39 PM   #2 (permalink)
Default Re: Guage Cluster LED Swap.
What year is your Focus?
SilverDuratecZX3 is offline
Old 10-29-2009, 07:28 AM   #3 (permalink)
Armanduhx3's Avatar
Whoops, i should of stated that.
2001 zx3
Old 10-29-2009, 08:38 AM   #4 (permalink)
slipster17's Avatar
http://www.superbrightleds.com/mini-wedge.html
Keep in mind that the green color you see when your gauges light up is not due to LED bulbs. All the bulbs in the cluster are white incandescent bulbs. The green color is a coating on the back of the gauge cluster.
That said, I'll double check what the sizes of my spares are when I get home but I believe that you'll need 3 #194 bulbs for behind the needles and a #74 to put behind the odometer.
The hardest part is really that you need to take apart the odometer and sand off the green finish on the little paper backing the glass screen has. The bulb behind that bit is actually white, the paper is what gives it the green tint.
If you are looking change the color the gauges light up, I'd recommend hitting up www.speedhut.com and seeing if you can built the custom one you are looking for.
Good luck!
_R E C A L L_
.,___,,_
/___l__\__
l(o)____(o)
l <--2001 Egg Yolk Yellow Eurofied ZX3
see it on CarDomain
- team edm - 160k+ miles
slipster17 is offline
Old 10-29-2009, 08:39 AM   #5 (permalink)
Cool. Your cluster has qty 3 of #194 bulbs in there. Now i have done a lot of experimentation with plug-in LED bulbs and I have been disappointed by all. They offer very spotty illumination, because of the placement of the bulbs in relation to the gauge face.
The best lighting that I have found is a ribbon of white LEDs, placed around the perimeter of the cluster. This gives a very even lighting effect.
You can get the strip at http://www.oznium.com/led-ribbon-roll. You would need about 3' of it.
But they do not offer it by the foot anymore, it appears. You also have a PM.
I hope this helps.
Old 10-29-2009, 03:54 PM   #6 (permalink)
Armanduhx3's Avatar
Thanks everyone .
I have an idea of what I might want to do.
Keep the gauge cover the stock black one, sand of the green. Throw in a LED Stripe and walla.
Anyone change the indicator light colors?
Old Yesterday, 01:27 AM   #7 (permalink)
Yeah the indicator lights on the stock gauge face are just semi-clear plastic film.
Best results I ever had changing those colors were to buy some overhead plastics (look at office-max for overhead projector sheets that are colored)
Then throw them through a laser printer and print the emblems you want on them, cut to size and scotch tape it onto your gauge face.
You can even get creative and have your brights indicator say something like "Blinder Beams". It will be small text but its fun!
PS- Use an xacto knife and peel up the edges of the indicator films that are on the stock gauge face.
FZXRAcing is offline
