Old 07-17-2007, 11:32 AM   #1
geostef
Default 2.4'' powerworks pulley
hello guys. I was wondering if there is a solution for the belt slippage using the little sc puley? have you faced that ? thnx
PowerWorks 2044cc Zetec -CR 9.7:1, Diamond pistons with Eagle rods ,lightened - weightbalanced crankshaft, 2.4'' pulley, 5.36''crank pulley, FR head with 1mm Supertech inconel valves,ported and polished supercharger manifold, Mcnews custom SC cams, SVT manifold decat with 2.75'' custom pipes with custom middle box,MTX trans 4.06 final with HyperSingle Exedy and Torsen T2
-- from JJ POWER --
geostef is offline   Reply With Quote
Old 07-18-2007, 12:13 AM   #2
K STYLEZ
Default Re: 2.4'' powerworks pulley
Yup. Check the site for our shorter belts.
Old 07-18-2007, 04:17 AM   #3
geostef
Karl its not the belt unfortunately. I am using a gates 6PK 2193 which is 86.33'' inches. It was really difficult to fit in so it tight enough. Any other advice?
-- from JJ POWER --
Old 07-18-2007, 09:44 AM   #4
K STYLEZ
Hmm. Dunno. I cant really recommend a size since your crank pulley is bigger. But I cna tell you once we found the right size, boost doesnt creep at all at the top of the graph. And its HARD to get on. I mean, H A R D. Like, you have to walk it on one rib at a time while rotating the motor by hand.
Maybe your tensioner is no good? It might seem tight at rest but under operation or high RPM its giving out?
Is your routing regular PW? Im unsure if there would be any differences with the 1.8 Zetec accessories as well...
Old 07-18-2007, 03:06 PM   #5
geostef
I have a 2.0 liter one mate forget the 1.8l ))
Yes the tensioner is a custom one...not an automatic one.Just kept the goodyear tensioner pulley. What kind of tensioner are you using?
The goodyear one, stock PW or the gates?
check that thread when you have time...
http://forums.focaljet.com/forced-in...placement.html
-- from JJ POWER --
