Old 08-30-2007, 10:43 PM   #1
SVT-SAGE
Default Massive Dogbone-
Hey thanks for the dogbone, that thing has Massive bushings . Nice and stout. It definately improved my shifting, no more stutter after shifting, just solid shifts.
2003 SVT Focus-Pitch Black#3746
-- SCT XCAL/4-1 SS/ORP/SH UDP/AEM E-Gear/ VOLANT /Ported TB
-- Fidanza 12lbs LWF/ Audi A4 SBC Clutch/Steeda STS
-- Tein S-Tech's / KYB AGX/ SPC plates/ Steeda 28mm RSB/ Massive Dogbone/ Kazera KZ-V
-- WRC Wing/ Rally Headlights/Euro Grille
SVT-SAGE is offline   Reply With Quote
Old 08-31-2007, 09:05 AM   #2
K STYLEZ
Default Re: Massive Dogbone-
You let the cat out of the bag!!!
Glad you like it!!!
Old 08-31-2007, 02:37 PM   #3
SLVRbulletSVT03
Geeeeeeeeeew! That thing is huge!
I may have to pick one up to replace my MAC mount....
2003 CD Silver SVTF
www.IMPORTSNC.com
North Carolina's Source for the Import Scene
SLVRbulletSVT03 is online now   Reply With Quote
Old 08-31-2007, 02:45 PM   #4
jerkeesvt
Looks like a very nice piece!!
Xios turbo'd '03 SVT Focus euro edition in competition orange with the Saleen/Eibach susp. kit!
If you want EXEDY to make a clutch for the SVT Focus...... e-mail them at: TechSupport@EXEDYUSA.com
jerkeesvt is offline   Reply With Quote
Old 08-31-2007, 02:50 PM   #5
Qwik1
Official [FJ] Spam Police Chief
Looks like a stocker with upgraded bushings.
Maybe it's just me.
Originally Posted by sicko
I just need to be able to tap it :(
I've done if from underneath before but can it be done at any other angle?
Qwik1 is offline   Reply With Quote
Old 08-31-2007, 06:29 PM   #6
K STYLEZ
Its a steel mount versus the mostly aluminum stockers. The aluminum ones break quite often on most higher torque boosted vehicles.
Old 08-31-2007, 06:55 PM   #7
whyme
so what are we talking price?
2006 zx3, 2.0 PZEV. Toreador red
Body Mods: Roush front fascia, HIDs (6k), 5% Tint, Blue turns, Silverstar fogs, painted headlights, BOSCH wipers.
Performance Mods: MBRP exhust, F2 CAI, F2 Header, Cosworth Cams, CFM 65mm TB, FC short throw, Steeda MIL eliminator, energy dogbone inserts, SVT 5 spoke wheels w/ Hankook K106 rubber, SVT dampers and FRPP 1 1/2 drop springs, Bix RSB retrofit, Eibach anti-roll kit(22mm front/25mm rear), slotted rotors and Hawk HPS pads, XCAL2 by FocusSport.
whyme is offline   Reply With Quote
Old 08-31-2007, 07:08 PM   #8
SVT-SAGE
Dude this thing is way more solid than the stocker. Not only are the bushings poly but the dogbone is some hardcore steel, and weighs alot more than the aluminum stock piece.
Old 08-31-2007, 07:30 PM   #9
K STYLEZ
Should be around $75.
Old 08-31-2007, 07:39 PM   #10
Qwik1
Um, the stocker in my 2000 ZTS was steel. So is the one from my 06 ST. This pic looks EXACTLY like both of them. Even has numbers cast in the same location in the recess, looks like the numbers on the small end were ground off before painting.
Old 08-31-2007, 07:43 PM   #11
K STYLEZ
None of the early cars had steel mounts. We've replaced literally hundreds of them.
Old 08-31-2007, 07:58 PM   #12
Qwik1
Not trying to knock you or your product here. Looks like a good value w/ some very nice bushings. But I will post pics tonight so you can see what I mean. I would put down $20 on that being a stock mount frame.
Old 08-31-2007, 10:16 PM   #13
SVT-SAGE
Here's another pic for you to analyse.
Old 09-01-2007, 01:59 AM   #14
Oreo
DoubleStuf™
My '05 ST came with a steel mount also. Looks identical to the one Massive is selling.
I'd like to point out an issue regarding the orientation of the large bushing. In the pic it is installed exactly the way the directions specify in the Energy Suspension bushing package. However, when I performed my own bushing swap I realized that the directions were infact flawed. The bushing needs to be rotated 180 degrees so that the flat spot on the rim of the bushing faces the small end of the mount. This way, the bushing conforms propperly to the frame of the car.
Gun Jet: Check out a great new forum! Click here.
Installed: SVT Brakes, ST200 Rims, Koni Sports, -2" Apex springs, poly FLCA & dog-bone bushings, Progress 22mm RSB, TriAx/F STS, Cosworth CAI, Draxas & Trubendz exhaust, XCal2- *Now with more ProRacer!*
On Shelf: T2 ATB, 4.06 fdr, Cosworth IM, Stg 2 Crane cams, Eagle ConRods, 12.5:1cr 88mm Supertech pistons, Fidanza FW, Luk ProGold clutch
Oreo is offline   Reply With Quote
Old 09-01-2007, 05:54 AM   #15
Qwik1
So, can you seriously state that yours is not a stock mount with black Energy suspension bushings? This is my stocker. Pretty obvious. Now, what you are selling is a good combo at a fair price. My objection is the claim that this is a Massive mount, along with the "Unbreakable" claim. I know, for a fact, that this mount frame has been broken by quite a few people. Many of them used the same type of bushings. Again, good product at a fair price. Just sell it for what it really is without the hype. That is, unless-- are you actually going to give a lifetime warranty to match the "Unbreakable"?
Old 09-01-2007, 10:59 AM   #16
MSpeedRacing
looks pretty much the same?
AKA SRF
MSpeedRacing is offline   Reply With Quote
Old 09-01-2007, 11:48 AM   #17
pzev04boy
00 - 04 Mounts were all aluminum. And they break very easily.
We offer a ready to go kit using the steel version. Saves the pain of having to press bushings and is rock solid.
03 ATX Powerworks sedan
00 Mustang Gt - Built motor
07 Ninja 500R
Massive Speed
Http://www.massivespeedsystem.com
pzev04boy is offline   Reply With Quote
Old 09-01-2007, 12:54 PM   #18
Qwik1
Thank you. I'll get out of your hair now. I was just picturing some guy just starting to mod buying this, pulling out the stocker, and freaking out thinking he got ripped off.
Old 09-01-2007, 01:47 PM   #19
IslandFocus
So this is actually a steel factory mount with upgraded bushings then?
2000 Focus ZX3: Xios Turbo Kit on Built Motor in Progress!!
IslandFocus is offline   Reply With Quote
Old 09-02-2007, 12:08 AM   #20
Oreo
DoubleStuf™
I can say that, while the aluminum mount might break, I have a very hard time imagining the steel one that came on my ST ever breaking, even under highly abusive conditions. Probably more likely that you'd ruin the urethane bushing first.
Having said that, the steel version is like, 900,000lbs heavier then the aluminum version. Kinda reminds me of that oil commercial with the cars dragging boat ankers.
Old 10-01-2007, 08:16 PM   #21
illinipo
This may be true, but I have one question: How the HELL did you get the bushing past the bulge in the K-member???? I tried, failed, and spun it around for easier installation.
PS Karl have you ever put one of these, or any rear mount I guess, on an atx? I cannot stand the vibrations at stoplights, and ive only had it in for 2 days. It seriously gives me a headache...reminds me of a hooptie with 15" subs playing a high note...constantly... Changing "Drive idle speed" in my xcal tune only bumps up the engine speed while the car is in motion with the throttle closed, not while its stopped.
illinipo is offline   Reply With Quote
Old 10-02-2007, 09:44 AM   #22
NewtzZx3
no matter what upgraded dogbone you get, if it is stiffer and does its job, you are gonna get the vibration. only cure is more cowbell! j/k, only thing to do is raise the idle like you say
"She turned me into a Newt!"..."A Newt?"..."I got better..."
"You might be an engineer if...In college, you thought Spring Break was metal fatigue failure"
2002 Black ZX5 - the mods are pilling up now!
NewtzZx3 is offline   Reply With Quote
Old 10-04-2007, 12:23 AM   #23
infraredhb
A press does wonders Pete!
'03 CDsilver 3door SVT #2976
infraredhb is offline   Reply With Quote
Old 10-04-2007, 10:18 AM   #24
illinipo
Now I have a question to you: How do you get a press under the car
Of course I used a press to get the bushings in, der...
But my original question related to installation on the vehicle.
Changing the idle with the xcal doesnt change the idle, now I am very specific about this situation, IN DRIVE OR REVERSE AND AT A STOP. If you are in drive and rolling, THAT is when the xcal makes a diference in idle. But as soon as I stop, the roms drop to some insanely low number (no tach...)
Old 10-05-2007, 03:26 AM   #25
Oreo
DoubleStuf™
That's a good question. I installed the bushi
