Tasca Auto Group
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Senior TEAM Member SuperFlea's Avatar
    Jan 2006
    Fixing Something!
    4,285
    Default Rear Wheel Bearing Replacement --> How-to
    I had to replace my rear wheel bearings and decided to take pics and make a how-to, since i wasn't able to find anything specific to what's included or how the process is done.
    On the scale of 1(easy) to 10(hard) on the easy / hard scale, i would rate this a 4. It's actually very simple and it's not too much time consuming.
    The way i knew i needed to replace my wheel bearings was because they were producing a humming/grinding sound when the car was in movement. Of course the loudness of the noise consists of how deteriorated the bearings are. In my case, my driver's side was the culprit [xx(] . The passenger side was producing noise as wheel but not as bad as the other.
    You can also check them by raising the car and grabing the wheel and try to move it from side to side, up and down. If there's any movement, there's a chance they might need to be replaced. Although this isn't a sure way to know if they're bad.
    In any case, it's good practice to replace both sides at the same time. As well for the front.
    Process Time:
    • 45-60 minutes (took me only 30 minutes for the removal and installation and i had all except one tool at hand).
    Cost:
    • $ 85 for the bearing kit.
    • $ 10 for the shop that helped me press in and out the bearings.
    Tools:
    • 13mm wrench
    • 15mm wrench
    • 19mm deep socket
    • 30mm socket
    • 1/2" Socket wrench / rachet. (i used a handle wrench)
    • Rubber mallet (or hammer)
    • Flathead screwdriver
    • Car Jack (I used a large 2 ton jack)
    • Thread lock (for bolts)
    • C-Clip remover pliers
    • A Press (this isn't a tool that you would normally have around in your house, so if you don't have one, just take it to a shop and have them do this job for you)
    Some of the tools i used -
    To get started chalk your front tires (prevent the car from moving in any direction when lifting it with a jack).
    Before i raised the car i loosened the rear wheel lug nuts, just enough to be able to take them off when the car is raised. Raise the rear of your Focus using a jack, or if you have access to a lift, even better.
    Support the car on jack stands on both sides.
    NEVER WORK ON A CAR THAT IS NOT PROPERLY SUPPORTED ON JACK STANDS OR JUST SUPPORTED ON THA JACK ITSELF! -
    Now remove the rear tires. I have a tendency to place them under the car so in any case the car would to fall of the stands, it will fall on the wheels and not crush you're arse while working under it! Of course, if that were to happen, it would F' up your wheels . -
    I went ahead and removed the dust cap from the hub, while i could still use the parking break, thus it wouldn't spin while i was banging it. I used a flathead screwdriver and a hammer to remove it -
    And i also loosened the hub retaining nut afterwards (just loosened it a bit). Of course this won't spin, so you may do this after removing the calipers and rotors. But i went ahead and did it anyways. -
    Using a 13mm and a 15mm wrench, remove the bolts holding the caliper in place -
    You may also want to unhook the emergency brake cable for more movement -
    Remove the brake caliper and set aside -
    Remove the brake pads from the rotors and set aside. This is also a good time to inspect them for unusual wear and replace if needed -
    Remove the caliper-holding bracket using the 13mm wrench. It's held by 2 bolts behind the spindle -
    Set the bracket aside. You may also want to screw the bolts in place, to prevent from loosing them -
    Remove the rotors -
    Now you can continue with removing the hub retaining nut using the 30mm socket -
    Remove the hub from the spindle -
    My baby during the install -
    Remember to replace the rubber seal that goes on the spindle. This prevents from water or dirt to enter into the bearing -
    Now, onto the hubs.
    Remove the ABS sensor ring -
    Remove the water seal carrier -
    Using the C-Clip pliers, remove the C-clip (or Circlip) from the hub -
    Like stated above, i don't have a press, (yet ) so i took both hubs to an alignment shop and had them press out the old bearings and press in the new ones -
    Just by looking at the used bearings, you can't really notice the damage unless you spin them. You can feel the wear on them -
    Install the water carrier seals and the ABS sensor rings back on the hubs. The kit i bought came with new ABS sensor rings and water seals -
    Remember to clean the spindles before installing the hubs in place. Inspect for any corrosion and replace if needed -
    Install the hub in place and screw on the retaining nut. Tighten the nut to 174 lbs-ft (as the instructions that came with the kit stated) -
    Install the dust cap (The kit came with new caps, plus i damaged mine upon removal) I was having a hard time installing them into place, so i had to use a little brute force . Hence the marks on the cap -
    Install the rotors into place -
    Install the caliper bracket back into place and tighten the bolts to 52 lb-ft (as stated in sheet that came with the kit). Install the pads and the caliper into place, tighten the caliper bolts to 41lbs-ft. Remember to hook the emergency cable back up. It's also a good ides to use some thread lock on the bolts -
    Before installing your wheels, be sure to double check everything, just in case
    Install your wheels back on the car. Tighten the lug nuts to 95 lbs-ft.
    You're good to go. Test drive the car starting at a low speed and accelerating from there.
    Hope this helps you out. If i missed something or need additional help, please feel free to let me know. You can pm me or post here!
    Enjoy!
    I <3 My Wagon!
  2. #2
    TEAM Member covert1's Avatar
    Sep 2000
    Columbia, MD
    732
    Default Re: Rear Wheel Bearing Replacement --> How-to
    I take it you've got a ZTW with advancetrac. Can you post the part numbers for the items you purchased, if you still have the info? The same stuff would apply to my ZTW. Nice work.
  3. #3
    Jan 2006
    Fixing Something!
    4,285
    Thanks Mister!
    I don't have advancetrac, it's the rear SVT set-up but it's just about the same. I did a swap about 6 months back. I'll look for the part numbers.
    I <3 My Wagon!
  4. #4
    NA Zetec Driver //// Where Bolt ons + Cams = 120whp
    May 2005
    Marysville, MI
    5,338
    ill take messed up wheels over messed up face anyday i sometimes do the same
    good write up. i have drums and did pretty much the same minus the caliper stuff
    Proud member of the 165k+ mile club
    Proud Member of the SE Mich Crew! MI > MN
  5. #5
    Jan 2006
    Fixing Something!
    4,285
    Yeah, it's way safer!
    So, the're really not much of a difference when doing the drum brake set-up, cool!
    I <3 My Wagon!
  6. #6
    Aug 2003
    Tampa Bay, FL
    281
    This should be a sticky!!
    2003 Pitch Black Focus SVT
  7. #7
    Jan 2006
    Fixing Something!
    4,285
    x2 ^^^
    I <3 My Wagon!
  8. #8
    Jun 2006
    Evansville, In
    476
    old post but my help me on wrkn on my car after today..lol
    I spend money
    I don't have.
    To buy things
    I don't need.
    To impress people
    I don't know.
  9. #9
    Senior TEAM Member Mabolzichjjl's Avatar
    Oct 2009
    Ft Riley, KS
    1,475
    sticky? or is in the suspension reference thread?
    Recycle your animals
  10. #10
    f91
    f91 is offline
    Junior Member f91's Avatar
    Dec 2010
    Port Orchard, WA
    81
    Replaced both rear drums, bearings, brakes and 1 spindle today....
    '04 zx3
    2.3 L-ATX
    FSwerks CAI
    SVT suspension
    Focus sport Strut bar
  11. #11
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,825
    Quote Originally Posted by Mabolzichjjl View Post
    It's in the reference thread
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
  12. #12
    TEAM Member jbswear's Avatar
    Jun 2010
    Maryland
    384
    I was just shown this today. Thanks to theindustrialist for allowing me to DIY and save a few hundred in labor!
    Semper fi,
    Brad
  13. #13
    TEAM Member jonny.burns.g1's Avatar
    Oct 2010
    lakewood, oh
    877
    rather keep this in a topic of wheel bearings for svt swaps... Can I re-use a spindle that has a scratch on it? its at the end close to where the threads begin?
    https://picasaweb.google.com/1158639...02931808597794
    I dont think you can embed picasa pics... Ill put them on my flikr later if that link doesnt work so I can just embed it.
  14. #14
    Oct 2010
    lakewood, oh
    877
    btw do you remember where you got your bearings at? I would love to get them in a kit like you got.
    Thanks,
    Jon
  15. #15
    Oct 2010
    lakewood, oh
    877
    Good News, Boss says it should be just fine as long as the hub is ok when i take the bearing out. The spindle just holds the bearing in a horizontal plan and as long as the bearing fits over the spindle without getting hung up on the scratch it will be fine. Still need that info on wheel bearings though pawease.
