Tasca Auto Group
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Sep 2000
    Yonkers
    3,849
    Default **Rear Wheel won\'t come off hub!**
    I'm trying to take my wheel off and it's been at least an hour now (with breaks in between of course).
    I've sprayed ALOT of WD40 over the time but nothing has happened.
    Any advice guys?
    I haven't taken them off since before winter so I'm sure it's just molded on to the hub by all the debris and mud and what not that the car got over the season. But none of the other tires gave any problems! [img]images/icons/confused.gif[/img]
  2. #2
    dlb
    dlb is offline
    Sep 2001
    Ottawa
    8
    Default Re: **Rear Wheel won\'t come off hub!**
    Its obviously "frozen/rusted on" - I had the same problem. You may have to bring it to a shop and have a mechanic "hit" it from underneath the car. My guy used a long crow bar and wedged it off. Lesson learned - put a small amount of lube on the hub so this will not happen again. Imagine if you got a flat on the road and had to remove this tire [img]graemlins/rant.gif[/img]
  3. #3
    Jan 2001
    fullerton, ca
    292
    hit it from the inside with a rubber mallet, or if you have it securely on jack stands you could try to kick it off from under the car.
  4. #4
    Apr 2003
    Sofa king we todd did Ventura CA
    556
    It happened to me too I just put it down on the jacks sat down on the ground and kicked it real hard on the edge of the rim
  5. #5
    Jul 2002
    funky town
    2,902
    kick it or wack it with a rubber mallot
  6. #6
    [FJ] Specialist BowDown's Avatar
    Nov 2001
    NY State SUCKS!
    7,351
    Kick it. Thats how i got mine off when the drum paint dryed it on! [img]images/icons/mad.gif[/img] [img]graemlins/lol.gif[/img]
  7. #7
    Nov 2001
    NY State SUCKS!
    7,351
    I don't suggest kicking it from under the car. Something wrong about doing that with jackstands!
    Just kick the tire on the wheel a couple good kicks... It will break right loose.
  8. #8
    Feb 2002
    Pittsburgh, PA
    1,574
    Yeah, I had this happen to me in January. I had to beat the **** out of it with a rubber mallet, but I finally got it off after about 15 minutes.
  9. #9
    Jan 2002
    Somewhere near you. . . . . . . . . .BOO!!!!
    58
    Put a loose lug on make sure you got it secure up in the air and Kick the S&%^ out of it
    Make sure to snd the hub and get some anti seze to brush on the hub
  10. #10
    Sep 2000
    156
    Loosen the lug nuts a turn and drive it around the block until things separate.
    Tio Barry
  11. #11
    Sep 2000
    Yonkers
    3,849
    Thanks for all the advice.
    I've been trying the kicking thing too many times! [img]images/icons/mad.gif[/img] Thing just won't come off!!!
    Maybe I'm just not kicking hard enough but I'll keep trying.
    I'd much much rather kick it off but I guess if it comes down to it, I'll just bring it by the local tire shop...even though I'd must rather not because they'll probably try charging me for a BS task like this.
    Thanks again.
  12. #12
    Apr 2002
    kc,mo
    1,439
    had the same thing with my svtf used a mallett and hit the crap out of the tire/rim from the backside
  13. #13
    Jul 2002
    578
    <font size="2" face="Verdana, Arial">Just don't put too much on or it will spin off all over your rim!! Anti sieze isn't the easiest stuff in the world to clean off. A little bit goes a long way!
  14. #14
    Oct 2001
    Home
    4,983
    Did you get it off yet?
    I had the same problem a few months ago. Tried a rubber mallet, a 2x4 and a sledge hammer, crow bar, etc...You name it I tried it.
    I ended up loosening all four rear lugs 1.5 turns and then driving around the block weaving back and forth. It was the only way I could get the rear wheel off. When the wheel comes loose, you will be able to feel it. [img]images/icons/wink.gif[/img]
    I'm not kidding here either. I was at an auto-x a few weeks ago. A guy there with a Mini was having the same problem. He tried the loose lug nut thing and it worked.
  15. #15
    Apr 2003
    Houston,Texas
    86
    The Loose Lug thing always works. Like the time I rotated my tires and forgot to tighten my driver's rear tire, yeah, it came off at about 40 mph. That was not fun! Make sure you tighten them after reinstalling them. HAHA
