Cosworth
Old 04-07-2008, 06:24 PM   #1
decepticon
Default Massive Unbreakable Rear Mount
This seems to be the lowest priced replacement rear mount on the market...how difficult is this part to install? I have a short shift kit on the way and would like to do the rear mount as well. Thanks!!
decepticon is offline   Reply With Quote
Old 04-07-2008, 06:34 PM   #2
K STYLEZ
Default Re: Massive Unbreakable Rear Mount
Should be a 20 minute install. Easy as pie.
Old 04-07-2008, 06:49 PM   #3
decepticon
Dude...you are quick! I posted that like half an hour ago! Thanks. Massive ROCKS!!
Old 04-09-2008, 09:39 PM   #4
venomrogue
unbreakable eh?
what is my prize if/when I break one?
Old School: 2002 fully built Powerworks Zetec
New Hotness: 2004 JRSC SVT soon to be Powerworks
Parts by Karl @ Massive Speed System (www.massivespeedsystem.com)
Tuning and porting by Mark @ Skidmark Racing (turbof150.com)
venomrogue is offline   Reply With Quote
Old 04-09-2008, 10:17 PM   #5
Mjasinski
i smell a challenge
2000 Autumn Orange ZX3 "Op Orange"
2000 CD Silver ZX3 "Bullet" the beater
My Space
Mjasinski is offline   Reply With Quote
Old 04-10-2008, 12:29 AM   #6
zx3r_type
Originally Posted by venomrogue
unbreakable eh?
A half eaten bologna sandwich
03 Infra-Red SVTF 5 door, HID's, Winter Package, Audiophile
Saleen Suspension, AEM Intake, FC ORP, Borla Flex Back, FC 65mm Throttle Body, All 3 VF Engineering Motor Mounts, Screamin Demon Coil and FR wires, Tune by Hypnotic, ST170 Grille, WW Midwing, Hail Damage Mod.
04 Sonic Blue Ranger XLT Ext. Cab 4x4 4.0 M/T
Magnaflow Split Rear Exhaust, K&N Intake, Tune by Hypnotic, Lund Racerback, Westin Brush Guard .
zx3r_type is offline   Reply With Quote
Old 04-25-2008, 11:27 PM   #7
jezwald101
i dont think its possible to break,you'll break other things way before this mount!!
SPEC FOCUS sponsored by MASSIVE SPEED SYSTEM.
2000 FORD FOCUS ZTS(ZETEC POWERED SPEC FOCUS)
2002 FORD FOCUS ZTS(JR SUPERCHARGED)
www.rehagenracing.com
www.fordracingparts.com
jezwald101 is offline   Reply With Quote
Old 04-25-2008, 11:56 PM   #8
zx3r_type
But, someone needs to try to break one. That is the fun part.
Old 04-26-2008, 02:24 AM   #9
Focusfre4k
I pay 5 dollar!
eh just put some real sticky tires on and pop the clutch about a 100 times and well....you hope it works. but your clutch would go first
Originally Posted by 1badassfoci
Well I hope it wont be too big for ya...haha hopefully you wont tear your butthole!
Focusfre4k is offline   Reply With Quote
Old 04-29-2008, 03:09 PM   #10
hEaT
I've seen a transmission snap the mounting ears where the lower mount connects using the stock mount. Has anyone noticed any increased stress or wear on the transmission using a mount this stiff compared stock or even the VF/MAC?
Tuned By: Bristol Dyno
Old 04-29-2008, 07:45 PM   #11
tparker
I have broken the stock bushings, the MAC bushings out and now the VF bushing have broken out of my current mount so I am going to get one of these next and see how it lasts.
No signs of wear on trans or subframe.
FS/VF SC w/IC blow thru mod
13.495 @ 102.306 best 1/4 current set up.
July 06 FOTM
My Focus Web Page
JCM Racing #10
tparker is offline   Reply With Quote
Old 05-01-2008, 10:18 AM   #12
hEaT
Thanks tparker. If there's no wear on your can then I'm pretty sure I'll be fine.
Old 05-01-2008, 02:43 PM   #13
OmniFocus
We've had somewhere between 400-600 clutch-dump launches on our FSP car with 275 Hoosier tires, and the first failure was an axle.... so I think this puppy will last.
Old 06-07-2008, 12:54 PM   #14
5speedZX3
Hey guys at massive, I just installed my new mount that I got from you. It was on back order so I had to wait a week or so. Anyways You may want to check the new batch you received. I was having a really hard time getting the tranny side of the mount in, so after pulling it back out I attempted to slide just that end into the tranny side and the metal spacer in the bushing was a bit to big. I had to press out that spacer and grind about 1/16in off for it to slide in place.
Just thought Id let you know so you cant check what you have in stock to be sure someone else doesn't have the same issues
2004 Black ZX3
Volant w/scoop, FC TB, FC UDP, Borla cat-back
98 Euro front bumper, ST170 headlights, Euro Grilles, Sportsline drop, 18" Velox VX-8's, Tinted tails
SVT interor swap(Red), Custom KPH red/black gauge face, a little ICE
5speedZX3 is offline   Reply With Quote
Old 06-07-2008, 09:30 PM   #15
focalized31
Ordered mine last week should be here by tues. or wed.
BTW i broke my Mac so lets see how this one holds
Team SPEEDLINE !!!
focalized31 is offline   Reply With Quote
Old 06-08-2008, 04:34 PM   #16
smokethebear
I've had mine for about six months now...
The motor vibrates all of my interior loose at idle (ESPECIALLY with the a/c on), but I love it. The 1-2 shift at high rpm is actually all fun now, rather than wondering if I slammed the block into the firewall again. It's really stiff. It's also at least 30 bucks cheaper than any other option you have, so it was a no-brainer for me, extra vibes or not...
I almost never use my a/c anyway. It's the 8th of June and it's barely reaching 70 degrees here . I love southern California...
Originally Posted by Honda Hunter
Deeze wheeels bing demm hoes to da cwieb ASAP.
smokethebear is offline   Reply With Quote
Old 06-10-2008, 09:09 PM   #17
focalized31
Just got my MSS UNBREAKABLE Mount.. When i open the boxed i was like WTF It was huge! LOL almost twice the size of my broken Mac. hahah!
Either way very simple install, took about 10mins, id like to thank Karl at the ppl at MSS very quick an relieable service. Theres only one thing i have to complain about
No MSS sticker in my delivery HAHAHAH
Cant wait to do business again guys NEXT? Pistons an Rods w00t!
Team SPEEDLINE !!!
Old 07-14-2008, 12:49 PM   #18
Dads03SVT
I just ordered one...wonder if i need to go old school and bolt in a log chain so it can't flex?? LOL
Dads03SVT is offline   Reply With Quote
