Tasca Auto Group
Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
    Jul 2002
    New Braunfels, TX
    10,540
    Exclamation car wont start? click here! (troubleshooting guide)
    Won't turn over, won't click, won't anything:
    Is there power to the accessories?
    NO - power distribution problem. Verify battery is good and power is making it to the central junction box and fuse box.
    YES – continue
    Is the PATS light flashing rapidly?
    NO – continue
    YES – PATS problem. Key is corrupt or not programmed, reciever is damaged or disconnected. ECU is damaged.
    Is the Clutch in? (if equipped)
    NO – depress clutch pedal all the way
    YES – verify that the clutch switch is working properly by measuring resistance across the 2 wires when the clutch is depressed, should be 0 ohms, then continue.
    Is the transmission in Park or Neutral? (if equipped)
    NO – Move selector switch to Park or neutral.
    YES – verify that the lever is actually moving the selector switch on the transmission to park or neutral, measure the resistance of the safety switch when in park or neutral, should be 0 ohms. then continue.
    Do you have an alarm or lockout?
    NO - continue
    YES – verify that the alarm is disabled and the lockout is working properly.
    Is the grey wire near the coil pack connected?
    NO - connect
    YES – continue
    Is your engine ground less than 100 ohms?
    NO – add a ground wire from a lift point to the chasis or batt-.
    YES – continue
    Is there power to the starter?
    NO – repair broken wire or terminal.
    YES – continue.
    Is the starter grounded?
    NO - repair engine to chasis ground wire.
    YES - continue.
    Is there 12v on the key terminal when the key is in the "start" position?
    NO - check operation of the ignition switch, ignition relay, and fuse.
    YES - bad starter.
    Clicks, won't turn over or start:
    Are the battery terminals connected securely and corrosion free?
    NO – clean and secure the terminals
    YES – continue
    Will the car jump start?
    NO - continue
    YES – bad battery or charging circuit.
    YES – continue
    Will the rotating assembly turn freely?
    NO – engine is jammed or seized
    YES – continue
    Is the starter seated correctly?
    NO – seat properly and tighten bolts.
    YES – continue
    Does the starter motor turn when power is applied and load removed?
    NO – bad starter
    YES – have starter bench tested.
    Cranks, turns over, but won't start or run:
    Is there gas in the car?
    NO – buy gas
    YES – continue
    Are the spark plugs firing?
    NO – no signal from crank angle sensor or faulty coil pack/coil harness.
    YES – continue
    Can you hear the fuel pump whir for 2 seconds when the key is set to “on”?
    NO – look under the passenger side kick panel and verify that inertia switch is not tripped and is working correctly. Fuel pump problem if switch is ok.
    YES – use a fuel pressure gauge to verify that you are receiving adequate fuel pressure during cranking. Continue if ok
    With the oil cap off and a friend trying to start the car, can you see the cams spinning while the engine cranks?
    NO - Possibly a bad timing belt. Pull the timing gear cover off to check the belt and watch the cam gears. Replace belt if bad.
    YES - continue
    Are the injectors firing?
    NO – damaged ECU or no signal from camshaft position sensor. (could be a broken timing belt)
    YES – continue
    Is there adequate compression in all cylinders?
    NO – broken timing belt, head gasket leak, or damaged valvetrain componant.
    YES – continue
    Is there a blockage in the air intake?
    NO – verify engine timing, have ECU tested.
    YES – remove blockage
  2. #2
    Jul 2002
    New Braunfels, TX
    10,540
    Default Re: car wont start? click here! (troubleshooting guide)
    special thanks to Ax0n for his contributions to this guide.
  3. #3
    Oct 2000
    In ur srvrz patchin ur krnlz
    6,880
    Added timing belt check. I can't believe we missed that in this write-up!
  4. #4
    Jul 2002
    New Braunfels, TX
    10,540
    oh yeah. duh.
  5. #5
    Jul 2002
    New Braunfels, TX
    10,540
    Timing belt is mentioned. I went to fix it and found it under the compression y/n.
    yay, we're not dumb.
    oh wait, I see you edited the post. I guess we ARE dumb.
  6. #6
    Aug 2003
    Tampa Bay, FL
    530
    I'm having the "clicks, won't turn over, won't start" thing going on. I popped the hood and checked the terminals... those were good.
    Here's an easy question: where can I find the starter / starter motor? (Pics would be awesome if anyone has 'em)
    edit: I have a 2004 D23e
    Word.
  7. #7
    Newbie
    Nov 2005
    3
    I too am having the same problem. It clicks but it won't turn over at all... Ran through the steps and don't know where the starter on our cars are located. It should be behind the flywheel under the car, but cannot find it.
  8. #8
    Jun 2003
    Weston, Florida
    2,368
    Quote Originally Posted by Tailhooker
    Have you checked the battery? If you haven't its most likely a dead battery.
    2011 MS3 LSM: SURE TorqR3 / SURE Countershift / SURE Aeros SRI / CorkSport boost tubes / CorkSport TIP / CP-E TMIC / OBX Racepipe + res delete / PAD Occ kit / Forge BPV V1 / Cobb AP Stage 1+ 93oct (tuned by me ~16psi) / Autotech FP Internals + DO Stage 2 Meth + 19psi Coming Soon!
  9. #9
    Aug 2003
    Tampa Bay, FL
    530
    Quote Originally Posted by SilverZXIII
    Thats what I was thinking, but when I first had this happen (a few days ago) it clicked for a while and then cranked hard and turned right over. Does that make a difference?
    Also, should I be able to push-start it?
    Word.
  10. #10
    Dec 2005
    San Diego, Ca.
    6
    Question Re: car wont start? click here! (troubleshooting guide)
    I have a 2004 ZX3-DURATEC 2.3lt with 7,500 miles, and having the exact same symptoms with my car.-
    I just replaced the starter and celenoid, replaced the battery terminals, replaced the baterry....and still..click..click...no start!!! ... if push start the car, it works.
    ...any one has any ideas on what might be? any info will be apreciated, thank you.
  11. #11
    Feb 2004
    Graham, Wa
    115
    I got one for ya.....I have a 01 focus zx3 with the roush turbo kit. I pulled my car in the car port to put on my lambo's and went to start my car and it just clicked like my battery was dead so I used our charger on the jump start function started up and my plugs fouled and got some nice grey smoke outta the tail pipe. Watcha got for this?
    Your honda looks better in my rearview
  12. #12
    Oct 2005
    Long Island
    80
    Unhappy Re: car wont start? click here! (troubleshooting guide)
    HELP!!!!! I think I blew the fuse for the ignition.
    Where is it located?
    My car is big in Europe.
  13. #13
    Oct 2005
    Long Island
    80
    Thumbs up Re: car wont start? click here! (troubleshooting guide)
    Never mind, found it. I'm just an idiot.
  14. #14
    Newbie
    Apr 2006
    1
    Okay you Car Guru's please help...
    I have a Ford Focus Zx2 and today when I tried to start it. When I turn the key it starts just fine but then it starts stuttering and dies on me with the following lights: battery and alternator..
    Well, I checked the battery to make sure there wasnt any corrosion on the battery itself (We just replaced the battery on a different occurance anyways) and if its the alternator it just wouldnt start right?
    Just recently a friend and I had to change a hose that was going from the air filter because the old one had a hole in it and I checked that and it was still tight on the hose and felt no holes.
    When, I give it gas when it starts it stays alive for a few more minutes before spuddering and dying on me...
    Thanks
  15. #15
    Feb 2004
    Graham, Wa
    115
    Hey guys I need some help...I installed a new optima battery about a week and a half or 2 weeks ago. 2 nights ago I went out to my car to leave a friends house and I went to start it and nothing no click nothing. Battery has juice. Tested ign. relay and replaced the blown fuse in auxilary block underhood. 30 amp maxi with a square and a key in it. What is this fuse? Does anybody know? Any help would be greatly appreciated.
    Thanks,
    John
