Perfect Circle Autosport
Results 1 to 8 of 8
    TEAM Member Yellow Jacket's Avatar
    Jun 2010
    Illinois
    541
    Thumbs up SVT power seat button LED conversion
    Since I’m doing a blue LED conversion why not? Plus I did the power lock light mod so it didn’t take me long at all to figure this out.
    What’s needed:
    -A Focus lock switch.
    - Power lock wiring harness with wire length.
    -18ga Wire, quick disconnects, Scotchlocks, soldering iron, and/or your usual electrical supplies.
    1. Remove the seat from the car.
    2. The switch has glue around it; mine flaked off easily with a screwdriver. Remove the glue and the switch.
    3. If you pop the switch open you’ll see there is no LED…
    4. … so take your lock switch with the LED and open it up. Simply swap the “top” of the seat switch to the “bottom” of the green lock switch which already has an LED in it.
    Lock and seat respectively. The lock switch has two extra pins for the LED
    Test: I converted to blue.
    Now to wire the LED to the seat:
    5. This is exactly the same as the lock switch LED write-ups. You can TRY to solder wire to the leads inside the switch and not be able to disconnect it ever… or you can get a spare lock wiring harness form the junkyard and do it OEM. I had a spare lock harness from doing lock switch mod with wire on it; remove two of the pins for the seat. You have to remove the white clip on top (not shown) and fiddle with the clip inside with a small screwdriver until you can get the pin to slide out of the back.
    6. On the seat remove the white clip and put click the pins in the harness.
    The pins on the switch are 5 positive, 4 negative. So put the pins in the corresponding holes.
    New pins, don’t forget to put the white clip back on.
    7.
    I thought it was logical to have the wires extend to the large harness that you have to unbolt under the seat, I put quick disconnects on them and zip tied them securely to the seat. I soldered 18ga wire to the 22-24ga wire because the disconnects will crimp on better.
    Wiring in the car:
    8. I grounded the wire to the bolt that holds the seat position sensor(?) under the carpet , there’s an access flap in the carpet.
    9.
    For the + power you can extend the wire to the headlight switch. I hooked mine up the headlight knob + power so it will come on with the headlight knob and door switches. OR if you have heated seats you can tap into that to have it come on with the parking lights.
    10. Make sure you have plenty of slack on the wires, I zip tied mine to the length of main seat harness that comes out of the carpet for protection and range of motion. Put your quick disconnects on these wires. Install the seat and plug everything in.
    Done!
    2003 SVT ZX3 EAP - "EUROTRiSH"
  2. #2
    Feb 2009
    Down East Maine
    365
    Default Re: SVT power seat button LED conversion
    Nice job, and nice write-up!
  3. #3
    May 2009
    Louisville, KY 40205
    621
    The SVT has power seats?!?
  4. #4
    Jun 2010
    Illinois
    541
    Quote Originally Posted by miragesmack View Post
    Only for the seat bottom height adjustment, surprisingly some SVT owners don't know that button is there.
  5. #5
    TEAM Member A_15's Avatar
    May 2010
    NW OKC
    372
    Didn't cougar buttons light up. I'm gonna see if the one I have already lights up
    2003 SVT Focus ZX5 "Iron Man Mk1"
    Saving the world, one on-ramp at a time.
  6. #6
    May 2009
    621
    Damn, I wish I knew that before I recovered mine. Learn something new every day I guess.
  7. #7
    May 2010
    NW OKC
    372
    I'm not sure yet but I have one in the garage. I need to take a look
  8. #8
    Jun 2010
    Illinois
    541
    Quote Originally Posted by A_15 View Post
    I know that the Contour window button is the same, except the switch is pinned differently for the LED. I almost recommended it, but I think the LED would stay on all of the time by the way it's made. I didn't try a Cougar button though.
    And for the record a Focus passenger window switch is pinned differently.
