MFactory Competition Products
Results 1 to 7 of 7
    May 2004
    Vega Baja, PR
    434
    Default Car sputters when AC fan turned on.
    My friend has an 01 ZX3 and when he turns on his A/C his revs drop down to about 450-500 when the fans turn on and the car is idling. What could be causing this problem?. Another thing is, his car starts to heat up when the A/C is not on. If anyone can shed some light on these 2 problems I would appreciate it. Thanks.
  2. #2
    Jul 2002
    New Braunfels, TX
    10,540
    Default Re: Car sputters when AC fan turned on.
    if the car is heating up without the ac on then that probablly means the other fan isnt working.
    the idle dropping could be related. typically the IACV opens further when the ac is on so that the engine can maintain its idle speed under the extra load of the AC compressor.
  3. #3
    May 2004
    Vega Baja, PR
    434
    Both fans are working when the A/C is on.
  4. #4
    Jul 2002
    New Braunfels, TX
    10,540
    does the other fan come on at all when its idling but the AC is off?
  5. #5
    May 2003
    Orlando,Florida Sunshine State
    204
    i seem to be having that same problem but only when foci is at normal operating temp,then goes further foci feels like it has no power almost like you missed a gear or two an thats without the ac being on .
  6. #6
    Jul 2002
    New Braunfels, TX
    10,540
    please start a new thread if you want help.
  7. #7
    May 2004
    Vega Baja, PR
    434
    No, it does not. I revved it for a while last night waiting to see if it would come on and nothing. Tomorrow we will check the main fan relay and see. I'll be testing a few options tomorrow with my foci and see if we can get to the solution. Keep posting possible solutions. Thanks.
