North Coast Performance
Old 08-29-2007, 12:38 PM   #1
K STYLEZ
Default ***NEW Addition - Zetec UDP Now Avail as 2 pc***
Massive has been offering our Zetec Under Drive Pulleys for years with great success, and we have decided to expand our offerings. Water pump pulleys are now available to increase undriving resulting in of course MORE HP and killer looks. Here is what we have to say about our new 2 piece pulley kit:
Installs in place of your factory crank and water pump pulleys. This is a BOLT on installation. REALLY frees up horsepower! Expect a nice performance gain, 5-7 wheel horsepower is typical. This device works by slowing down or "underdriving" your vehicles accessories. That includes all pulley driven items (alternator, water pump, power steering, A/C, etc.). The less horsepower your engine spends driving those, the more power it has to move your vehicle forward. Zetec motors are INTERNALLY ZERO balanced, meaning the factory pulley IS NOT a harmonic dampener of any kind. This means swapping the crank pulley will have NO adverse effects on engine longevity, Massive's staff has logged literally over 250,000 collective miles with these pulleys installed and have seen NO unsatisfactory qualities. Made of super light weight 6061 aluminum, this pulley also allows the engine to rev more freely by replacing the heavy cast iron pulley it replaces. Weight differences between this and competitors pulleys is less than 2 ounces yet pulleys offer 90% higher total rigidity and far better overall strength. These are not cheesy knock offs with fitment problems often found on ebay, these are the real deal. Massive makes our pullies with the highest precision machinery in the business today, and utilizing ultra close tolerances and a super strength design that will last forever. Fairly straight forward installation, comes with its own instructions. These high quality Massive pieces are quality made in house at Massive in the USA. If you need assistance, let us know and we'll walk you through it! Should take less than 1 hour for a novice car guy (or girl). Pulleys come anodized MASSIVE PURPLE. Has the Massive logo and a crank position mark machined into the faces. For A/C cars only.
Massive now has 3 distinct offerings. The above mentioned kit, the traditional crank pulley/belt combo:
and our NEW PRO System:
Find them all Here
Old 09-21-2007, 11:21 AM   #2
sliverbullet
Default Re: ***NEW Addition - Zetec UDP Now Avail as 2 pc***
what the difference between the dual and the pro
what kind of power do this give me for my zetec
ford focus zx5, 5-speed
custom short ram intake, obx catback,screamin demon and live wires, exel tz10's, custom gauge pod, prosport gauges.......... many more mods coming soon
sliverbullet is offline   Reply With Quote
Old 09-26-2007, 08:48 AM   #3
Alec Brandon
Ditto, you offer 3 different kits and don't tell us the differences between them... whats'up?
Yellow 2000 ZX3 - Tinted Windows, SVT Air Intake, MBRP Exhaust, NewEdge Performance 2.25" Flex Pipe, Focus Sport UDP, SVT Bumper, Ford Racing 9MM Wires, K&N Filter, Shorty Antenna, 91 SCT Tune, Ported Throttle Body. 190,000 KM (120,000 Miles) and counting!
Alec Brandon is offline   Reply With Quote
Old 09-26-2007, 12:43 PM   #4
MaroonZX3
It looks to me like the Light Pulley is a single pulley setup and uses a non-original length belt, which it appears to come with.
The Light Dual Pulley obviously has two pulleys and most likely works with the stock length belt.
The Pro Light Dual Pulley looks to be the same as the Dual Pulley system, but it comes with a new belt. This would be a good option if you could use a new belt anyways.
I hope I have that all right.
MaroonZX3 is offline   Reply With Quote
Old 10-25-2007, 01:21 PM   #5
starfuryt550
the pro system uses a better belt, which is more expensive. it is stronger and hold up to heat better.
starfuryt550 is offline   Reply With Quote
Old 10-26-2007, 05:44 PM   #6
AG_UA
Karl,
1) Does the Dual Pulley System use a stock size accessories belt?
2) Do you make the water pump pulleys in gold shape (as you did with your crank shaft UDP)?
2) Aren't you planning to introduce something similar to the below device
http://www.pumaspeed.co.uk/showdetails.php?id=575
Euro FF1 /1.6 Zetec-E: Engine Bay: SVTF Air Snorkel, OMP Air Filter, BBK 65mm TB, ECOTEK “CB-26P” Valve, MSD Coil, Magnecor KV85 Wires, AYFS22C Plugs @ 0.059", "Big 7" SuperEarth, UDP, ES Lower Motor Mount, Custom Fit Ingalls "Stiffy", SVTF De-Gas Tank Cover. Exhaust: JBA Shorty Header. Interior: SVTF Brake Handle, FR Intermittent Wiper Switch, “Metal" Painted Door Handle Inserts & Vents Surrounds, 2 "CG-LOCKs" Seat Belt Lock. Exterior: Focus ST170 Lower Radiator Grille, Tinted Windows, PIAA "Super Plasma GT-X" 6000K Low Beam & Wedge. Brakes: “Gold" Painted Front Calipers, EBC Black Pads. Susp.: Prothane Everywhere, 21mm Rear SB. Wheels: VSMPO “Vega” 15” Forged Rims.
AG_UA is offline   Reply With Quote
Old 10-26-2007, 08:40 PM   #7
IslandFocus
Isn't that the same pulley that CFM offers?
2000 Focus ZX3: Xios Turbo Kit on Built Motor in Progress!!
IslandFocus is offline   Reply With Quote
Old 10-27-2007, 04:57 AM   #8
AG_UA
I haven't seen it before @ CFM... Now I see it really is the same pulley. It seems that UK guys import it from the US.
Old 10-27-2007, 11:29 AM   #9
Terrible1
Wish you guys could make a stock size lightweight crank pulley for us SC guys! I'd pick one up in a heartbeat
ENGINE- Powerworks, Kamikaze, 2.5" SS exhaust, Mocal oil cooler, Torsen, 4.06 FD, CN race clutch, Fidanza SUSPENSION/WHEELS- Custom H&R Coilovers, FS camber plates, CFM control arms, Prothane, Eibach sway bars, Rota Slips w/Toyo R888, SVT brakes w/Hawk race pads, ARP studs, Custom wheel spacers
EXTERIOR- Deft' CF hood, Sparco hood pins, CF F1 mirrors, CF sunroof delete, Custom front airdam/splitter, APR wing
INTERIOR- Custom spec cage, RS shift knob, FC SS, Corbeau Fx1, Momo Mod78, NRG quick release, Defi gauges, Crow 5point SPONSORS- Troys Engine Mfg., Casper Customs, Striknine Motorsports, Bleeding Cowboy Tattoo
Terrible1 is offline   Reply With Quote
Old 11-06-2007, 05:46 PM   #10
starfuryt550
so does that tensioner pulley actually give you additional power??
Old 11-07-2007, 01:15 PM   #11
pzev04boy
There is no tensioner pulley. I think you are confusing the hub adaptor for the water pump pulley.
We made the Water pump pulley to fit both duratec and zetec. It fits zetec with the hub adaptor.
03 ATX Powerworks sedan
00 Mustang Gt - Built motor
07 Ninja 500R
Massive Speed
Http://www.massivespeedsystem.com
pzev04boy is offline   Reply With Quote
