James Barone Racing
Results 1 to 11 of 11
    Mar 2004
    7
    Default where is the airbag control module?
    I am looking for the airbag control module because i am selling my airbags. I already got out the drivers and passengers airbags but i cant find the control module. CAN ANYBODY HELP? Also, is there a way to turn off the airbag light on the cluster? Thanks guys
  2. #2
    Oct 2003
    Maine
    1,758
    Default Re: where is the airbag control module?
    its under the center console. Why are you taking out your airbags?
  3. #3
    Mar 2004
    7
    The focus i am taking the airbags out of is actually just a show car and it is almost never driven. I replaced the steering wheel with a momo steering wheel, then decided to sell the airbags because i am looking into buying the tsunami front bumper. how can i get to the module? by center console, you mean like where the radio is or like where the emergency brake is.
  4. #4
    Oct 2000
    In ur srvrz patchin ur krnlz
    6,880
    I believe it's near the e-brake handle, under the plastic console. I could be wrong though. As for the AirBag light, gotta take apart the cluster and pull the bulb, as I think even with the controller removed, the light will stay on. I could be wrong though.
  5. #5
    Nov 2001
    Tampa, FL
    308
    the light isn't as easy as removing a bulb, you have to take the cluster apart and cut/desolder the LED.
  6. #6
    Mar 2002
    Herndon VA
    1,831
    or do what i did and USE THE MAGIC BLACK TAPE.. that stuff works wonders
  7. #7
    Feb 2002
    Northwest
    3,212
    It is under the cup holder cluster between the front seats, between the shift lever and the e-brake.
  8. #8
    Mar 2004
    7
    Well took everything out and it was right between the shifter and the e-brake. THANKS GUYS!!! And i might have to just put tape over light. At least now I can get all the interior pieces painted before i put them back in
  9. #9
    Nov 2004
    New York
    68
    Quote Originally Posted by Welding Rod View Post
    Digging up a way-old thread here as it seems to answer my question best. The only thing I'm wondering is whether this location still holds true for a 2005. I've learned that the 2005-07 has a different airbag control module (RCM), so I thought it would be worth verifying that the location didn't move.
    Any tips on removing the center console? I only found one post indicating that it was "really difficult".
    Brad
  10. #10
    Senior TEAM Member bflesher's Avatar
    Aug 2010
    Minnesota
    2,383
    The center console on the floor is easy to remove, are you thinking of the center console on the dash as in this http://forums.focaljet.com/mk-i-inte...r-console.html ?
  11. #11
    Nov 2004
    New York
    68
    Quote Originally Posted by bflesher View Post
    Okay, thanks - haven't even given it a glance yet, so good to know it won't be difficult.
    Brad
