Go Back   The Ford Focus Forum | Powered by Focaljet > Focaljet Premier Sponsors > Massive Speed System
Old 10-13-2009, 09:35 PM   #1 (permalink)
focusonfocus's Avatar
Default msx 90..??
i got msx90 in orange 5 months ago from you, and i m now having problem misfiring..it was working fine until today..
i thought water got into it but wasn't..
i tried to measure resistance but what resistance should i see??
when i measured it,
#1 800~900 ohms
#2 around 600 ohms
#3 around 400 ohms
#4 around 200 ohms
can you share spec of each wires please??
Advanced MECP certified mobile installer
2000 Kona Dirt.
www.cardomain.com/id/focusonfocus
focusonfocus is offline
Old 10-15-2009, 12:59 PM   #2 (permalink)
Default Re: msx 90..??
bump??
2000 Kona Dirt.
Old 10-15-2009, 01:10 PM   #3 (permalink)
K STYLEZ's Avatar
Those are correct.
K STYLEZ is offline
Old 10-15-2009, 01:13 PM   #4 (permalink)
oh ok..then do you think coil pack might cause the problem misfiring??
when i ordered, it was missing 1 spacer, so i mounted with 3 spacer only..
that might cracked coil pack??
2000 Kona Dirt.
Old 10-15-2009, 01:22 PM   #5 (permalink)
K STYLEZ's Avatar
Could be. I would take it off and inspect. Also take a look at the plug from the car itself. The plugs and the wiring going to them are prone to failure.
Look at the plugs too. Found a cracked porcelain insulator on one of my cars just yesterday.
Also - did u remove the extra gasket from the coil pack 3 prong plug?
K STYLEZ is offline
Old 10-15-2009, 01:35 PM   #6 (permalink)
if it is cracked, is it covered under warranty??
and also the wires??
when i first mentioned about it as soon as i got it, you've told me it is fine to use 3 spacers..
yes i removed extra gasket and used 1 only, i don't remember but i think i removed factory side and used what it came with..
2000 Kona Dirt.
Old 10-15-2009, 04:03 PM   #7 (permalink)
K STYLEZ's Avatar
Sure, I could get it covered. Wires sound fine though.
I dont recall telling you that, as I have seen that happen before. But you never know. Maybe I forgot my anti-DID (Dissociative Identity Disorder) pills that day. I always seem to get them mixed up with mentos.
K STYLEZ is offline
Old 10-15-2009, 07:10 PM   #8 (permalink)
here is post
http://forums.focaljet.com/massive-s...0-gapping.html
and i will take a look at coilpack tomorrow and see if i can find any crack..
if it is coil pack, it is still covered under warranty right?
i m going to order few some more parts too..and you can send me extra spacer and screw right?
i will let you know tomorrow..
2000 Kona Dirt.
Old 10-16-2009, 10:10 AM   #9 (permalink)
K STYLEZ's Avatar
Well, I did say "for now".
So you should not have run it that way for 5 months. But I can warrant it for you.
K STYLEZ is offline
Old 10-16-2009, 09:44 PM   #10 (permalink)
checked it and don't think it is coil pack, i didn't see any crack..
or is there any way i can check for internal??
checked wires, it might be the problem
if there is crack in wires, it shrinks and expands when hot right?
it happens when engine is cold..after warm up, misfire seems to go away..
but i will go ahead and replace new spark plugs and see if it fixes problem..
i will let you know on monday or tuesday..
2000 Kona Dirt.
Old 10-20-2009, 09:52 PM   #11 (permalink)
hmmm..here is an update..
when it happened, weather was close to..0 celcius..
oct 18th, weather got warmer close to 10 celcius..
and never had this misfiring issue..
but i put new spark in it today because i didn't want go back to dealer to return..
only thing i could notice was a bit smoother idle..
changed from regular motorcraft spark plugs to motorcraft platinum..
i will have to wait until weather gets cold..and will let you know again..
1 last question, should i run something 1 step colder plugs with this setup??
2000 Kona Dirt.
Old 10-21-2009, 09:06 AM   #12 (permalink)
K STYLEZ's Avatar
With just the swap of the coil pack and wires, stock heat range is fine. If you have a few other mods, 1 step colder could be beneficial.
K STYLEZ is offline
Old 10-24-2009, 06:14 PM   #13 (permalink)
it happened again..
it happens when rains hard overnight and misfires the next day..
sounds like i got serious high cam..i have to keep it above 2k rpm but when engine gets normal temp, runs fine..
and this goes away completely and idles normal after 5~7 days..
how do i do this warranty thing??do i pay for shipping?
2000 Kona Dirt.
Old 10-28-2009, 07:50 PM   #14 (permalink)
umm hello..??
2000 Kona Dirt.
Old 10-28-2009, 09:39 PM   #15 (permalink)
K STYLEZ's Avatar
Go ahead and ship it back
K STYLEZ is offline
