Perfect Circle Autosport
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    TEAM Member VonKaiser's Avatar
    Dec 2009
    Little Elm, TX
    238
    Default Picture guide for taking off door panels
    I checked the how-to forum and searched the forums itself and found nothing. I need a good guide with pictures on how to remove the door panels. Anyone?
    2013 Ford Focus SE Sedan
    2012 Ford Fusion SE I4
    2007 Mazda RX-8 <-- SOLD on 7/13/2012
    2003 Mercury Mountaineer V8 <-- The Daily <-- SOLD on 2/2/2013
    2003 Ford Focus SVT ZX5 - Infra Red - #604 <-- SOLD on 2/1/2012
    1990 Chevrolet Camaro RS V8
  2. #2
    [FJ] Special Ed. LornesBored's Avatar
    Nov 2004
    West Van, BC, Canada
    8,292
    Default Re: Picture guide for taking off door panels
    should be pretty easy, tonnes of them are clipped in. I know someone will chime in, but you should be able to pry out the cover on the grab handle where a couple of screws may be, look all around the door panel, if no screws, pry it off. I've never taken a door panel off of a focus, but they are all generally very easy.
  3. #3
    TEAM Member SVT0209's Avatar
    Jul 2009
    NOR.CAL TRACY
    465
    its real easy
    2K4 SVT EAP# 1131 - Powerworks
    2K14 Turbo Veloster
    2K4 Kawasaki ZX6R
    AKA volcomstone1966
  4. #4
    Senior TEAM Member slipster17's Avatar
    Jul 2006
    Baltimore, MD
    4,285
    1. There is one torx screw in the alcove behind the door latch. You need to pop off a little screw cap to see it. Remove that and extract the screw.
    2. The bezel around the door latch and switches is held on with pressure clips. Work your fingers into the front edge of it and pull gently, working your way back as the clips come undone. I believe there are 2 at the leading edge of the door and 1 to the rear of the door latch.
    3. Using a small screwdriver, stick it up into the two small holes beneath the grab handle in the middle of the door. There is a cover inset into the front of it that you need to pop off. If you work that small screwdriver around a little bit you should be able to raise the insert enough to get your fingers under it and pull it free.
    4. There are several torx screws around the outside edge of the panel where it meets the door. Remove all of these. They are the same size as the torx that was behind the latch.
    5. There are 2 bolts behind the grab handle that can be reached now that you removed the insert. They require a small socket with a nice long extension to reach. I believe they need a 6mm socket?
    6. Once you've removed all the torx screws and the two bolts, the panel should move fairly freely. There may be one or two pressure clips in the rear doors. Remove the panel by pulling it towards you and then up. There is a small lip in the window channel that you need to clear.
    And that should be about it!
    April 2010 FF ROTM
    2011 Yellow Blaze Metallic SES Fiesta hatch
    Carlisle AFN 2011 & 2013 1st Place - Fiesta Class
    FR '11 Winner - Best Fiesta
  5. #5
    Nov 2004
    8,292
    why do you need to remove the switches bezel? it's probably not necessary unless it somehow screws into the door, you can remove it all as one piece then unplug it when you are taking it off.
    just one less step, also prevents possible damage and chipping of pieces with a sharp screwdriver.
    if you can (and if you have it) use something made of plastic to pry on these pieces, also, try to use something that is skinnier and can do less damage than a flathead screwdriver, with more of a surface area thats used to pry, so you dont crack and damage parts.
  6. #6
    Nov 2004
    8,292
    meh I would say its all down to preference, if you are experienced in taking them off you can leave them all on, really just depends on the door design, where if you can take the wiring out without removing the bezels, you do it.
    I've been doing it at work, door panels don't weigh a hell of a lot, won't be too too much strain on the wires, and if you are really that concerned, get a jack and put a cloth on it to hold it up. I guess thats just me though, where I am working we only deal with '02+ Euro cars and I can't damage or chip a single thing or everything gets replaced and replaced out of my ass
  7. #7
    Jul 2006
    Baltimore, MD
    4,285
    Quote Originally Posted by LornesBored View Post
    It's really a convenience thing with the Focus door panels. The door latch is actually half behind and half in front of the switches bezel (if you see it on the car that will make sense, I swear!) and is affixed to the door itself, not the panel you'll be removing. So, if you don't remove the switch bezel then you'll need an extra set of hands to pull on the interior door latch so that you'll be able to get the panel off from around it.
    With the switch bezel removed, there is a nice large open space for the latch to fit through during the removal process and you can leave it attached to the door.
    April 2010 FF ROTM
  8. #8
    Jul 2006
    Baltimore, MD
    4,285
    Quote Originally Posted by FordFociSHO View Post
    7. You'll have to remove the trim over the mirror adjuster (manual or power). It pops off and is held on by 3 friction clips. Work from the window side to the front. The 2 clips are on the window side, running parallel with the window, the 3rd is just under the adjuster and runs perpendicular to the window.
    Yes! Good call. Forgot about those little buggers on the front doors.
    April 2010 FF ROTM
  9. #9
    Dec 2009
    Little Elm, TX
    238
    Good info guys, but no one has any pics? I like to see what I would be doing before I do it. lol
  10. #10
    I steal money from other Focal Jetters
    Jan 2010
    Back from sayin' "hi" to Allah and his peeps
    230
    Seriously, Kaiser, it's easy as can be. I just removed all four door panels on my car, was able to do it all in about 10 minutes per door.
    Remove all of the torx screws around the edge of the door, there is something like 6-8 of them. Remove the torx screw from behind the door latch release handle (covered behind the aforementioned plug). Remove two bolts from behind the door handle itself (not the latch release handle, but the handle for closing the door). They are behind the removable cover on the inside face of the handle itself. For the front doors, remove the interior mirror cover trim that is forward of the window, and if you have a four-door (or five-door hatchback), remove the trim panel there.
    If you want, you can then remove the door lock/window switch bezel, but I didn't find it necessary. You can simply unplug the harness from the switch. Once you have all of the bolts/screws, lift the panel carefully from around the window, since that is really the only thing holding it in place. It should slide up with minimal resistance. Once the panel is out of the way, that's when you can unplug your wiring if so desired. Be careful when you remove the panel, remember that the door latch release handle is still feeding through the door, so slide it up and forward to clear the release handle.
    2003 SVT Focus, very lightly modified at this point.
  11. #11
    Dec 2009
    Little Elm, TX
    238
    Ok then I'll take your word for it and check it out.
  12. #12
    Jan 2010
    230
    Just take it carefully. Patience is the name of the game, because if you can't get it to come relatively easily, something is probably wrong! But yeah, have fun, these are good times!
  13. #13
    Mar 2006
    478
  14. #14
    Feb 2010
    Orange County
    24
    I have always used a wide trowel...the kind of thing you would use for moving around drywall mud or plaster. I tape the end with some shipping tape to protect the parts from any scratches. Works a treat for prying apart plastic panels held with friction clips!
  15. #15
    Senior TEAM Member Lancer211's Avatar
    Mar 2009
    Tucson, AZ
    3,294
    Quote Originally Posted by slipster17 View Post
    It's not a huge deal to leave the bezel connected, though. You merely have to open the handles (like you're opening the door) when you reposition the door trim.
    That having been said, I always remove the bezel anyway.
    04 ATX Zetec sedan, FSW Cool-Flo, e2kIM, ported TB, header, TruBendz exhaust, SVT suspension, Steeda RSB, SVT FSB, FSW tune
    32" HDTV posted in Garage Sale!
    CarDomain Page
