Tire Rack 2
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
    Feb 2004
    235
    Default Wheel Bearing Replacement
    Should I replace in pairs? Anyone estimate how many hours of labor?
  2. #2
    Aug 2004
    Gresham, Or
    231
    Default Re: Wheel Bearing Replacement
    When one goes, the other isn't far behind. I like to do it in pairs. Your going to need a press. If you have one, it should only take a couple of hours.
  3. #3
    Jul 2002
    New Braunfels, TX
    10,540
    front or back wheels?
  4. #4
    Feb 2004
    235
    Fronts - I wont be doing this myself though ( I dont have time)
  5. #5
    Jul 2002
    New Braunfels, TX
    10,540
    just need a press, 20 ton at least.
  6. #6
    Nov 2004
    104
    It isn't hard if you have any experience. Yes, replace both sides at the same time.
  7. #7
    Feb 2004
    235
    How do you get to the wheel bearings - through the front or back of the hub?
  8. #8
    Feb 2004
    235
    Went to the shop to have it looked at - they said it was the left rear wheel bearing. The noise is still heard but faintly now.
    Now my questions and concerns:
    I had the rear drums replaced last summer - If im not mistaken the rear drum assembly that I bought seprately (not from the shop) came with the bearings inside. How can a bearing go out in less than a year?
    I called ford seeing if I could have this replaced under the recall seeing that I only had the right wheel bearing replaced when i had the recall done. No luck there.
    I'm going to take it back to the shop that did the work since I still do hear a noise. If they come back with something else is wrong im going to tell them to refund me for the wheel bearing - since that was not the problem.
    The only thing I've done to the car recently is changed the power steering fluid. I did not take any hoses off or so on - just used a turkey baster to suck fluid out then replace it.
    Please help - I feel as I've been had.
  9. #9
    Sep 2000
    Ottawa, Ontario, Canada
    471
    Default Rear wheel bearings on the focus are my biggest problem
    I've had the rear wheel bearings replaced 3 times so far. I'd never had any problems until I went in for the recall.
    Approximately 4 weeks after I got the wheel bearing replaced under the recall the right rear failed.
    Approximately 10 months after I replaced the right rear the left rear failed.
    I bought new hub nuts for when I replaced by rear brake shoes. One of the nuts came with a locking mechanism, but I was unable to use it because my spindle was not threaded. I think they put the locking mechanism on to try and prevent bearing failure, but I'd need to buy a new spindle to use it. I thought that's what I'd get when they did the recall. I suspect the dealership screwed me.
  10. #10
    Senior TEAM Member bluebyutoo's Avatar
    Nov 2001
    Fayetteville, NY
    3,943
    Default Re: Rear wheel bearings on the focus are my biggest problem
    My front right just failed and I plan to replace it next weekend, anything I should know first?
  11. #11
    Feb 2004
    235
    People gotta stop hijackin' one -ok; but two?? Oh well
  12. #12
    Apr 2004
    Syracuse, NY
    2,538
    Who's hijacking? Here's your original post:
    And the title of the thread is "Wheel Bearing Replacement", after all.
    And first you said you were replacing the front bearing, then you said the dealership said one of your REAR bearings needs to be replaced. Every single post in this thread has been about wheel bearings, so I don't see what the problem is.
    So anyway...
    As TXFO already said, the rear bearings need to be pressed in. As I recall, he's had first-hand experience in the past with a cracked drum because pressing in the bearing without damaging the drum is a big PITA.
    As for swapping bearings in pairs, I see no reason to do so. If it ain't broke, don't fix it.
    I have no idea how long it should take to swap the bearings.
    For the front, I'd just get a new knuckle from FC - they're really cheap.
    Bill - I'll look it up on my CD, since I'm not sure what all is entailed in swapping just the bearing in the front.
  13. #13
    Apr 2004
    Syracuse, NY
    2,538
    Well, for the sake of closure, I figured I'd update this thread. Yesterday I helped Bill (bluebyutoo) replace one of his front bearings, and it was a pretty big PITA. It looks like the actual bearing replacement will be similar for the front and rear, but the preliminary steps should be simpler for the rear bearings, as it's much easier to remove the rear drum than to remove the knuckle at the front.
    Here's a summary of the rear bearing replacement procedure from my Ford service CD:
    Remove the dust cap.
    Remove the retaining nut.
    Remove the hub, being careful not to damage the wheel speed sensor ring.
    Remove and discard the ABS sensor ring.
    Remove the circlip
    Use a drift to press out the bearing
    Support the drum so the wheel studs are off the surface
    Use special tool 307-210 (17-041) to install the new bearing
    Install the circlip.
    Install a new ABS ring.
    Install the brake drum.
    For both the front and rear bearings, my Ford CD makes no mention of a press. Instead, it says to use a drift to remove the old bearings and to install the new ones. In practice, that sounds like a huge PITA, especially for the removal. To remove Bill's old bearing, we made use of a 20-ton press, an oxy-acetylene torch, and an air chisel, among other tools. Installation was a piece of cake by comparison, but you'll still want to use a press if at all possible.
  14. #14
    Feb 2004
    illinois
    1,270
    so is there a recall for the rear drum bearing? what state r u guys in? cause im having the driver side rear go on me and the passanger rear went months ago...they didnt mention a recall and i had to deal with the ish myself...just bought new drum n new bearing's an shaft...my tire almost fell of while i was speedin on the h-way...bearig completely melted and fell apart!!! anyway...curious about the recall cause ive checked the recall site and the dealer said nothing about it...
  15. #15
    That one was just me not paying attention....and sucking j20000's Avatar
    Mar 2005
    Pittsburgh, PA (But, San Diego at heart)
    7,509
    yes there is a recall on the rear hub bearings, I had both of mine replaced, the same thing happend to me on the highway, I thought I had a flat at first, but when I checked it out I realized it was the wheel bearing.
