A little about the rods:
Genuine Eagle Forged Chromoly H-Beam Rods for Ford Zetec 2.0 found in Focus, Escape, Contour and Escort. Install in place of the stock powdered metal rods, the weak link in the Zetec engines. DONT expect to run anything over 250 flywheel horsepower with stock rods. Made from forged high strength 4340 Chromoly steel with a super solid H-beam design. Eagle rods are much stiffer and can handle higher heat levels, which permit far greater power and RPM situations. Rods feature premium US made ARP 12 point rod bolts, AND ARP assembly lube. Set of 4. Installation is best left to a professional. You'll need serious automotive knowledge and specialized tools to complete this job.
Find em Here
Linear Mode
