Focus Performance
Old 06-13-2008, 09:21 PM   #1
ras50401
Default 00-04 to 05-07 svt brake kits
what is the difference between the 00-04 and the 05-07 svt brake kits beside the couple hundred bucks?
02' Sedan SPI Blood type Qow1"LOOKING FOR SVT"
Engine, Focus flo intake msd wires Efp orp Efp atx shift improver soon spi controller.
Interior, Gauge cluster with tach. key fob haha.
Exterior, Cfm shortie antenna st200 wheels m3 mirrors sedan tail light mod
ras50401 is offline   Reply With Quote
Old 06-14-2008, 08:21 PM   #2
venomrogue
Default Re: 00-04 to 05-07 svt brake kits
I belive the older kit has the spindles and knuckles, that are required, i think that is the reason for the price difference.
someone more knowledgeable will respond, im sure.
Old School: 2002 fully built Powerworks Zetec
New Hotness: 2004 JRSC SVT soon to be Powerworks
Parts by Karl @ Massive Speed System (www.massivespeedsystem.com)
Tuning and porting by Mark @ Skidmark Racing (turbof150.com)
venomrogue is offline   Reply With Quote
Old 06-14-2008, 09:16 PM   #3
ras50401
will from what i saw it looks like the same kit? i might be wrong just wanted to know the difference.
Old 06-15-2008, 06:43 PM   #4
venomrogue
it is basically the same kit.
but you need the SVT knuckles and spindles, which I think the 05+ already come with (not positive) and that is the main difference.
Everything else, calipers, rotors, pads, etc are the same.
Old 06-18-2008, 10:49 AM   #5
Egz
Correct. The 2005-2007 have SVT-style knuckles, and the brakes bolt right to them. 2000-2004 have incompatible knuckles, and thus have to be replaced so the calipers can bolt on.
Egz is offline   Reply With Quote
Old 06-23-2008, 06:50 AM   #6
EnixStorm
to add-on to the question, does the rear kit come with everything you need to install on the rearend and also hook up to the stock front ones?
-2003 SE PZEV ATX - FS 2.3l Stage 2
1/4: 13.78@100mph
-2008 Mazda 3S Touring 2.3l w/VVT
EnixStorm is offline   Reply With Quote
Old 06-24-2008, 04:19 PM   #7
venomrogue
yes.
everything but brake fluid.
Old 06-25-2008, 03:08 PM   #8
K STYLEZ
The"big" SVT kit that includes the rears, as Bryan states, does indeed include everything.
Old 06-25-2008, 03:10 PM   #9
K STYLEZ
I'm not really sure about the front stuff being "SVT compatible" but it would appear that way. I haven't acutally tried that new 05-07 front kit yet.
I'm going to check out the situation tomorrow AM first hand. I'll post pics with my findings.
Old 06-30-2008, 12:16 PM   #10
K STYLEZ
Yup. 05-07 spindles ARE SVT caliper compatible. They would not be able to be fitted to an 00-04 car though as the ball joint opening is a different size.
Old 06-30-2008, 12:24 PM   #11
SVTEuro
I am confused I thought Ford stopped making SVTs in 04?? How can there be 05 brake kits...It's not OEM?
SVTEuro is offline   Reply With Quote
Old 06-30-2008, 12:28 PM   #12
ras50401
could you do a convert? to adapt the the larger ball joint and would there be a plus side to doing it.
Old 06-30-2008, 04:24 PM   #13
K STYLEZ
Ford makes the ball joint as one piece. Its riveted on. Ford would tell you that you'd have to replace the entire control arm to do the job, and thats true, but companies like Moog have come out with kits that allow you to drill out the rivets and bolt on a replacement (they are greasable too!!). Unfortunately, these kits are only available for 00-04 cars at this time, so if you had 05 spindles, you'd need to buy 05 control arms from Ford to get the job done. They run about $85 IIRC.
Old 06-30-2008, 04:25 PM   #14
K STYLEZ
They did. But the SVT brake kit is easily adaptable to the 05 + spindle.
Old 06-30-2008, 04:39 PM   #15
SVTEuro
thanks
Old 06-30-2008, 05:50 PM   #16
ras50401
humm. i'm pretty impressed. but on a side note is there any actual advantages to upgrading the ball joint.
Old 06-30-2008, 08:53 PM   #17
K STYLEZ
That hasnt really been proven...
I will say that Focus ball joints do tend to go out alot, and replacing them with the Moog I imagine would yield superior performance and greater longevity if they are maintained.
Old 07-08-2008, 02:38 PM   #18
Stolle
YOU MODIFY, I CRITICIZE!
i know the SVT knuckle is alot beefer then the non svt 04 and 05 knuckles too. there is alot more metal to the knuckle as a whole which might be better suited for track/autox.
Parts by MASSIVE, tuning by FocusSport
"You must be able to keep track of the course in your head. If you can't, then you can't drive it to its fullest potential"
:|MK1 MotorSports|:
[> MY BAD!
Stolle is offline   Reply With Quote
Old 08-03-2008, 07:45 PM   #19
PCP_TwilightZX3
are these on the site cuz i don't see the 05-07 ones
2007 Infra ST 2.3 Fs intake, Hella 500's, Borla catback
Dough buys beer, it buys me beer. Ray, the guy who sells me beer. Me, the one who drinks my beer. Far, a long way to the john. SO, i'll have another beer. LA-ger Lager lager beer. Tea? no thanks i'll have a beer.
NObama 08
