Tire Rack
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Like Tree3Likes
Thread: Rear hub nut size?
    Newbie
    Mar 2005
    1
    Default Rear hub nut size?
    Me and my wife just moved down to VA from PA, and I left most of my tools at my dads house. I was going to change my rear brakes on my 01 focus SE and need to know what size the HUB NUT is. Help would be great.
  2. #2
    Oct 2000
    In ur srvrz patchin ur krnlz
    6,880
    Default Re: Rear hub nut size?
    you don't need to pull the hub nut to do the rear brakes. You can just un-do the 4 bolts on the back and the whole spindle, bearing, and drum will come off. It's really a lot easier to do it this way if you're doing just the shoes and not replacing the whole drum.
    This page shows the rear brake disassembly in quite a bit of detail:
    http://www.focushacks.com/index.php?modid=48
    427Sparky likes this.
  3. #3
    Dec 2002
    South Texas
    535
    Okay so I've messed up now. I looked for info after I did it. Could have saved some time and done it correctly but now I have to fix what I may have done.
    I've already removed the rear axle nuts and inspected my brakes. I'm going to have to get some brake shoes but it's okay for a few more miles.
    What's the correct torque for the axle nut and should I replace them. I had no problem with them. I just didn't know about the removable spindle. I'm just doing slow local driving for the rest of the week but I have to get on the highway again Friday.
    Is removing the spindle really the Ford recommended procedure?
    Louie.
  4. #4
    Oct 2000
    6,880
    Louie.
    IT is in my CD-ROM service manual!
    Unfortunately I don't have it here with me, it's at work, so I don't know what the torque spec is.
  5. #5
    Jul 2002
    New Braunfels, TX
    10,540
    hub nut is 32mm and the torque spec is 173 ft/lbs
    Mile30 likes this.
  6. #6
    Dec 2002
    South Texas
    535
    173ft/lbs! It was no where near as tight as that when we took it off. My torque wrench won't even read that high.
    The rear bearings were serviced as part of a recall last year(or the year before) so Seguin Ford must not have tightened them very much. Either that or they loosened up by themselves. I guess I'd better look for a torque wrench and tighten them up a little more.
    The other question was are they re-usable. I have to take care of this quickly. Last Friday I had the car up to 120 mph on a twisty farm road trying out the new speed limiter.
    Louie.
  7. #7
    Newbie
    Jul 2008
    2
    It's 29mm. I'm in the process of doing the rear brakes on my 2000 Focus SE and I tried the sockets I had. 29mm was what fit on mine. The proper procedure for removing the drums is to remove the spindle (there are 4 bolts behind the backing plate) and to disconnect the ABS wire from its connector.
  8. #8
    I Lost My Toy in Atlanta! glowin3232's Avatar
    Jul 2006
    Whorelando FL
    1,476
    I agree with the 29mm, that is definately the size I used to change my rear brakes. 32mm is too big.
    The rear axle nuts are only recommended to be reused 3-4 times. I replaced mine with new nuts the last time I had them off because I had already taken them off once, and I have no clue how many times the previous owner of my car had the nuts off. New nuts were $8 a piece from my local Ford dealer parts department.
  9. #9
    TEAM Member Terry1's Avatar
    May 2006
    Riverside,R.I.
    926
    So the front and back are different sizes ? I just worked on my front and it is 32mm.
  10. #10
    Jul 2006
    Whorelando FL
    1,476
    I guess that may be the case, I dont believe I have taken my front axle nuts off yet, so the fronts may be 32mm. My focus is a 2000 as well, what year is yours?
  11. #11
    May 2006
    Riverside,R.I.
    926
    2001, I did the back brakes taking off the four bolts. I never touched the hub nut. * Anyone doing back brakes, take shock off. It's much easier working than working around it. I took the bottom off and should have removed the whole thing.
  12. #12
    Nov 2007
    117
    So, the winner is 29 MM for the rear spindle nut?
  13. #13
    Senior TEAM Member sonicblu3zx3's Avatar
    Oct 2004
    Gastonia, NC
    2,120
    Are we sure the torque spec is 173 ft./lbs?
    JCM Racing #316
    2005 Sonic Blue ZX3
    K&N Typhoon CAI, FS 2.25" exhaust, F2 V3 header, ST200 wheels with BFG G-Force Sports (215/45/17), SVT rear bumper, Ford Racing Dynamic Suspension Kit, Progress 22mm rear swaybar, FC strut bar, RS wing, Vent visors, rear seat delete kit, interior upgrades
  14. #14
    Sep 2000
    Ottawa, Ontario, Canada
    472
    Just wanted to clear some things up for you:
    Front Axle Nut - 32mm
    Rear Axle Nut - 29mm
    Rear Axle Torque - 173 Lb/ft (yes, it gets cranked on).
    Front Axle Torque - I'm not sure, but it's up there too.
    Ford states that you can re-use the axle nuts a couple of times before replacing. I typically do my rear brakes by removing the axle nut. My spindle nuts (the "proper" way) are rusted and rounded so I've always gone with the axle nut for removal. I don't think I've ever re-used the nuts more than once, but I've definitely re-used them without any problem.
    Maybe it's better for the wheel bearing to remove the drum via the spindle bolts, but that seems like a bit of a stretch.
    2000 Twilight Blue ZX3
    2013 Performance Blue ST (CDN)
  15. #15
    ebe
    ebe is offline
    Newbie
    Mar 2010
    1
    I am doing the rear brakes on my 2001 ZTS. I have the new brakes on and got new drums as well. The old drum looks to have a hard rubber washer on the back of the drum. The new drum does not. Do I need the hard rubber washer or just put the bare metal drum on?
    Thanks,
