FJ Gear Store
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Jun 2001
    Everett, WA, USA
    717
    Default How do I drill out my faulty ignition lock cylinder?
    Well, after very little warning, my ignition lock seized. It's time to replace it; since I can't get the key into position 1, it looks like I'll have to drill.
    </font><ul type="square">[*]<font size="2" face="Verdana, Arial">How should I go about drilling out the cylinder?</font>[*]<font size="2" face="Verdana, Arial">How big a hole (diameter) needs to be drilled?</font>[*]<font size="2" face="Verdana, Arial">After I get it out, does the new cylinder just drop in?</font>[/list]<font size="2" face="Verdana, Arial">
    [size="1"][ 02-17-2003, 01:35 PM: Message edited by: Bantha Fodder ][/size]
  2. #2
    Oct 2002
    Toronto
    329
    Default Re: How do I drill out my faulty ignition lock cylinder?
    heres a tip, tow it to the dealer, especially if you have warranty. because you can call road side assistance to tow it for free. the only reason I suggest this is because if you drill in the wrong spot, or drill too far, you will drill into the steering column, and you will have to replace the whole steering column.
  3. #3
    Jun 2001
    Everett, WA, USA
    717
    No, at 45k miles, my warranty's long gone. I'd rather do it myself, since I'm not terribly happy with the dealers in my area, but if it's really that dicey of a situation, I'll take it in.
    Any drilling tips?
  4. #4
    Sep 2002
    713
    try pm ing Red-Se-00 - he just had a bit of experience with this
  5. #5
    Jul 2002
    funky town
    2,902
    i should beaple to email or post them to you when i stop in at work today or tuesday.
  6. #6
    Jul 2002
    funky town
    2,902
    sorry i spelled wrong but i cant send it to you. whe have a print up detailing it. i could fax it to you. but try spraying penetrating lube in it and put the key in an out a bunch of times. it might free it up a little and you may be able to turn the key and get it all out with out destrying it.
  7. #7
    Jun 2001
    Everett, WA, USA
    717
    Yeah, I already tried that, and it helped a bit (at first, I couldn't even get the key more than halfway into the ignition), but I still can't turn the key.
    If you want to fax me something, I have an eFax number: 1-419-791-7614.
  8. #8
    May 2001
    Signal Hill WHAT!
    364
    this just happened to me last thursday. I have 67K on my car and roadside towed me to the dealer for free [img]images/icons/grin.gif[/img]
    The dealer replaced it in a day, but i'm still waitin for the airbag to be fixed [img]images/icons/frown.gif[/img]
  9. #9
    Jul 2002
    funky town
    2,902
    tuesday you will get a fax then
  10. #10
    Jan 2001
    358
    <font size="2" face="Verdana, Arial">Read this
    Be prepared to pay big bucks if you make a mistake with the drill.....
  11. #11
    Sep 2002
    Janesville WI
    1,175
    i haven't seen what the focus key mechanism looks like but usually there is some sort of device that holds the cylinder in and keeps it from falling out a pin a lip something once this is removed or released the cylinder should come right out but like i said haven't delt with the focus cylinder yet just my 2 cents
  12. #12
    Jul 2002
    funky town
    2,902
    you will get my fax tonight. it is 13 pages
  13. #13
    Jul 2002
    funky town
    2,902
    ok i tried to fax them to you but the call would not go through. what is an efax? i have a regular fax machine. are you sure the number you gave me is correct?
  14. #14
    Jun 2001
    Everett, WA, USA
    717
    eFax is an internet fax gateway that will accept faxes and convert them to emails and send them to me. I'm not sure how thorough their service is, however (it's free), because this has happened before.
    I'll find out the number for our fax machine at work and PM you with it.
  15. #15
    Dec 2000
    irvine,ca,usa
    142
    when this happened to my car ford payed half of the cost cause they said it was a common problem it cost me 50$ maybe you should ask about that
