North Coast Performance
Old 03-27-2008, 09:17 AM   #1
spudmurphy
Default A question about international shipping
Its an easy enough one, are you guys happy to do it?
I'm after some clevite main and rod bearings, and you seem to have a pretty good reputation here on fj.
Please let me know if you'll ship to the UK and we can sort out the parts I'm after
Ta,
Spud
spudmurphy is offline   Reply With Quote
Old 03-27-2008, 12:15 PM   #2
K STYLEZ
Default Re: A question about international shipping
Absolutely. Do it all the time. Shoot me an email kt@massivespeedsystem.com
and we will get you a quote.
thanx!
Old 03-27-2008, 01:49 PM   #3
spudmurphy
Thanks, I have sent you an e-mail
Spud
Old 04-22-2008, 07:27 AM   #4
spudmurphy
I just want to follow this up with a quick thanks
The bearings arrived in the post here yesterday, a top service that I look forward to using again.
Cheers guys,
Spud
Old 04-22-2008, 11:25 AM   #5
K STYLEZ
Great! Glad we could help!
Old 04-22-2008, 03:27 PM   #6
AG_UA
Cheers guys,
Spud
They did same way several times for UA, not only for UK...
Euro FF1 /1.6 Zetec-E: Engine Bay: SVTF Air Snorkel, OMP Air Filter, BBK 65mm TB, ECOTEK “CB-26P” Valve, MSD Coil, Magnecor KV85 Wires, AYFS22C Plugs @ 0.059", "Big 7" SuperEarth, UDP, ES Lower Motor Mount, Custom Fit Ingalls "Stiffy", SVTF De-Gas Tank Cover. Exhaust: JBA Shorty Header. Interior: SVTF Brake Handle, FR Intermittent Wiper Switch, “Metal" Painted Door Handle Inserts & Vents Surrounds, 2 "CG-LOCKs" Seat Belt Lock. Exterior: Focus ST170 Lower Radiator Grille, Tinted Windows, PIAA "Super Plasma GT-X" 6000K Low Beam & Wedge. Brakes: “Gold" Painted Front Calipers, EBC Black Pads. Susp.: Prothane Everywhere, 21mm Rear SB. Wheels: VSMPO “Vega” 15” Forged Rims.
AG_UA is offline   Reply With Quote
Old 04-23-2008, 11:15 AM   #7
K STYLEZ
Whats up Andrey! Didnt know you were on here. Hows things?
Old 05-03-2008, 06:24 PM   #8
AG_UA
Hi Karl! Yes, I'm here...looking for some ideas about 8-11 psi supercharger kit bazed on Rotrex C30-74...
Old 05-03-2008, 07:09 PM   #9
K STYLEZ
COOL!
What kind of ideas are you after? Like... DO IT! Do you have the blower yet?
Old 05-04-2008, 07:16 PM   #10
AG_UA
No, I haven't it yet. I have a lot of things to sort out first to buy the blower.
The goal is something close to 200 whp (I hope to get a bit more ) with FMIC at 11 psi (wouldn't like to go with higher boost because I keep the internals stock). I'm planning to keep the intake completely stock: SVTF snorkel + drop-in hi-flow air filter in OEM box + MAF.
The most important question for me is what max boost level can I get with Rotrex C30-74 at max engine rpm (stock 6500 or 7000) I already calculated every possible pulley combinations to don't max out the allowed pick impeller speed (120K rpm). So, I can even stay with my (or your ) small lightweight UDP (wich I actually wouldn't like to swap back to the stock one) to be very close to 120K rpm:
100 mm crank pulley (UDP) + 60 mm blower puley = 103K rpm @ 6500 = 111K rpm @ 7000 or
130 mm crank pulley (stock) + 65 mm blower puley = 123K rpm @ 6500.
I see no way but to check it out directly on the engine.
The second problem is that there's no any good ECU tuner in Ukraine who worked with boosted Zetecs. But I hope to find the way.
Blower mounting bracket isn't a big problem (planning to mount it just below the alternator), as well as either alu-tubing, silicone hoses/couplings, injectors etc.
Just figuring about "exotique" BOV/diverter from http://www.synapseengineering.com/... is it worth
