| Massive Speed System The Midwest's Focus Power Source
www.massivespeedsystem.com |
#1 (permalink) |
A must for your hardcore engine build. Another Massive exclusive!!! No one else offers these for the Duratec!!!
The torque from a properly fastened cylinder head can impart significant distortion to the bore. Rings do not seal properly and scuffing is often the case if the engine overheats. By installing the Massive Absolute Torque Plate, these problems are non existent, leading to more consistent tolerances, better sealing and more power. This plate is torqued to the identical specs while it is being machined, thus reproducing the exact same forces. This will ensure the truest machining for the best ring seal. Made in house in the USA of 3" pure 6061 aluminum (most representent of the aluminum head is mimics). 90mm Bore size allows for ample tool space and over sized piston applications. 4340 steel inserts at dowel locations ensure long service life and accurate locating every time. Holes are countersunk allowing usage of any OE of aftermarket head bolt/stud. Plate is clearanced so pressed on water outlet on block need not be removed to mount. Massive M logo engraved on top so folks know you use the best. Anodized Massive Purple for extra wear surface durability and handsome good looks. No hardcore Duratec race shop should be without it!!! ![]() $697 find it Here
Never interrupt your opponent while he's making a mistake. ![]() www.massivespeedsystem.com -The Midwest's Focus Power Source- |
#2 (permalink) |
Ok PLEASE forgive me, but where does this go and is it a permanent application.
Any dyno numbers yet? I thought It was an intake spacer at first. My guess now is it is a bore extension of some sort. |
| Thread Tools | |
| Display Modes | |
